Basic electrickery ...
[Closed] Basic electrickery wiring question
4 Users
Can I wire this thermostat:
[URL= http://img.photobucket.com/albums/v242/glasgowdan/Mobile%20Uploads/IMG_20160918_095512187_zpspbbl05et.jp g" target="_blank">http://img.photobucket.com/albums/v242/glasgowdan/Mobile%20Uploads/IMG_20160918_095512187_zpspbbl05et.jp g"/> [/IMG][/URL]
[URL= http://img.photobucket.com/albums/v242/glasgowdan/Mobile%20Uploads/IMG_20160918_095519168_zpskvhwiypb.jp g" target="_blank">http://img.photobucket.com/albums/v242/glasgowdan/Mobile%20Uploads/IMG_20160918_095519168_zpskvhwiypb.jp g"/> [/IMG][/URL]
Onto this wire?
[URL= http://img.photobucket.com/albums/v242/glasgowdan/Mobile%20Uploads/IMG_20160918_095531523_zps9sgboote.jp g" target="_blank">http://img.photobucket.com/albums/v242/glasgowdan/Mobile%20Uploads/IMG_20160918_095531523_zps9sgboote.jp g"/> [/IMG][/URL]
Posted : 18/09/2016 9:38 am
What's it for?
Posted : 18/09/2016 9:51 am
yes, your only using two cores like before. as long as the other end is going back to your heating control box.
Posted : 18/09/2016 10:08 am
Don't see why not, but are you aware you've damaged the insulation on the new cable where you've stripped the outer off?
Posted : 18/09/2016 10:09 am
Cheers. The plumber has routed the new cable into the hallway for me as we're moving the thermostat, it's not connected, but I saw the cable was different and groaned. Yes, I know the insulation is cut, there's metres spare to play with.
Thanks
Posted : 18/09/2016 10:16 am
might be only a 12v stat. still has insulation on the cores anyways
