just need something checking..
y=(x^2)(e^3x)
find the equation of the tangent when x = 1
i get dy/dx as (3x^2)(e^3x)+(2ex^3x) which gives the gradient as 5e^3
then sticking x = 1 into original equation, you get e^3 = y
y = mx + c
e^3 = 5e^3 x 1 + c
c = - 4e^3
y = (5e^3)(x) - (4x^3)
i think its right, but not quite sure, just got a feeling something might be wrong.
How many thousandths in an inch ?
I dont know, there must be millions of them!
or as some tool i went to school with once said while watching superbowl:
"how many quarters are there?"
6.
No clever people on today then.. 🙄
Once painfully witnessed two girl shop assistants trying to work out 15% of £1. Took them about 5 minutes, and they still had their doubts.
Does is not go like this
y = uv
dy/dx - u.dv/dx + v.du/dx
Now y = (x^2).(e^3x)
So, dy/dx = (x^2).(3.e^3x) + (2x).(e^3x) { I think the dy/dx of y = e^x = e^x and if y = e^3x then dy/dx = 3.e^3x}
= (e^3x).(3.x^2 + 2x)
= x.e^3x.(3x+2)
Substituting x = 1 gives
dy/dx(1) = 1.e^3.(5x1 + 2)
= 5.e^3
Then the y = mx + c bit gives the same answer as you. So I agree you are correct.
Gary PhD, MSc, BSc :roll:. I am probably completely wrong its close on 25 years since I finished my first degree!
Alright cool cheers.
In my day we had to work this sh*t out ourselves 😆
alright grandpa.. 😉
I think GJP is right. So are you. Assuming you mean 2xe^3x rather than 2ex^3x in the second bit.
Are you doing AS level maths? I am learning differentiation at the moment
no, just finished as, on to a2 now. also doing as further and a2 further (all in one year..)
good luck 😉
your working looks right, but since ive only just learnt this i couldnt be sure
Realman - I wasn't trying to confuse you or lead you to believe your calculations were incorrect. I found it easier to work through it myself and only at the end did I realise we had done the same thing.
I am confident this is the right answer - the only thing I wasn't 100% sure on was the first derivative of e^3x ( I was a seriously sh1t hot mathematician in my day - if there is such a thing!)
Good luck with the studies.
Gary
All i know is soon as you leave school/college/uni it will be the last time you ever need this!
Used to get stressed about this myself but never needed it since!
🙁 😕 🙂 😀 8) 😆 😉
I spent years and years learning this stuff and I can honestly say that none of it has ever been of any use to me whatsoever. I always hated maths anyway.
Then again if you get an engineering degree and then don't become an engineer I suppose that shouldn't be so much of a surprise.
I believe the answer to be y=e^3(5x-4)
Edit: Check your original post, you have the constant c as -4e^3 yet in your final answer you have it as -4x^3
I'm sure this is a typo and what you meant is the above answer.
A tip though: Don't use y=mx+c any more, use y-y1=m(x-x1)
Although using y=mx+c is ok for these questions once you start doing harder ones especially if you are doing further maths ( Fp1, Fp2 and Fp3) it makes it easier for you.
Of course it depends on what they were working out - if it was simply 15% discount, then fair enough, it is easy. If she was trying to work out the VAT (at 15%)element of something with a value including VAT of £1 then fair enough, it does take a little calculation (read calculator 😉
