bolt/ fastner help
[Closed] bolt/ fastner help
9 Users
I know i have seen a type of bolt but i don;t know what it's called or where to buy it..
A threaded bolt (probably cap head/ hex head) but the tip has a captive rotating plate.
Any ideas what they are called, or even where thay are used.
Please help....
Posted : 17/05/2017 3:54 pm
Have you tried doing a Google Images search ? - might spot something that's close without having to get the name exactly right.
Posted : 17/05/2017 4:22 pm
Do you mean a captive washer under the bolt head, or at the thread end of the bolt, like a levelling foot?
Posted : 17/05/2017 4:30 pm
yep - not even close - yet..
at the thread end of the bolt.
it's not so much a foot - as the bolt still fits through it's standard hole. eg m8.
Posted : 17/05/2017 4:47 pm
What would it's purpose be? The only thing I can think of that would be close to that is a set screw with rotating tip - normally a ball bearing or brass/plastic insert in the end.
Posted : 17/05/2017 5:08 pm
Posted : 17/05/2017 5:10 pm
What are you trying to do with it?
Might help narrow it down like.
Posted : 17/05/2017 5:11 pm
http://m.laxmifastener.com/fischer-fastner.html
Posted : 17/05/2017 7:06 pm
it's pushing against a plate - the bolt is to set the position of the plate.
The bolt is digging in to the plate (it's stainless) - i thought that one of those screws with the 'spinny tip' would help. but bugger me i don't know what they are!!
Posted : 17/05/2017 8:36 pm
It sounds a little bit like a variation of this sort of thing which is an adjustable or levelling foot.
You turn the bolt which freely turns in the plate.
Posted : 17/05/2017 8:54 pm
Think what your looking for is a toggle clamp stud. Quick google shows one in images
Can't see.one in its raw form in the uk. But suggest a toggle clamp and strip out the stud and end
https://www.amazon.com/JW-Winco-Stainless-Assembly-Diameter/dp/B00G5754D0
Posted : 17/05/2017 9:05 pm
Ball and socket levelling mount???
http://www.vibrasystems.com/product/leveling-mounts-feet/b-series-steel-ball-and-socket.html
Posted : 17/05/2017 9:21 pm
I reckon you are thinking of this ??? The blind bolt
https://m.youtube.com/watch?v=j3imSL7A3WU
Posted : 17/05/2017 11:56 pm
