best way to cut sil...
[Closed] best way to cut silver braided hydraulic brake hose ?
10 Users
anyone know the best way to cut silver braided hydraulic brake hose without a proper hose cutter, so i dont knacker this stuff with it being so exspensive appreciate the do's & dont's, i have the usual shed tools
Posted : 07/10/2013 9:43 am
Well wrap it in masking tape and use a very fine toothed hacksaw/junior hacksaw blade was how I use to do braided brake hoses on my cars which is the same stuff, I think.
Posted : 07/10/2013 9:46 am
what he said without pipe cutters your only choice is a saw/tape but its not ideal
Ensure you have no burrs afterwards including inside the pipe
Posted : 07/10/2013 10:17 am
How about popping down to the LBS with a pack of biscuits and pleasant word?
Posted : 07/10/2013 10:28 am
The best way without a proper hose saw is to wrap with masking tape as already said but use an angle grinder with a thin cutting disc. The end result is much tidier than using a hack saw 😉
Posted : 07/10/2013 11:45 am
Check they did not go to public school first 😉
I am sure it is tidier but it is it usable?
Posted : 07/10/2013 12:25 pm
I just normal wire cutters/snips
Posted : 07/10/2013 1:03 pm
Masking Tape, Vice, fine pitch (New) hacksaw blade, take your time and let the saw do the work.
If you are in a hurry then, Masking tape and a thin cutting disc in a dremel works brilliantly
Posted : 07/10/2013 1:51 pm
thanks i have the dremel and thin discs never thought of that so thanks to all who contributed appreciate it.
Posted : 08/10/2013 12:22 pm
Cold chisel, big hammer and something to chop it on(anvil), it's how we used to do all our braided hoses.
Posted : 08/10/2013 1:05 pm
Posted : 08/10/2013 1:08 pm
With a haddock...
Posted : 08/10/2013 1:59 pm
+1, but not an angle grinder, use a dremel with a fine cutting disc.
Posted : 08/10/2013 2:33 pm
