autocad experts
[Closed] autocad experts
5 Users
Hi,
I have been sent an autocad 3d model ? of some structural steel.
I want to convert each of the beams into 1 single line ( ideally the centreline of the beam). I do not really know how autocad works and when i zoom in the is not a centreline within the beam section, only the lines that make up its edges (hopefully you follow).
Is this something that can be done ?
i can get access to autocad 2007 to do this (if it is possible)
Thanks
Posted : 08/01/2012 12:51 am
 kevj
Hmm. Sounds like this is a genuine 3D model and not a series of drawn lines to depict the flange and web.
Do you need your version to be in 3D too or do you wash to work from a flattened 2D model?
Posted : 08/01/2012 7:26 am
From my experience if it can be done AutoCAD will do it, but if you don't know your way around AutoCAD you might as well go bang your head against a wall; it'll be more fun.
Most unintuitive software I've seen... You really need a lesson or two.
Posted : 08/01/2012 8:10 am
Email me the model & I'll have a look for you.
Address in profile.
Posted : 08/01/2012 8:16 am
If there is not a centreline through the beams already you will have to add it to every beam. There could be a layer of centrelines which is simply turned off. Turn all your layers on, you may just then have to turn the beam layer off.
Posted : 08/01/2012 9:43 am
Yeah, my head hurts from banging it on the wall.
I should learn how to use it really, but can't afford to buy it.
I used to use a program called choicecad. Simple as you like !!
I turned off the layers and didn't see any layers for a centreline. So how does 3d autocad work then?
Do you select a beam profile and pick 2 points it goes between ? Does that beam then have properties ( i.e beam size / length etc). Could you select all parts in a 3d model and produce a list of beams (like what you could do in 3d detailing software like Strucad.
Any thoughts
Posted : 08/01/2012 11:25 am
Thanks Takisawa2
Have emailed the 3d model to you
Posted : 08/01/2012 11:27 am
revs, there were a lot of layers. All locked. The beams types are each on their own layer. There is a red layer called Centrelines, & one called Wireframe thats some of the centrelines also.
I've saved it with them all unlocked & sent it back to you. Let me know if you need owt else. Cheers.
Posted : 08/01/2012 1:07 pm
Many thanks
I am out and about at present, but will take a look as soon as I get home.
Thank you for your help
Posted : 08/01/2012 3:26 pm
