Astra 1 and 2 - Dua...
[Closed] Astra 1 and 2 - Dual LNBable?
4 Users
Rather than have two dishes are these two satellites (19.2E 28.2E)
close enough for a dual lnb setup?
Posted : 25/05/2012 7:18 pm
by dual LNB do you mean 1 LNB with two o/p's or two separate LNB fitments?
If the second it is possible.
Never seen it on a standard sky dish but have on larger dishes.
Posted : 25/05/2012 7:45 pm
Sorry, yes, two separate lnbs. When you say larger dishes do you have an idea what the minimum size might need to be? Think mine is only 50 to 60cm.
Posted : 25/05/2012 7:49 pm
sorry I might have missed something..
those two sats are 9 degrees apart are they not?
I would be very surprised if one dish could get both, and would be fascinated to know how its done if it is possible on one dish!
Posted : 25/05/2012 7:54 pm
It may work with a smaller dish though i've never seen it tried, i've only seen it with 80cm plus dishes.
You might get it to work with a smaller dish but I imagine you would have to be very accurate with the positioning of each LNB.
Have a google, there is a fair bit of info out there on how to do it.
Posted : 25/05/2012 8:28 pm
well it looks like it can be done.. there you go.
You'll have to shift your dish a bit though!!
Posted : 25/05/2012 8:48 pm
Yes it can be done
I used to do lots with a 6° spread
There's some DIY stuff here - some a bit more professional than others
http://www.satcure.co.uk/tech/dish_xtra_LNB.htm
Posted : 25/05/2012 9:12 pm
Posted : 25/05/2012 9:16 pm
Great! Thanks Jota. Since toying with the idea I've now found that to get to Astra 2 I've got a row of oak trees to penetrate. Doh!
Posted : 25/05/2012 10:50 pm
