Briquettes or Lumpw...
[Closed] Briquettes or Lumpwood - the definitive answer...
9 Users
So, we all know coal is best, but what coal?
I'm a lumpwood man myself, but am I discounting briquettes too readily? Does a chimney make them easier to use / light?
Posted : 16/04/2015 12:48 pm
Proper BBQ - lumpwood. Have to use briquettes on the cobb though.
Posted : 16/04/2015 12:51 pm
 Yak
lumpwood. I then add some real wood too for some better flavoured smoke.
Posted : 16/04/2015 12:52 pm
Lumpwood sounds better!
tink, tink, tink...
Posted : 16/04/2015 12:55 pm
Lumpwood for me. Lit with a chimney starter.
Like Yak's use of additional wood - might try that.
Posted : 16/04/2015 12:56 pm
just make sure you use the right kinds of wood!
Posted : 16/04/2015 12:58 pm
Definitely lumpwood unless cooking for several hours... But what do you use?
The best good stuff which is also affordable that I have found is the restaurant grade lumpwood from bookers...
 Yak
I'm adding oak chippings right now.
Posted : 16/04/2015 1:07 pm
Mixture of both, but it depends on how long I'm cooking for. Lump wood I gets very hot quickly but doesn't last, briquettes even things out a bit.
EDIT: chimney starter and I'll add some flavouring wood chips too. Applewood last time I did a pork joint. Yum!
Posted : 16/04/2015 1:13 pm
I use charcoal if it's just me and the Wife having a bit of dinner on the BBQ. But if there's friend's round and the BBQ is likely to be used for a longer period, then I'll use briquettes with perhaps some charcoal to get things started quicker.
Posted : 16/04/2015 1:20 pm
a mix sounds like a good idea for longer cooks.
I use wood chips, in a little foil open topped pouch for smoke if I'm cooking with indirect heat, really makes the difference for whole chickens, ribs etc....
Posted : 16/04/2015 1:58 pm
