Broadband Coverage
[Closed] Broadband Coverage
3 Users
Hi All some advice needed again, my wife's art studio is has no WiFi but has phone socket connected to the home network. Do I just need another router and connect to socket? I have taken current router from main home tested and works fine but not sure what to do for a permanent option.
All advice appreciated.
Posted : 16/01/2020 5:44 pm
Is the power supply connected to the house?
Posted : 16/01/2020 5:45 pm
Hi Drac I am not to sure but it has its own fuse box, but I would need an electrician to tell. The telephone line is connected so would presume electric is but this is just a guess.
Posted : 16/01/2020 6:01 pm
Powerlink adapters May work then but someone with a better knowledge will know.
It won’t work over the phone line.
Posted : 16/01/2020 6:06 pm
Yeah, you can forget the phone line as part of a solution here. Plugging a second DSL router in would be like expecting to be able to make two different concurrent phone calls from two handsets.
Options are:
1) Run a CAT5 cable between the buildings, if physically practical.
2) Wi-Fi boosters / range extenders, depending how far apart they are.
3) PowerLine adapters, IF they're on the same bit of electrickery cabling as Drac was alluding to.
Posted : 16/01/2020 6:18 pm
