Anyone use the BBC ...
[Closed] Anyone use the BBC radio player app?
10 Users
And had it constantly pause then play again? Doesn't matter whether I'm on Android or ios I can't seem stop this happening. Sometimes it's worse than others but at some point it starts happening again. Tried deleting and reinstalling but makes no difference.
Posted : 22/10/2015 1:27 pm
No issue here unless someone is hammering the local network downloading pr0n.
Posted : 22/10/2015 1:29 pm
Happens a lot to me to.
Posted : 22/10/2015 1:30 pm
I get it on long downloads. I downloaded that 8 hour "Sleep" thing from radio 3 the other week (still available for a few more days I think, highly recommended) and it does it there - pauses for a second or so then resumes. As a download it can't be anything to do with network speed or owt, can it?
Posted : 22/10/2015 1:32 pm
 jb72
When does it happen? - that will happen if I'm streaming while in the car. I'd put it down to the mobile network being unreliable - it has improved a lot now I'm on 4G.
I'm starting to like the new app more - especially as you can download everything. I download most stuff before I listen to it now and it never stutters.
(Android)
Posted : 22/10/2015 1:38 pm
 DrJ
[quote=loddrik ]And had it constantly pause then play again?
Yep. Sometimes starts again. Sometimes doesn't. Sometimes works again if I quit the app and start it again.
Posted : 22/10/2015 2:20 pm
Cant say i get any problems with download stuff or with a good 4G signal. With a poor/average signal you can sometimes get jumps when its trying to get you back to the 'live' broadcast if it thinks you are a bit behind. I think thats likely what most people are experiencing.
Posted : 22/10/2015 2:25 pm
I have had this too. I mentioned it in a feedback form one time when it crashed and it has got much better lately.
Posted : 22/10/2015 2:36 pm
If you're on a 3G network, then it will keep doing it, especially if the network is in a busy area, because it has to keep buffering. It's a lot better with 4G, but even then if it's busy it'll drop into 3G and you'll get buffering. Where I work falls roughly into the overlap between cells, and it's on a very busy industrial estate with a bypass on one side and large housing estates all around, so 4G will be fine for a bit, then just drops suddenly into 3G, and the radio will just go quiet while it buffers. Sometimes it'll run on 3G, but it depends on signal strength.
Posted : 22/10/2015 6:20 pm
Nope. Happens over wifi. Pretty fast wifi too.
Posted : 22/10/2015 7:36 pm
had this the other day for the first time!! - it was a 15-20 second loop, repeated about 20 times - would have been more but my plan to annoy the missus was working too well.
Posted : 22/10/2015 7:42 pm
