Any recommendations?
To be used when running if that matters.
Budget? Standard answer seems to be [url= http://www.plantronics.com/uk/product/backbeat-fit#fndtn-overview ]Plantronics Backbeat Fit[/url], which I use following a recommendation on here and which have been faultless in 6 months of use.
Use those on the turbo and would recommend them.
Budget?
Up to around 100 squids.
[url= http://singletrackmag.com/forum/topic/bluetooth-earphones-for-running ]http://singletrackmag.com/forum/topic/bluetooth-earphones-for-running[/url]
Gives standard answer.
I like my Jabra Rox, but have never done any running in them, so can't say if they fall out or not. Sound's good from them though, and I found mine for about £30 or so.
I've used the cheap in-ear ones, they work fine (assuming high sound quality isn't something you're too worried about) but they tend to start falling out when I get a bit too sweaty. That's on a treadmill, though, outside I probably wouldn't sweat as much and it wouldn't be an issue. Either way they cost less than 20€ so I'm not too worried!
We just gave someone a set of these for exercise / gym use, and they have been very well received. I was impressed with the quality and their sound too:
http://www.amazon.co.uk/gp/product/B00ISRUFXY
Bragi Dash if you can push yer budget and wait a month.
fairly sure they won't fit "in" his ears unless he's the BFG.
theflatboy - Member
cheers will check those out - sort of in ear but plus hook over to keep in and waterproof with big buttons - killed a lot of earphones running in the rain
I find the hook over ones are uncomfortable if you wear sunglasses, YMMV.
