Boring holes in the...
[Closed] Boring holes in the bottom of bottles.
12 Users
How?
Basically the plan is to daisy chain many bottles together to form a continuous flow when i pumped water through them.
I'd rather like to insert the top of one, into the bottom of the next and seal with a rubber grommet of sorts.
It's for a solar water heated shower.
I've heard abrasive paste can be used with a piece of notched brass tube. Or i could make a furnace and bring each bottle to a temp in which i could force a hole through it.
Cheers!
Posted : 30/04/2013 8:11 pm
A little diamond core drill?
http://www.amazon.co.uk/gp/aw/d/B0015NULJQ
Posted : 30/04/2013 8:15 pm
Diamond tile hole cutter? must be a similar issue to having to put pipe holes in porceline tiles? And dont do yourself down, it's not [i]that[/i] boring a question... 😉
I am guessing they are glass bottles then?
You will need a lot of heat to melt the glass from what I have seen the university glass blower use.
I'd definitely go the diamond hole cutter route. Unless you know someone with a water jet cutter which works well.
Posted : 30/04/2013 8:21 pm
I was considering a diamond cutter with generous amounts of water.
Cheers, was wondering about other options, but seems, there isn't many.
Yes, they're glass bottles.
Posted : 30/04/2013 8:25 pm
maybe use coke cans instead? Plenty of designs online for can designs with a sheet of glass on top.
Posted : 30/04/2013 8:26 pm
A glass cutter all the way round about an inch from the bottom, and then tap the bottom...
Posted : 30/04/2013 8:27 pm
 grum
Can you not make them interesting holes?
IGMC. 😳
Don't forget to vent the pressure in the bottles so that when the water gets heated in the [s]hot Chilean[/s] sun the bottle doesn't fail [s]and explode like a frigging ied[/s].
Posted : 30/04/2013 8:34 pm
I've hundreds of glass bottles and don't fancy getting diabetes just to get a load of cans together.
Grum 🙄
Khani. I only need a hole a little bigger than the top of a bottle.
 grum
Grum
Eh? I was making a (really) crap pun on the use of the word 'boring'. Now I'm confused. 😕
Posted : 30/04/2013 8:35 pm
Show them the overtaking thread, that could bore holes through diamonds.
Posted : 30/04/2013 8:38 pm
Konabunny. It would only be sealed at the refill end, the other end would have a pressure release valve near the shower head. Or should i put in a few at intervals along the system?
Posted : 30/04/2013 8:40 pm
Grum. I should of put a space between your name and the previous statement. I was mearly rolling my eyes at your pun;)
Posted : 30/04/2013 8:42 pm
 ski
Sharki - curious, do you have any pictures of what it would look like once finished?
Posted : 30/04/2013 8:43 pm
Nope, it's a design i've heard about. The version i heard about suggested interlinking the bottles with pieces of hose and the only way i can think of it working properly, would be to go in one end and out the other.
This is not me.
[img] ?w=410&h=308[/img]
Posted : 30/04/2013 8:47 pm
http://www.ehow.co.uk/how_8645712_cut-glass-string-under-water.html
something based on this...
Posted : 30/04/2013 9:27 pm
what about if you used copper pipes to do a straw in the bottle type set up?
ie the pipe goes to the bottom of the bottle which flows water in and a larger pipe that terminates at the top takes water out. Just need some kind of bung (eg cork) with two holes in for the pipes. You can make the pipes U shapes to link all the bottles togther.
Posted : 30/04/2013 9:42 pm
or from jonbas link: http://www.ehow.co.uk/how_6749312_cut-hole-glass-bottle.html
Posted : 30/04/2013 9:44 pm
You would be better off with brown bottles rather green ones, if you're thinking of copying the geezer in your picture. Also I suspect that brown glass is more likely to inhibit the growth of algae, a potentially very serious problem imho.
Posted : 30/04/2013 9:58 pm
I saw a very crude one in Spain but using big plastic 2 litre bottles - just one long line on a roof but I guess it might be warmer (Quicker to heat up) in Spain 😀
Posted : 01/05/2013 6:56 am
Sharki, I don't know the right way to do it, only th wrong way that almost shredded my uncle!
Posted : 01/05/2013 9:48 am
