I need a new front plate fitting to an existing socket and a new double socket installing - an idea of a ballpark figure?
(Oop north in Manchester)
£120 would be about right
If you just want to convert a single gang to a double gang you can use on of these
More info [url= http://www.theukhighstreet.com/Volex-1-To-2-Gang-Socket-With-Outboard-Switches_PDBandQ5010620047984 ]here[/url]
You can also convert a double to a triple gang. I think that they are a little deeper than a normal plug socket.
Whereabouts are you based? My mate is a mountain biking sparky, based on the Manchester side of the Peak, if you're not too far away, I can put you in touch.
It really does depend on where your new socket is going and whether you want it surface mounted (using mini trunking) or chased into the walls and made good afterwards.
Without seeing it, very ballpark £150
Thanks all.
Badly Wired Dog - I'm in Streford, could I get your mate's number? Might be a too far away but doesn't hurt to ask.
(email in profile)
Another question.
Assuming the new socket is fitted as a spur and that's really a glorified extension, can anyone see a problem with me using a single gang heavy duty extension cable placed in trunking and daisy chaining a short multi gang thingy off of that?
The extension would 4 to 5m long.
It's in a bedroom so would have things like a lamp, tv, booster aerial, dvd, speakers etc plugged in.
20 quids worth of bits and an hours time for the spark as long as you make good say max 80 quid in central manc in rochdale more like 60 all in..
