Axis, joystick or d...
Axis, joystick or diablo?
10 Users
As a helmet light to supplement my six-pack.
My old axis has died and is unrepairable sadly according to exposure.
Replacement would be one from their 2024 range.
Posted : 07/11/2025 4:42 pm
Don’t know if any use but I have a brand new Joystick MK15, in silver, with helmet mount, that I haven’t ever used and am unlikely to do so, happy to sell for £100
Posted : 07/11/2025 4:54 pm
Not Axis. I've got one and it's not as good as the two joysticks
Posted : 07/11/2025 5:12 pm
Don't forget to look at the zenith as well.
Posted : 07/11/2025 5:50 pm
I've had all 3. IMO the MaxxD pairs best with the Joystick and the Six Pack with the Diablo/Zenith
Axis was a bit meh with the MaxxD and lost with the Six Pack
DONT forget the 18% members discount!
Posted : 07/11/2025 5:55 pm
Exposure no longer make the Axis, just the Zenith, Joystick and Diablo.  FWIW, I prefer the Axis (Mk10) offroad with my MaxxD.  It has just slightly more punch in the centre and a little more flood for the corners.  than the MK16 Joystick I have.  On the road, with an SB Activ, I can't tell the difference between the Axis and the Joystick.  There's a little more flood from the Axis, but it's not much and just blends in with the flood from the SB.  The new NK18 Joystick seems to have a bigger deeper lens, so may have more punch, but still be pointy.
Posted : 07/11/2025 6:30 pm
With the lesser power of the Toro, I’m really liking the flood beam of the Diablo. It naturally extends out from the Toro beam as I move my head to go around corners. There isn’t really a hot spot, there’s just light where I want it.
I nearly got a Joystick or Axis, as I’m a big fan of the extra distance a spot beam reaches on the road. But after trying with the weaker Link+ light I already had for the road, I found a spot harder work off road - it’s better to see a wider area to pick the best line, rather than search for it with a spot.
To run the Diablo bright you really need a support cell though, unless you are doing very short rides. But these look like they might be discontinued - and don’t work with the 2026 lights, although presumably you can use a power bank. The Joystick has a bit of an advantage for battery life, as it’s giving out less light - but appears brighter in the distance as it’s a spot not a flood.
On my 2025 Diablo I really like full power for anything technical or fast, then 1/3 power is a useful level for everything else. From the specs, I don’t rate the brightness choices USE have made for the 2026 helmet lights. To get full brightness on the Diablo, the second mode is 1/6 as bright, which I reckon might be too big a drop. The other modes get 1/3 power at best, then drop to very dim. Great for riding through the night, not so useful for going out for a few hours maximum.
Posted : 07/11/2025 7:46 pm
I’ve just bought the latest joystick and there’s a weird blue light dot in the middle of the beam which my previous versions didn’t have - not sure if its due to a change in led/lens, but it’s not as nice a beam pattern.
Posted : 07/11/2025 7:54 pm
I have a Joystick and manage it's battery fine during night rides (don't have it on all the time). It's spot compliments a Maxx D perfectly.
My mate with a Diablo moans about it's poor battery life
Posted : 07/11/2025 11:35 pm
Just popped my brand new Joystick Mk15 on the classifieds if any use to anyone.
Posted : 08/11/2025 9:44 am
I'd go with the lightest (weight) one. Hated the weight of the Diablo; not keen on the weight of the Joystick but find the Link ok... but that's only ok for being seen and not to actually see with!
Posted : 08/11/2025 12:02 pm
