We've got a Myson kickspace - when the central heating is on it's supposed to blow hot air - but it's stopped working and now only blows on the cold setting - I've tried bleeding it but no joy - any other suggestions (apart from get rid which I would do except it's the only heating in the kitchen)
No expert but I think you could replace it with an electric one? Has the benefit of being able to use it when the central heating isn't running.
Do you know if the hot CH is getting to the heater ? Does it get hot but not trigger the fan ?
Thanks - need to drag it out to have a proper look - would rather not go electric as it seems daft not to make use of the hot water in the GCH - I wonder if the flexi pipes have got blocked or collapsed inside
Or it could be the thermostat
