Another Zwift Quest...
[Closed] Another Zwift Question, HRM AND iPhone
4 Users
I have gone from using a laptop for zwift to using my iPhone. I stopped using the laptop because of the constant freezing mid ride. So the HRM is a CooSpo Heart Rate Monitor Bluetooth ANT+ which is BLE4.0.
My trainer connects straight away but I can not pair the HRM however I try. Batteries are fine. It bleeps once fitted but the iPhone ignores on the zwift app even though it shows up connected on the Bluetooth settings .
Anyone else have this issue and how did you resolve it.
Posted : 08/02/2021 5:01 pm
What trainer is it?
My coospo works well with Apple TV box and tacx flux
Posted : 08/02/2021 5:10 pm
The trainer is a Elite Directo XR
, this connects faultlessly. The iPhone is not recognising the HRM when using the Zwift app even though the phone shows it connected.
Posted : 08/02/2021 5:21 pm
Are you manually pairing it with your phone first? I vaguely recall that’s not the way. Try deleting it from your phone’s Bluetooth settings if so, then load up Zwift and try to pair it from there.
Posted : 08/02/2021 6:17 pm
My understanding is you can normal only pair two device together with BT
ANt+ allows multi pairings as does Apple TV with BT
Good luck
Posted : 08/02/2021 6:30 pm
@Ro5ey I’ve had BT trainer, cadence & HRM all working with Zwift on iPad before.
I think AppleTV has a 2-device limit for whatever reason, but this is arbitrary & doesn’t affect iPhone/iPad AFAIK.
I think you need to pair it with Zwift app tho not directly with phone.
Posted : 08/02/2021 6:37 pm
