Any caravannists in...
[Closed] Any caravannists in? 12v/240v question
2 Users
Staying in a caravan for my current work contract. There's a 12v circuit switch inside, CAR/OFF/VAN, plus a battery health meter. I think there's also some kind of 240v to 12v charger/converter. I'm hooked up to site electrics and all 240v sockets & equipment work. 12v only works if I have the switch set to VAN. I thought the convertor meant I could leave this in the OFF position?
The charger/convertor appears to be doing something. When not connected to site electric, battery health meter shows just into the green. When connected to site electric, battery health is 100% green.
Any ideas? Am I supposed to have the 12v switch set to VAN even when connected to site electric?
Posted : 07/09/2015 8:36 am
Leave the switch on VAN.
Off is just to isolate all your 12v stuff. Van means your 12v stuff is being powered via the leisure battery acting as a rectifier from the hooked-up charger which is how it should be.
Car usually means that you are using the "starter" battery in a motorhome/campervan as a back up because your leisure battery is borked.
Posted : 07/09/2015 8:48 am
Cheers. I was terrified of leaving it on and having the whole thing burst into flames while I sleep.
Posted : 07/09/2015 8:55 am
