Beginners Guide to ...
[Closed] Beginners Guide to Python...
8 Users
Having been inspired yesterday I've just started having a play with python. Been following this tutorial as he's started from the beginning so easy for people like me to follow.
http://www.dickBaldwin.com/
However I've hit a wall as I don't know how to create a path file for it. I'm using Mac OS X. Feeling a bit like I'm in over my head but I really want to get to grips with it.
So any help / tips / advice here will be greatly appreciated!
Posted : 07/04/2011 6:47 pm
Start with the dead parrot
Posted : 07/04/2011 6:58 pm
“it's f*****g snuffed it!”
Posted : 07/04/2011 7:01 pm
Trouble downt mill,
four yorkshiremen...
ministry of sllly walks.
Posted : 07/04/2011 7:08 pm
Should have seen that one coming!
Posted : 07/04/2011 7:10 pm
Yay, Python!
[url= http://docs.python.org/tutorial/ ]http://docs.python.org/tutorial/[/url]
Another tutorial you might want to look at. What do you mean a path file? Do you mean adding Python to your system path so that you can call python from the command line?
Have you done any coding before?
Posted : 07/04/2011 7:12 pm
Cheers chvck, that looks like a helpful tutorial.
I'm under the impression that to start using scripts I have to set a path for it?
And no, no coding experience whatsoever!
Posted : 07/04/2011 7:15 pm
Posted : 07/04/2011 7:23 pm
I'm not an osx user but i use Ubuntu so it's not that far away.
[url= http://stackoverflow.com/questions/3387695/add-to-python-path-mac-os-x ]http://stackoverflow.com/questions/3387695/add-to-python-path-mac-os-x[/url]
Might help you, it may not. One of the most important things (at least to me) is the editor that you use to write code. Having syntax highlighting and auto-complete on keywords is quite nice. It's worth having a play with a few to see what you like. I use Komodo Edit 6
[url= http://www.activestate.com/komodo-edit ]http://www.activestate.com/komodo-edit[/url]
It may also be worth having a look at a few generic programming guides and that sort of thing. When you've got to grips with it all I can send/link you some of my code to have a play with if you like.
Posted : 07/04/2011 7:26 pm
Python comes pre-installed on OSX. Snow Leopard ships with 2.6 specifically. You don't need to mess with your path to run a script, just do "python <your script.py>" in Terminal.app and you're away.
To add to chvck's bit about editors, give [url= http://macromates.com/ ]Textmate[/url] a go. It's very popular on OSX and pretty cheap to buy if you like it.
Posted : 07/04/2011 7:40 pm
