Any Sky/satellite t...
[Closed] Any Sky/satellite telly installers in?
7 Users
I want to move the entry point of the Sky cable from one side of the room to the other. It would mean, I guess:
- taking the end connector off the existing cable
- pulling the cable out of the the existing entry hole
- extending the cable (how do I do that?)
- running it round the external walls
- drilling a hole at the new entry point
- poking the cable through
- putting the end connector back on
Have I missed anything? Anything I need to watch out for?
Alternatively, any Sky fitters in the Chelt/Glos/Ciren/Swindon area fancy a bit of, ahem, 'freelance' work..?
Posted : 29/07/2015 7:28 am
Rather than have a join, I'd buy a new length of cable and run it from the dish to where you want it to go.
Posted : 29/07/2015 7:39 am
second the new length of cable, cable is cheap enough and joining it would be a cludge.
Once you have the LNB open its obvious how it connects.
Posted : 29/07/2015 9:19 am
You phone them up and ask them to push a bit more through from their end.
Posted : 29/07/2015 9:22 am
[i]You phone them up and ask them to push a bit more through from their end. [/i]
Yeah, very good, I'm not that stupid. That's cable telly.
[i]Once you have the LNB open its obvious how it connects. [/i]
Brill. What's an LNB?
Posted : 29/07/2015 10:10 am
The bit the wires go into on the dish (low noise block)
Posted : 29/07/2015 12:11 pm
All you'd need to extend the existing cable, if you don't fancy climbing ladders etc to replace the whole cable, is an F type barrel and a couple of F type connectors. The F type connectors just screw over the sat cable once you've stripped some of the insulation off. You'll find em at Amazon or eBay. Only a couple of quid. Then join with the barrel. No special tools required.
Posted : 29/07/2015 12:20 pm
New cable preferable, you can do this yourself fairly easily,
Things to think of are:
You'll need some self amalgamating tape - this is fairly expensive usually but worth it - if you drop me an email actually I can stick some in the post. You don't need much but it's essential for sealing the f connector at the lnb. You just stretch it around the join and it'll prevent water ingress.
Same applies around the f-connector join, if you go down that route (but I wouldn't bother as others have said - it could work, but you'll be annoyed if you've wasted that money on the cable and it's losing too much signal).
An f-connector fitting is easier than a normal RF lead - have a peek at the existing one and it'll make sense - don't have a single strand of the outer touching the inny bit though as it'll attenuate and bugger the signal up.
When you drill hole, drill in > out (sorry, probably obvious).
Also when you feed the cable into the hole, make sure to add a drip loop, so basically you make sure that the cable goes north into the hole - so any rain doesn't drip down the cable and have a chnace of getting in to your hole *s*****
Stick some stuff into your hole to seal it up. *guffaws*
Actually, I've still got a fair amount of CT100 cable left from when I ran my new aerial in at home, so if you're near W.Yorks you're welcome to some.
EDIT: Sorry, just seen your location. Still drop us an email if you fancy some of the tape (you definitely will need it one way of t'other)
Posted : 29/07/2015 12:28 pm
