Our Amica cooker is a couple of years old. Just come back from holiday, clicked the switch on the wall back on and…….nothing. I didn’t realise that cookers don’t have their own fuse.
Checked the household fuse box and worked out it has a 45amp fuse, replaced that with a new one and still nothing.
The question is do I call on someone to fix the cooker or someone to check the household electrics? Will an electrician do both?
Are you sure it's not on a fused spur?
First you shouldn't be replacing fuses unless the underlying problem had been diagnosed. Sounds like you need a new consumer unit if yours still has replaceable these and not MCBs.
Second it should be on its own circuit.
Most cooker related problems are due to oven elements blowing, our oven used to eat at least one a year although its been rather a long time since I last replaced it. I'd start there, they are generally cheap, easy to source and fairly straight forward to replace. YMMV.
Does your cooker have a clock and is it working? If not then it's likely the electricity supply. If it is working then something is wrong with your cooker
You might find an electrician who can do both as cookers are fairly straightforward
https://www.amica-international.co.uk/warranty-terms-and-conditions
Two year warranty if you're inside that period
They might offer a fixed price visit after that
What's with the additional page detail...a simple link would do, as intended
If by a fused spur you mean there should be a fused switch, then no there is no fuse for the switch. The only fuse is on the house fuse box.
No clock on our cooker, but the oven lights, fans, rings and ring lights all fail to operate.
Yep, old style ‘replace the wire’ type fuses for our fuse box (except the cooker one).
Sounds like an electricity problem them. It would be unusual for them all to stop working at the same time.
Check the oven light bulb. I had a cooker that basically shut down if it blew
No fuse in the cooker from Amica’s online info. And no fuse where the wires enter at the back either.
Looks like it’s time for an electrician then.
Thanks for the replies folks
Some cookers won't work if no time is set on the clock
Time for a new consumer unit though. Fuses?
as said above clock set to a time
Ah, if only it had a clock…….it’s a simple device this one, no clock
Have you tried setting the clock ? 😉😀
Or aligning the hanger?
Cooker Control Units (the big cooker switch on the wall) are notorious for loose connections which cause arcing and damage to the terminations. This stops them conducting to the output side. Assuming all is good in your fuse board and the cooker isn't toast (SWIDT) then that'd be a place to look, although it's not for the faint-hearted as they can be tricky to terminate properly without repeating the same issue that caused the arcing in the first place. There would also be heat damage to the cables that would need rectifying. If you can loosen the two switch screws and ease it forward, if it has been arcing on the back you'll smell it around the edges, it's quite a distinctive smell and not pleasant tbh. That's a dead giveaway for burnt terminals.
Did you actually check the fuse for continuity?
To be honest, if you still have wired fuses and are at the point where large power-hungry appliances are now not working without a good reason it's perhaps time to consider a rewire.
And it’s fixed 🙂
The problem? Wall switch was faulty.
However, now I know more about the fuse box I’m planning on getting the electricians back to upgrade that too.
Thanks for all the responses, I’m off to reset all the clocks that aren’t attached to the cooker (no, it still doesn’t have a clock), then out on the bike
