Boiler Advice - Hot...
[Closed] Boiler Advice - Hot - Not Hot - AhhhH!
6 Users
Hello,
Our gas boiler is 8 years old. It powers the radiators and hot water for the house. For a few years now the water has begun to run cold for short periods - noticeable during showers, though it doesn't seem to effect hot water in the kitchen.
The shower is about 3m higher than the boiler, the kitchen about 3 m below. Will that have an effect?
Any Ideas?
Is 8 years old for a gas boiler?
The system is controlled by a central thermostat on the wall as opposed to thermostats on each rad. Is that out dated now?
How much to change the boiler and install thermostats on each rad? 6 rads in the house.
Any advice please?!
Cheers!
Posted : 29/11/2013 9:16 am
If it's a combi boiler it sounds as though you should check the pressure and turn that tap which refills it with water. When they're running empty they perform like that.
Posted : 29/11/2013 9:20 am
When was it last serviced?
doing rad stats is fairly cheap if they're draining the system and flushing it for a new boiler anyway but you'd still keep the central one too.
I'd allow £2k for a new boiler and associated work.
One thing to check is the size of the gas pipe - if it's 15mm it may need to be changed to a 22mm supply.
Posted : 29/11/2013 9:23 am
Flow sensor maybe. They can gum up a bit which can make it intermittent. Mine pops open with the removal of a circlip.
Posted : 29/11/2013 9:26 am
Pressure - that we must check!
I'll read up on the flow sensor. That is a potential as the problem has been getting worse and the "outages" have been getting longer.
Posted : 29/11/2013 9:31 am
If it is a combi and there is plenty hot water at all other taps, I'd be looking at the shower. No need to replace an 8 yr old boiler, I would have trv's fitted though.
Posted : 29/11/2013 9:32 am
What he said about the shower.
Personally i wouldnt be mch fussed with trvs but would fit a programble 7 day wireless stat.
Most stats are in the hall and about as much use as a toaster for the job.
Posted : 29/11/2013 9:45 am
Trail Rat and Supreme Bean - I think you're onto something. Seems so obvious but it may be the shower mixer unit. It could be as simple as the tap washer being a bit dodgy.
I'll look into it.
Cheers all!
Posted : 29/11/2013 9:49 am
