Very OT, but worth ago.
I have some alloy wheels on my car, and I have "lost" one of the center caps which cover up the bolts on the alloy wheel and I am damned if I can find any replacements.
The outside width of the hub which I measured last night is 165mm.
So anyone have any idea where I can track some down
Main dealer 😉
Make model of wheel?
Ebay breakers main dealer/ wheel manufacturer. Or silver tape.
Give us a picture of the wheel.
Scrap yard??
Renault or Vauxhall?
A car park
Its a replica VW wheel.
And it looks like:
[URL= http://i9.photobucket.com/albums/a91/richc666/IMAG0262.jp g" target="_blank">
http://i9.photobucket.com/albums/a91/richc666/IMAG0262.jp g"/> [/IMG][/URL]
Essentially its a little plastic hub cap with 165mm diameter and I am damned if I can track one down.
So who makes the replica wheel?
too small, I need the entire bit, here is a picture of the wheel with the missing one.
[URL= http://i9.photobucket.com/albums/a91/richc666/IMAG0263.jp g" target="_blank">
http://i9.photobucket.com/albums/a91/richc666/IMAG0263.jp g"/> [/IMG][/URL]
no idea who makes it, as I couldn't find any markings
I think you need to be looking at VAG/Audi:
http://www.ebay.co.uk/itm/Audi-Alloy-Wheel-Centre-Cap-A2-A3-A4-A6-A8-S6-S8-RS4-RS6-TT-S-LINE-146mm-Hub-Cap-/111142980783?pt=UK_Cars_Parts_Vehicles_Wheels_tyre_Trims_Trims_ET&hash=item19e0a34caf
It's still not 165mm though surely? That would make the wheel about 20" or more?
Or is my maths really terrible!
screwdriver and a dark street 😉
or
[url= http://www.ebay.co.uk/itm/VW-PASSAT-97-00-CENTRE-HUB-CAP-CHROME-FOR-3B0601025A-7JX15H2-ET45-3B0601149FED-/271166837547?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3f22cd932b#ht_2313wt_1186 ]this?[/url]
So I think you've got an RS8 replica wheel.
Are you sure 165mm...the biggest seems to be 145/146mm?
Best thing to do imo is remove one of the ones you still have and clean it up, on the back side should be a part number something like - 3b0 601 149. Which if you type into ebay comes up with quite a few that look similar.
That does look like an after-market wheel though as there seems to be a lot of wheel bolt holes, ie suitable for multi fitments. Should be Ok as I'd guess the centres are all the same anyway
Edit - You know they are replicas, coz you said so. Oh and they are Audi A8 replicas
Carl
OK thanks for the help, I will lever off another one and see what I can find.
They are very big which seems to be making life hard.
Hi, were you able to get the part number? I have exactly the same wheels and the same problem however all four of my centre caps were stolen so i can't get the correct part number. My wheels are 17" and none of the caps i've found on ebay fit.
Sounds like richc has been poaching caps - and maybe collected a few spares at the same time... 😈
What has the cap diameter go to do with wheel size? Or am I missing something?
It's still not 165mm though surely? That would make the wheel about 20" or more?Or is my maths really terrible!
Terrible. 😉
165mm is a fraction over 2.5". You're thinking of 165cm, which would be 6.5".
Im confused. Wouldnt 165cm be 5ft 4inches?
I bought a set of 155cm caps which were the right size on the outer edge but the centre clips to secure the caps were the wrong size.
Sorry, left out the decimal; 16.5cm = 6.49", 165cm = 64.96". That's what comes of using the computer at work with an unfamiliar keyboard and OS, while making sure it's not too obvious that I'm slacking off. 😳
Hi, richc, were you able to get the part number?
