bothering to indica...
[Closed] bothering to indicate...
67 Users
I did wonder if this would stand up in court.
"Right sonny, did you not see all those arrows telling you that this lane is ahead only. You can't turn left there!"
"I think you'll find I can officer. I'm from STW-land so I'm allowed to completely ignore road markings that I don't agree with. Also, ahead actually means left."
"Oh fair enough. On your way, but try not to kill any more grannies."
Posted : 29/09/2016 3:17 pm
 Solo
[i] GrahamS - Member
I did wonder if this would stand up in court."Right sonny, did you not see all those arrows telling you that this lane is ahead only. You can't turn left there!"[/i]
That arrow is saying stay in a lane, which very soon splits into two lanes.
Posted : 29/09/2016 3:22 pm
 Solo
As for approaching the roundabout in the middle lane?
Simple, left lane is clagged with folk who've never used that roundabout before. So you take the middle lane to turn left, with the intention of cutting in, with the application of the relevant indicator.
But hey! You soon discover you can hang a left anyhow.
Sorted!!
Posted : 29/09/2016 3:27 pm
No it isn't. As per the TSRGD the arrows indicate "Appropriate Traffic Lanes for Different Destinations"
So it is saying "this lane for straight ahead" and the one next to it is saying "this lane for left turn".
As sbob says, when you approach the roundabout there is a big sign telling you that the three exits are left, straight on or right and there are three lanes clearly marked left, straight on and right.
I'm struggling to understand why anyone thinks they would pass their driving test if they took the straight on lane to go left. But this is STW. 😀
Posted : 29/09/2016 3:33 pm
 Solo
No it isn't. As per the TSRGD the arrows indicate "Appropriate Traffic Lanes for Different Destinations[/i]
But the lane later splits in two, so taking exit one or exit two is fine.
Posted : 29/09/2016 3:40 pm
The lane doesn't split in two. It just passes a turn to the left.
If it did split then it would have a double headed arrow indicating the two options, like all the other arrows on the roundabout where there are two options.
Posted : 29/09/2016 3:48 pm
The fundamental question here seems to be: are the arrow markings on the roundabout a load of bollocks? Since we can't decide about the top right bit of the roundabout, I present the bottom right arrows as evidence for the prosecution. Specifically the straight ahead arrows in both lane 1 and lane 2, despite the relevant exit only having one lane.
Posted : 29/09/2016 3:57 pm
If it "passed a turn to the left" there would be broken dotted lines across the mouth of the turn. There isn't. It's not. That lane splits in two. It's additional, new information contrary to the previous signage, and I think perhaps this is the critical bit you're missing. And it happens all over the place, because the standard and quality of such things isn't as consistently high as it could be.
It is, at best, ambiguous as there are contradictory lane markings. Why does the lane markings just before the junction in my example supersede previous contrary lane markings, yet the ones in yours do not?
Why are you so convinced that you're right and everyone else is wrong when you said yourself in your initial post that "I confess I never quite got the hang of [it]"?
Posted : 29/09/2016 4:02 pm
The other fundamental, if you removed the arrows, what is the best way for it to work? If you removed all road markings on the roundabout, what is the best way for it to work?
Posted : 29/09/2016 4:07 pm
Yeah that's fair actually.
I'm not entirely sure why the lane 1 arrow there isn't a left arrow. 😕
I guess the exit is sort of "ahead" in that lane and it's pretty obvious you can't be any more left than you already are. But that's a different "ahead" to the "ahead and right" arrow in lane 2 which is a bit confusing.
Posted : 29/09/2016 4:10 pm
It is worth saying again that those arrows are for information: They are not mandatory, so ignoring them isn't illegal. If they wanted to make sure that you did not progress left from the mddle lane at that point they should've put a solid line hatching to prevent an exit there, and the two lanes after the exit should have markings showing you to move out to the outside lane if you don't want to go left. It is just crap road marking. There is no 'right' in this instance because the markings allow for an ambiguity.
Posted : 29/09/2016 4:34 pm
Aha, so which exit is the ahead from lane 2, and therefore which exit is the right?
Posted : 29/09/2016 4:39 pm
I think the ideal approach for that exit (if you follow my line of thinking on it) would be something like:
Which would be similar to the exit on the bottom left.
Because the reason it caused me bother was people making up their own rules instead of following the road markings and the Highway Code. 😀
Why are you so convinced that it is the road markings are wrong rather than your understanding?
What makes more sense: that multiple road engineers designed, inspected and signed off on a design that contradicts itself and introduces inevitable collisions (directly outside the council offices) - or that they signed off on a design that [i]would[/i] work if people just did what it tells them to do? 🙂
If you removed all the markings (and abolished the bit in the Highway Code about staying left to go left "unless signs or markings indicate otherwise") then it'd be even more chaos than it is - but yes [i]then[/i] I would probably come on at the top left straddling lane 1 and 2 to control the space and then move more definitely into lane 2 once I had made the exit. 😀
I think (and I agree [i]those[/i] arrows are confusing) that the ahead from lane 2 there is exit after the left and that right would be for the next (or any) after that.
Posted : 29/09/2016 4:45 pm
Because, as I suggested earlier, the whole roundabout markup is a clusterfrank of a design. That's the real problem here.
Posted : 29/09/2016 4:49 pm
It does have nice trees though.
Posted : 29/09/2016 4:52 pm
The debate seems to have morphed into you trying to prove that the way you interpret it is somehow "better," which is a bit random. Whether that would be better or worse is a matter of debate, I'm not a road designer and presumably you'd need some sort of traffic flow analysis in that area.
What I do know though is that if the road was marked like that, I'd 100% agree with you. But it isn't, so I'm not sure what point you're making; you could just as easily Photoshop some fictional white arrows on it.
Yet, that's clearly what happened. Are you asserting that there's no such thing as a shit road design?
I think (and I agree those arrows are confusing) that the ahead from lane 2 there is exit after the left and that right would be for the next (or any) after that.
QED. Where are your multiple design gurus now?
Posted : 29/09/2016 4:56 pm
What makes more sense: that multiple road engineers designed, inspected and signed off on a design that contradicts itself and introduces inevitable collisions (directly outside the council offices) - or that they signed off on a design that would work if people just did what it tells them to do?
Well the road markings are contradictory, so the only possibility is the former. Sorry!
Which left? Could you specify exactly which exits the straight on and right arrows in lane 2 are directing you to? I know it's tricky because the arrows are a load of bollocks, but I'm interested in your take on it.
Posted : 29/09/2016 4:57 pm
You suggesting there would be some dashed lines across the exit - I was just illustrating how I think it could be made clearer.
It's not perfect - but it doesn't cause obvious conflict and collisions in the way the top exit would.
See I just don't agree with you or Cougar on that point. I think the lane layout is definitely not as clear as it could be, and would be ambiguous were it not for those arrows explaining it. (And the Highway Code of course!)
You and Cougar seem to agree that the lane layout is ambiguous - but instead of using the arrows to clarify that ambiguity you have instead just picked an interpretation that leads to poor traffic flow and user conflict and then decided that multiple arrow markings must be wrong because they don't support it.
Welp I [b]reckon[/b] the Lane 1 arrow means "this lane for straight on to that exit". Lane 2 means "this lane for straight on to the second exit or right to the rest". And lane 3 "this lane for right to the rest"
Something like this:
I'm not sure why lane 1 isn't a left arrow. Maybe to avoid confusion with the entrance next to it? I dunno.
It's not 100% clear but it's not particularly unsafe either.
(And although it is just a "reckon" I don't have any other evidence that directly contradicts it. If I did I'd reconsider my interpretation.) 😀
Posted : 29/09/2016 5:40 pm
My apologies - I thought you might pick up that it was a trick question. If the right arrow means what you're suggesting, then it is directing traffic to go back down the road it has just come from.
Given the actual exits available, the only possible exit for the right arrow is actually the road to the right of your picture above (unless you think your team of experts are directing 2 lanes of traffic to do a u turn). Therefore the straight ahead arrows are directing 2 lanes of traffic into the single lane exit at the top of your picture. Not particularly unsafe?
Posted : 29/09/2016 5:53 pm
Why are you allowing traffic going right round at that right exit (the middle three of your yellow arrows over there) when the earlier white road arrow said it was straight on only? That shouldn't be allowed if the road arrows are immutable.
Posted : 29/09/2016 5:57 pm
(Sorry for brevity in the reply, I'm making tea)
Posted : 29/09/2016 5:59 pm
Different set of arrows, Cougar. Sorry for confusing things (though graham hasn't helped by rotating the pic!), simply disproving the suggestion that the planners know what they're doing.
Assuming that is that the same person planned both sets of arrows - may be a dodgy assumption given that it seems different people did the lane markings and arrows without talking to each other.
Posted : 29/09/2016 6:26 pm
Does it? Or is that poor traffic flow and conflict only due to the ambiguity? If the arrows were painted to remove the ambiguity (or removed altogether) would there still be a problem with the traffic flow and conflict?
The ambiguity is because of the arrows - in their absence there would be no ambiguity about the traffic flow into that exit.
Posted : 29/09/2016 6:31 pm
But they [i]are [/i]ambiguous. The 'lane' is, by defintion, delienated by the white broken line. For the first exit, the left hand side of the 'lane' continues off the roundabout whilst the right side continues around it. The lane spilts. When you take that first turn from the middle lane, you never at any point leave that lane by crossing a white line. You are not making a 'left turn'. Thw advisory arrow is meaningless unless it points to a contiguous lane which you are following.
Posted : 29/09/2016 6:33 pm
Exactly.
Even if we assume that as Graham asserts the white arrow states "you [b]must[/b] go 'straight on' and leave at the second exit", what happens if you'd arrived at that same exit from further round the roundabout in the infinite third lane, and then changed lanes to the second lane after the arrow? Anything stopping you from using that exit from the second lane then?
Posted : 29/09/2016 9:10 pm
Thus,
(apologies for my lack of artistic ability)
Posted : 29/09/2016 9:21 pm
 sbob
So arriving at the roundabout wanting to turn left, has anyone questioned the fact that the only instruction is to use the left hand lane?
No?
Then you just carry on. 😆
Utterly pointless. 😆
Posted : 30/09/2016 12:15 am
I don't think it helps much to resolve the question, but I thought you lot might be amused by the set of directions I managed to generate:
https://goo.gl/maps/piwcAsacENF2
Posted : 30/09/2016 1:44 am
Sorry for the late reply - I went to the pub 🙂
Right, so...
aracer:
As one of the possible options. Seems reasonable to me. Being able to go all the way around is one of the key features of a roundabout.
Didn't you tell me off earlier for suggesting changing lanes across a long dash?
Now you're telling me that an arrow saying [i]"this lane to go straight on"[/i] actually means [i]"[b]leave[/b] this lane to go straight on (which is really a bit left)[/i]?
No, I don't agree.
I do agree that it is odd that the left lane has a straight-on arrow there, but I don't think that's a good reason to start changing the definition of the other arrows.
Cougar:
Thus
WTaF?? 😯
If you take the route marked by your red dots then you have joined the roundabout in the right turn lane when you want to go straight on!
All the other cars??
If you do that then we now have at least three different streams of traffic all trying to get to second land of that exit!
We have the green line, which is people taking what I believe are the correct routes (i.e. the routes that follow the arrows and Highway Code).
We have the red lines which are people following your previously suggested routes (i.e. routes that ignore arrows and Highway Code in favour of having an easier time getting into the right lane at the exit)
And then we have your dots (i.e. Hyundai drivers and people on the phone)
Posted : 30/09/2016 9:34 am
Yep that's about how useful my satnav is in most parts of city centre Gateshead or Newcastle.
Posted : 30/09/2016 9:37 am
arrows are for guidance only.
The junction here has bike boxes which are bright and clear after I asked for them to be re-painted. They had been worn to the point of not being recognised and car drivers would get upset at cyclists stopping there because it wasn't obvious that they were entitled to.
I also asked for the "left turn only" arrow to be repainted, and repeated further up towards the junction. Drivers who were using that lane to go straight, hoping for a drag start to cut in first before the parked cars would get aggressive with cyclists in front of them spoiling their plan.
If ever there was a case for a "left turn only", it's here. The road further up is single carriageway with cars always parked in the bays.
However:
Thank you contacting Islington Council regarding Hornsey Road.
The left north bound lane at the junction of Hornsey Road and Tollington Road is not a mandatory left turn. [b]The arrow is there for guidance only.[/b] Both cycle and motor vehicle traffic is entitled to travel straight ahead from this lane. However, drivers should not be aggressive or threatening towards other road users and instances of this type of behaviour should be reported to the police.
We would not recommend further arrows be painted in this lane, however I will ensure that the existing arrows are refreshed if required.
Regards,
Mike Fletcher
Senior Engineer
Traffic and Parking Services
Environment and Regeneration
Fair play to them, they got the boxes repainted only about a week after I asked them to. If you spot something that needs done, it's well worth taking a few minutes to write to the council.
Posted : 30/09/2016 9:46 am
Yeah we covered that ned. Consensus seems to be (from a pistonheads thread) that the arrows are advisory unless they are accompanied by the words "Ahead Only", "Turn Left" or "Turn Right" ([url= http://www.legislation.gov.uk/uksi/2002/3113/schedule/6/made ]Diagram 1036 in TSRGD[/url]).
But traffic police [i]could[/i] (if they haven't had their Snickers) cite you ignoring arrows as a factor in an Inconsiderate Driving charge.
Good you got some action from the council though.
https://www.fixmystreet.com/ and http://www.fillthathole.org.uk/ are also useful for reporting stuff.
Posted : 30/09/2016 9:56 am
Apologies, that was a mistake on my part as I did it in a rush. Imagine that route starts from the entry at the bottom of the picture instead.
So now our rule is that we drive where other cars aren't?
No, there's one. There's traffic from the second lane as I've indicated, and your fictitious assertion that the second lane after the exit it's somehow exclusively for the first lane to swing across into with gay abandon. How the hell else are you supposed to leave by that exit when approaching from the entry road at the bottom of the picture, teleporter? Or gradually force your way out from the third lane into the first just to change straight back into the second lane when you leave the roundabout? That's insanity.
Posted : 30/09/2016 9:57 am
See, what you's lot are discussing is nuffin to do with "bothering to indicate" now is it? This is about a poorly marked roundabout, which isn't actually the fault of the shitty driving public!
I'd like to present you with a local roundabout of mine, where "bothering to indicate" is a real pain in the arse and causes me issues every day when I ride across it!
So what you have, approaching from A, is just one "normal" exit, B.
D is a shopping centre - normally only buses and pizza deliverers. AND ME.
E is Wickes, mainly.
So, how do you think people going from A to B behave on this roundabout?
(and what the hell do the dots coming out from E mean? but thats beside the point)
Posted : 30/09/2016 10:07 am
Or gradually force your way out from the third lane into the first just to change straight back into the second lane when you leave the roundabout? That's [s]insanity.[/s]The Highway Code
You signal and change lanes to the left after you pass the last exit before yours:
When taking an exit to the right or going full circle, unless signs or markings indicate otherwise
• signal right and approach in the right-hand lane
• keep to the right on the roundabout until you need to change lanes to exit the roundabout
• [b]signal left after you have passed the exit before the one you want.[/b]
When taking any intermediate exit, unless signs or markings indicate otherwise
• select the appropriate lane on approach to and on the roundabout
• you should not normally need to signal on approach
• stay in this lane until you need to alter course to exit the roundabout
I think some of the contention here is that I take the arrows as "signs or markings", but you are taking the [i]possibility[/i] of a turn as a "sign or marking" that overrides the arrow just a couple of metres before it.
And I can see your argument there. Really I can. It makes hitting that exit lane easier (or it would do if didn't conflict with all the cars doing it my way).
I've yet to hear anyone explain how me approaching in the middle lane, (which is clearly marked for "straight on" by two sets of arrows on approach) would fit with the Highway Code saying:
When taking the first exit to the left, unless signs or markings indicate otherwise
• [b]signal left and approach in the left-hand lane[/b]
• keep to the left on the roundabout and continue signalling left to leave.
The markings on the approach do not "indicate otherwise" do they?
In fact they directly reinforce what the HC says there, left lane for first exit.
Posted : 30/09/2016 10:20 am
Yeah we covered that ned. Consensus seems to be..
Really?. Seemed to be 3 pages of arguing about whether you could turn left from a lane with a straight on arrow in it?
Dez -
I'd expect people use A2 to get to B2. Can't think of a good reason why not.
Presumably there's a B2 there because the capacity is needed to get people off the roundabout. And how else are you going to get to B2 apart from from the inside lane of the roundabout? And if you can come off from the inside, does it matter whether you got there from A, C, D or E?
We could argue all day long about how it affects the journeys times of those going to D or E from A, or to B from C, D or E, biut you'd only know for sure with in depth traffic studies during conjested times, with chnges of priorities and measuring the effects.
If traffic's moving freely, A2 to B2 shouldn't affect anyone at all.
Posted : 30/09/2016 10:26 am
(Thanks ned!) Ah, but.. they do, probably half the A-B traffic is A1 to B1 and half A2 to B2. Problem is NOT ONE BASTARD indicates! From A2 to B2 a LEFT indicator would inform C traffic that they can come out.
Problem for me is, C traffic are so used to non-indication, when I'm going STRAIGHT ON to D, I have to signal right (wiv me arm) or C traffic just pulls out in front of me (and I'm usually not going slowly)
WHY WHY can't they indicate LEFT?
Posted : 30/09/2016 10:31 am
DezB: yeah a change of subject I think.
Two lanes on, two lanes off?
(thus ignoring the Highway Code unless it has some some signs we can't see)
They seem to be suggesting people joining at B should take the inside lane (lane 2) on the roundabout which is.. erm.. unusual.. but fits with the HC bit about "unless signs or markings indicate otherwise" I guess.
Posted : 30/09/2016 10:32 am
So I'm arriving from the bottom entrance (ho ho!) and I want to leave by the right exit, and am turning right after the exit.
By your interpretation, and following the advisory arrows, on entry I move to the third lane of the roundabout. On passing the last exit before mine, I have to make two lane changes in the space of several metres (which will be fun in busy traffic) to get into the far left lane, leave the exit, and then immediately try and return to the lane I've just left in the space of another few yards?
By my interpretation, on entry I move to the third lane of the roundabout. On passing the last exit before mine, I make one lane change to the second lane, stay in lane as I leave the roundabout by the perfectly clearly marked and valid exit, stay in lane as I progress down the road and then turn right at the junction.
Even if by some cruel twist of fate you're actually right and I'm wrong, then it's still crazy and needs changing. (TBF, even if I'm right the entire roundabout is still shite and needs redesigning, as I said before).
Posted : 30/09/2016 10:36 am
I think I can see why. They're all interpreting it as "straight on" rather than "first exit."
Posted : 30/09/2016 10:38 am
Maybe, but even straight on you indicate LEFT to exit!
Posted : 30/09/2016 10:39 am
Sorry Cougar, my fault for rotating the diagram and all that, which bottom entrance? Bottom left on the last version of the diagram (with the red dots)?
(If so I'll reply in a bit - gotta go pick up the kids)
Posted : 30/09/2016 10:40 am
God knows now, I hadn't even noticed! Does it make much difference? I thought we were only ever discussing the one exit.
Posted : 30/09/2016 10:42 am
Problem is that we want to interfere and correct others (see any thread of 100 pages or more).
#ChillWinston
Posted : 30/09/2016 10:48 am
 Solo
[i] DezB - Member
Problem is NOT ONE BASTARD indicates! From A2 to B2 a LEFT indicator would inform C traffic that they can come out.[/i]
Shouldn't you be waiting for said traffic to complete their move, before pulling onto the roundabout/exiting a junction.
Irrespective of what the little yellow lights are telling you?
Posted : 30/09/2016 10:49 am
I wasn't suggesting they were right, I'm just thinking maybe that's why they're doing it. Regular away I see successive cars leave a roundabout exit in front of me, one indicating left and the other indicating right as they both leave the same exit.
On your roundabout I'd be largely ignoring indicators anyway as they're unreliable - they could be indicating where they're going around the roundabout or that they intend to change lanes (A2 to B1 or some such, crazy to do it on a roundabout but y'know, people).
Posted : 30/09/2016 10:50 am
This is genius. I am thoroughly enjoying the level of detail you guys are going into to annotate this one roundabout.
Top marks to GrahamS for his smooth & flowing arrow style, as well as use of multiple colours.
It's just a shame you're incorrect about the use of the roundabout, the pesky arrows and that lane 2 straight on/left into the right hand lane conundrum!.... 😆
I've only scan read the replies, but aracer & Cougar seem to be agreeing with my original viewpoint & are therefore obviously correct.
Oh, and on the latest Cougar's dotted lines which he did wrong teaser, bottom exit as I took it was the bottom of the last pic (with the flowing red & green lines), as opposed to the left hand side of the image which is where his dots originally sprung from.....
Posted : 30/09/2016 10:53 am
You! You are on a thread about BOTHERING TO INDICATE and you come up with crap like that! Jeez, you are part of the problem obviously 👿
[i]I'd be largely ignoring indicators anyway as they're unreliable[/i]
YEAH! What's the point of indicators anyway? Nobody uses them correctly so we might as well not use them at all. Or ignore them..
hmph
Posted : 30/09/2016 10:54 am
 Solo
[i]GrahamS - Member
I've yet to hear anyone explain how me approaching in the middle lane, (which is clearly marked for "straight on" by two sets of arrows on approach) would fit with the Highway Code saying[/i]
The middle lane at the entrance is incorrectly marked wrt to that lane on the roundabout splitting into two lanes.
The middle lane of the approach should have a combined ahead and left arrow as has been painted in lane one of the eastern approach road.
Posted : 30/09/2016 10:56 am
 hels
The craziness started when somebody put more than one lane on a roundabout. Funnel everybody to one lane at all the entrances and exits, with one lane on the roundabout. Indicate left to leave and right to continue around. All sorted. Traffic would flow better too.
Although, as all motorbikerists know, the indicator flashing only means that the bulb works. (no it doesn't, yes it does, no it doesn't etc)
 Solo
[i] hmph[/i]
Posted : 30/09/2016 10:59 am
Yeah, I cocked it up cos I was tired and did it in a rush, I said as much earlier. That's what I meant, approaching from the entrance further round.
Indicators are a show of intention, but people are idiots and not to be trusted. If you rely solely on indicators as gospel as to what people are [i]actually[/i] going to do, you're going to end up under someone's wheels.
Posted : 30/09/2016 11:03 am
Thanks for the tip. I'll hopefully survive another couple of decades of road use now.
Posted : 30/09/2016 11:05 am
I think that on Graham's Roundabout (as it shall henceforth be known), part of the issue is that there are (at times) 3 lanes.
Remove a lane and it's clear; left lane for 'next' exit, right lane otherwise.
Add in the third lane & it may help traffic throughput but does add ambiguity.
Using Graham's 'green line theory' above, then there's basically no scenario where you would need to be in lane 3. And the HC parts that Graham quotes all seem to assume a 2-lane setup.
So i think
are actually intended for general use to speed up traffic flow through the junction. Otherwise you may as well just have a 2 lane roundabout.
Posted : 30/09/2016 11:06 am
Sorry. #mansplaining
Part of the problem is that many roundabouts in the real world bear little resemblance to THC's idealised version.
Posted : 30/09/2016 11:11 am
and drivers! 😆
Posted : 30/09/2016 11:15 am
Well, quite.
Posted : 30/09/2016 11:19 am
[i]Graham's Roundabout (as it shall henceforth be known)[/i]
Don't name that shite in my town after me though eh?!
[edit]just realised - every single day this thread will be like an earworm when I negotiate that! Argh.
Posted : 30/09/2016 11:25 am
I think we should start a petition to have the middle arrow changed, the lanes coloured in and the roundabout renamed to 'The Graham Cougar Circular' 😀
Posted : 30/09/2016 11:52 am
Circular being the operative word.
Posted : 30/09/2016 11:59 am
Sorry for the delay. Kids!
Right..
Cougar:
It's a "straight on" from the bottom left so I assume you mean coming on from the bottom right yeah?
I'd do this:
Join in the right lane for the right turn (as per Highway Code and road markings). Move left once past the exit before mine (as per Highway Code). Exit roundabout then select RH lane.
Which is why I laughed at you saying [i]"If folk just stuck to what the HC says, there'd be no discussion. It's folk re-interpreting the situation and coming to their own answer is where it starts to get sketchy, imo."[/i]
Here you are ignoring the Highway Code and re-interpreting the situation to come up with an answer based on the arrows you think [i]should[/i] be there rather than the ones that actually are there.
For the record I completely agree that you/Cougar/aracers plan [i]would[/i] work, but if that was the intent then the roundabout would be marked like this:
But it isn't.
(I'm actually quite tempted to write to Gateshead council and ask them to explain it - but knowing them I'd get nothing back. FOI request for the plans maybe?)
This is probably a good point to say that use of indicators on roundabouts is [b]only advisory[/b].
And if this thread has taught me anything its that most people are happy to ignore the advisory stuff if they think it'll take less effort. 😉
Posted : 30/09/2016 12:20 pm
I'd do this:
You're moving out to the first lane too early,
• signal left after you have passed the exit before the one you want.
You wouldn't change lanes before indicating; so you pass the exit, [b]then[/b] indicate, [b]then[/b] manoeuvre across. I know this sounds pedantic, but it drastically reduces the time you've got to do your 37 unnecessary lane changes, rather than the nice sweeping curve you've drawn.
Plus, veering dangerously back on topic, your indicating to change lanes that early could be misconstrued as an intention to leave an exit earlier, risking the chance that people will pull out on you.
Posted : 30/09/2016 12:34 pm
As I said earlier, I don't think it's [i]effort[/i] (I mean... effort?!) , it's just something that's either ingrained into your driving or it's not. For some reason (faulty brains I say), for most it's not.
Kinda depends what speed you're doing. Note the 20 signs on the exit, the fact you are only a dozen metres after the lights, and the fact I said this roundabout is solid at rush-hour.
One lane change on the roundabout - same as your approach.
One additional change off the roundabout to get into the correct exit lane.
Posted : 30/09/2016 12:42 pm
Lane three to lane one is two changes.
Posted : 30/09/2016 1:01 pm
Didn't you tell me off earlier for changing lanes across a long dash?
Now you're telling me that an arrow saying "this lane to go straight on" actually means "leave this lane to go straight on (which is really a bit left)?
I'm just saying that's what the arrows are telling you to do, I don't think I've ever suggested that the arrows are telling you to do anything sensible - the whole point of this little interlude is that they're not (and so by extension none of the arrows on the roundabout can be trusted). Thank you for agreeing with me.
That's not odd at all - not if you consider how and where the arrows are providing you with information. By the time you are past the exit those are alongside, those arrows are already out of view, so at that point the left turn is the exit they are alongside.
However if you like I'll go with your interpretation of those arrows - this is where it really gets good! So you're suggesting that the right arrows in lanes 2 and 3 are sending traffic right around the roundabout back to the exit we were first discussing? To the exit which you think you can only exit from a single lane? Which set of arrows are wrong?
Posted : 30/09/2016 1:44 pm
• signal left and approach in the left-hand lane
OK I'll have a go if it helps. The trouble here - and with the whole discussion of Graham's roundabout - is that [b]you[/b] are using your own interpretation of the HC. There are two sorts of road markings here, the ones hidden by other cars when it's congested, and the ones still clearly visible on the edges of the lanes. You seem to be completely ignoring the latter.
When you are on the roundabout, the edge of lane markings quite clearly indicate that it is acceptable and correct to turn left there from both lanes. Hence there is no ignoring of the HC from those of us suggesting that is correct.
As an aside, when I was doing my streetmap tour last night I noted that the next junction on your route has the arrows marked on the road reinforced by signs at the side of the road which you can still see when it is congested. There are no such signs on the roundabout or the approach, hence when it is congested the only available information from road markings is from the lane markings.
Posted : 30/09/2016 2:03 pm
As it gets us vaguely back on topic, I'll also have a go at DezB's roundabout ( 😉 ). I can see why nobody going from bottom to top there indicates - and I'd suggest that actually going from A2 to B2, not indicating may be the correct thing to do, given it could easily be interpreted as an intention to use B1. Meanwhile it seems correct to indicate right to go from A to D given that exit is well past 1 o'clock. Sorry - I'm not doing the usual STW being contrary here, that's my genuine interpretation of correct behaviour there.
I can see why from the presumed (but out of picture) orientation of the bottom road you're describing D as "straight on" but from the actual orientation of the exits on the roundabout it isn't.
Posted : 30/09/2016 2:11 pm
Nah, everyone (locals!) coming out of C knows that a A2 car indicating left is going B2. Cos that's what people do. Thing is A2 to ANY exit is not inidicated, so it's a bloody guessing game. Except the poor beleaguered cylist, who has to indicate or get squished.
(Actually, my issue is also keeping momentum, so if A2 is indicating left I can go past - if they're not I have to stop behind cos I don't know where they're going)
But! Doesn't the [i]sign[/i] leading to the roundabout indicate (tell!) which is straight on, which is right? Here's another one -
Posted : 30/09/2016 2:34 pm
You're going from A, to Tesco.. which lane and what indication?
Posted : 30/09/2016 2:40 pm
What a horrible roundabout.
A2 approach definitely. I'd probably indicate right, then left after the Gym exit.
Posted : 30/09/2016 2:52 pm
Yes! Thank you Cougar - that's what I think. 3rd exit, right lane.
But -
So nearly all go A1, no indication (natch) and you don't know where the sod they're going!
Posted : 30/09/2016 3:03 pm
Well that's a problem, and the latter just standard fare unfortunately. #bloodycyclists
But! Doesn't the sign leading to the roundabout indicate (tell!) which is straight on, which is right?
Possibly - do we have to play the guessing game now?
I tend to agree with Cougar on indication on your latest one, though arguably not indicating is also correct - if there was a minor exit on the right which didn't fundamentally change the traffic flow then it would be incorrect to indicate right, but that wouldn't change anything for you. Of course if everybody indicated left when taking an exit this issue would largely be solved...
Surely you'd indicate right until you pass the last junction before the one you want then indicate (and change lanes if you have taken inside lane) left for the exit.
This may, or may not, have been discussed earlier, but I've had work to do and am not reading all that.
Posted : 30/09/2016 3:10 pm
I knew it was a trap! That's exactly what I'd do based on the strength of that sign and no other information.
It's why I said "probably" - it's difficult to be sure just from a still without actually being there, there may be other information that we're not seeing (and there was).
Posted : 30/09/2016 3:11 pm
The sign is wrong anyway. Why have they made the housing exit like it's nothing?
Pisses me off. IDiot planners.
Sorry aracer. Sign for that miniroundabout coming up...
(I really do think too much about this stuff. Glad there's others like me!)
Oh, there isn't a sign at all! Not on Google Earth anyway (will look on way home)
But thought you'd enjoy this view of the approach to that roundabout with the amazing vanishing cycle-path 😕
this is the first roundabout (not the one with Tesco) btw.
Posted : 30/09/2016 3:15 pm
Does the sign predate the estate and they've never updated it, perhaps?
Posted : 30/09/2016 3:22 pm
Just give us a Google maps link?
Posted : 30/09/2016 3:24 pm
 rsl1
In a strange turn of events I had an incident with a motorcycle recently where he attempted an overtake on 4 cars all indicating right onto a minor road (still moving) including one which turned across in front of him followed by me who he hit. He wasn't in sight when I checked my mirrors but the two cars turning right behind me were hence I chose to concentrate on the blind brow ahead (i did spot him with final check but was too late to avoid)
Somehow there is still a debate about who is to blame despite dashcam footage and him accepting responsibility at the scene... So maybe there's no point in indicating after all?
Posted : 30/09/2016 3:49 pm
The irony there is that if you were a motorcyclist you'd probably have seen him. There's an extra shoulder-check they teach you on the bike course that doesn't get mentioned on the car one, called (with good reason) the life-saver; I still do it now when I'm in the car.
Damn fool thing for the biker to do though.
Posted : 30/09/2016 4:01 pm
Page 3 / 4
