Any auto electricia...
[Closed] Any auto electricians here- weird lights problem
6 Users
Or not.
When I turn the headlights on on the van (Bongo), they're ok for a second or so, then dim to a very faint glow, on both sides. High beam is fine though. Anyone got any ideas?
Posted : 26/08/2011 11:51 am
 ibis
poor grounding
Posted : 26/08/2011 11:55 am
As Ibis says, poor grounding/earth would be my first suggestion.
Posted : 26/08/2011 2:09 pm
 momo
Sounds like an earth fault, check the bulb holders for contact and give them a clean with some wet and dry.
Posted : 26/08/2011 2:25 pm
Take the bulbs and holders out of the headlamp, clean the contacts and if any corrosion, use some fine sandpaper to remove it. Check any earth points in the engine bay and again clean any corrosion off them.
Are they HIDs or anything fancy?
Posted : 26/08/2011 2:54 pm
 Taff
Had this with the rear lights on the 306. Cleaned the contacts and they were better. Sometimes it's easier to put in an extra earth
Posted : 26/08/2011 2:57 pm
