Anyone used Cold La...
[Closed] Anyone used Cold Lay Tarmac?
10 Users
 lcj
I have a steep driveway down from the road to my house which transitions to a flat car port. The departure/arrival angle between the slope and the flat is sufficiently steep that the nose of my car rubs on it, meaning I can't use the car port at the moment. I want to make the transition a bit more gradual, and was thinking of using cold lay tarmac (like this https://www.wickes.co.uk/Tarmac-Instant-Lay-Macadam---Major-Bag/p/220017) to do that. The ramp itself will be about 7ft wide, and 1ft deep, maximum height about 4-5 inches.
Has anyone used this stuff, and is it up to a job like this? It seems to be used more for filling small potholes, and I'd rather not have it breaking up and being useless after 6 months!
Thanks!
Posted : 31/01/2022 1:07 pm
If you just lay it on top of what's there it'll rip up in no time you'd have to dig out what's already there and lay on the Sub-base, for the width of your ramp. Thats likely to be quite a few bags of coldlay
Posted : 31/01/2022 1:13 pm
I would use ready mix concrete, company you order it from will work out what volume/type you need.
Simple wooden shuttering frame to pour into and tamp down and your done.
Posted : 31/01/2022 1:20 pm
 lcj
Thanks both - good suggestions and much appreciated. Time to investigate concrete (why didn't I think of it?!)
Posted : 31/01/2022 2:11 pm
I used Coldplay on my drive kerb. The transition from road to kerb had a very abrupt dip and then a steep dropped kerb. Wasn't doing my suspension any good. I laid a couple of bags of Coldplay and then rolled with my garden roller. Sealed with a spray can. Still going after a couple of years.
It is only about 4 inches deep probably. 1 foot wide, 10ft wide ish
Posted : 31/01/2022 9:26 pm
Thats how all their songs feel
Posted : 31/01/2022 9:30 pm
Frigging autocorrect 😀
Posted : 31/01/2022 9:51 pm
12 inches deep is too deep for tarmac. It will come up and degrade
Posted : 01/02/2022 7:39 am
The usual depth is 25 mm
Posted : 01/02/2022 7:41 am
With concrete and it being steep, look into the right technique to do it so it doesn't end up shifting downslope and cracking while drying.
Posted : 02/02/2022 12:07 am
I like the idea of laying down Coldplay as a drive!
Posted : 02/02/2022 8:35 pm
Wooden bearers to shallow the angle.
Chemfix them in place
Or trailer ramps, possibly backed with scaffold boards, again drilling 3in into the slab and chemfx in a stud
Posted : 02/02/2022 10:50 pm
Wasn't it a bit yellow?
Posted : 02/02/2022 10:54 pm
