Any brickies in? ho...
[Closed] Any brickies in? how much to brick up kitchen door?
4 Users
Does anyone have recent experience of costs with regards to removing a standard sized back door and bricking it up?
We want to remove the current 'back door' which is on the side of the house as we are fitting a bi-fold door in place of a bedroom window on the back of the house (bungalow).
This will free up more kitchen space, eventually a full height built-in fridge freezer will be sat where back door once was.
Its a standard 60's build, nothing unusual about the exterior brickwork, so I imagine would just need inner and outer walls filled in, maybe some cavity insulation, and a quick slap of plaster on inner wall?
I'm guessing 2 days solid work plus materials? So perhaps somewhere around £1000-£1300?
Posted : 25/11/2015 12:01 pm
Id sub contract the removal of the back door to hora personally.
Posted : 25/11/2015 12:08 pm
I'd get any brickwork in the doorway removed so you have a proper cavity all the way across, not the original brickwork providing a thermal bridge between the inner and outer brick courses.
Could be messy if they have to cut any brickwork away with a grinder.
I'd give myself two days and expect a professional to do it in a bout 1/2 to 2/3rds of that.
Posted : 25/11/2015 12:13 pm
I'd estimate 2-3 days to remove, put in internal wall + insulation, plaster over, add skirting, make good.
Depending on local rates, £600 - £1,000 + materials.
Posted : 25/11/2015 12:26 pm
