Amplifiers- biwirin...
[Closed] Amplifiers- biwiring and biamping help!
12 Users
Hi,
I've got some;
6ohm Wharfdale Diamond 9.1s
Chord Carnival Silver Screen bi-wire cable
An older Denon amp/receiver (sorry not sure of model!)
Its currently bi-wired, but i'm instrested in biamping- the Denon has two speaker channels, A + B and so I thought I was sorted- but on the back of the amp it states;
A or B = 4-12 ohms
A + B 12= 12- 16 ohms
So, I can't use both channels successfully can I?
Posted : 15/08/2013 4:01 pm
Using 2 sets of speaker terminals from one amp into one set of speakers is not really bi-amping - all it will do is possibly make your wiring a little easier.
To bi-amp properly you need two power amps or an integrated and a power amp and they ideally be matched so usually a pre amp and two matched power amps is best.
Regarding bi-wiring there is a train of thought that it is of little or no benefit. I run a single pair of cables to each speaker and use a high quality jumper lead in place of the usual piece of metal they give you to bridge the terminals.
Danny B
Posted : 15/08/2013 4:17 pm
Cool.
I've got both single (QED Silver Anniversery) and bi-wire cable so I may try the upgraded jumper option at some point
Posted : 15/08/2013 4:27 pm
I've always though bi wiring was a bit of Hi-Fi snake oil.
I could never hear a difference.
Bi amping on the other hand is worth while, but you do need another amp
Posted : 15/08/2013 4:34 pm
Depends on the gear tho... My amp seemed not to like the load of just a tweeter and the sound was strident.
Posted : 15/08/2013 4:38 pm
Yet to see any real science to explain biwiring, its just a sales gimmick IMO.
Posted : 15/08/2013 4:51 pm
Dunno, the capacitance and resistance presented to the amplifier must both change a little with biwiring.
Posted : 15/08/2013 5:02 pm
I bi amped using one amp with two channels. Defo found it better
Posted : 15/08/2013 6:21 pm
I heard a difference when bi-wiring. I cannot explain it with science. The most obvious change was that I bought a second cable run which was different cable, and when I changed which driver the good cable went to, it was extremely obvious.
However bi-amping even with cheap kit made an even bigger difference.
Yeah, I thought something along those lines.
Posted : 15/08/2013 6:40 pm
Biwiring seems to ignore the fact that the wires are attached to a single pair of terminals, to which are attached another pair of wires inside going to the crossover board. In order to work, surely there would need to be separate terminals on the amp for bass and mid/treble, with the same on the speaker, with the internal wiring set up to match?
It all sounds too much like all the voodoo attached to the old vinyl crowd; not wearing digital watches, or having unpowered transducers in the listening room to avoid affecting the overall audio experience.
Posted : 15/08/2013 6:45 pm
Yeah I'd agree, but I can't see how it can be beneficial, rather biwiring makes cable inductance and capacitance important, single wiring less so.
Posted : 15/08/2013 7:15 pm
Just how do you "bi-amp" using one amp??
Ive listened to a set of kef speakers that where intially singlewired, then bi wired and then bi amp'd.
To be honest there was no real difference between single and bi wiring.
However the difference between those two and bi amp was truly astonishing !! quite a big difference for me !
Posted : 15/08/2013 8:12 pm
Use a stereo amp to drive a centre speaker in a home cinema set up
I've done it myself, works quite well
Posted : 16/08/2013 9:24 am
I'm a bit confused - or do you mean the amp had 4+ channels of
amplification. That's what I used, a 6-chan receiver, using 4 of them to bi-amp two speakers.
Posted : 16/08/2013 9:26 am
Well, there are two sets of terminals on bi-wirable speakers, with a removable bit of metal between them. If you remove the metal then the drivers are not connected together at all, but the filter part of the crossover still is. The speaker then does have one set of treble terminals and one set of bass terminals.
The amp has to sets of terminals for wiring convenience, but they are the same. Although the amp presents the same signal on its end on each set of terminals, the filter at the driver end only means that each wire only carries the current for that frequency range.
Posted : 16/08/2013 9:36 am
No you are still using one amp to drive one speaker??
Bi-amping is using two amps to run a set of speakers. one amp for the bass/mid range and the other amp for tweeter !
Posted : 16/08/2013 9:54 am
@renton - or one amp for each speaker. Some set ups sound better that way...
Posted : 16/08/2013 9:59 am
@renton - A stereo amp is just two amplifiers (one for each channel) in a single box - so using one to drive a single speaker is bi-amping.
Posted : 16/08/2013 10:01 am
I wouldn't and don't bother with bi-wiring. Maybe it will sound slightly different but if you spent time picking out your components then surely you would prefer the signature you spent that time getting to.
Posted : 16/08/2013 10:07 am
Nope thats wrong.
Bi-amping is the use of two channels of amplification to power each loudspeaker within an audio system. It differs from the conventional arrangement in which each channel of amplification powers a complete speaker. I.E one amp per speaker.
@dannybgoode...thats correct you can vertically or horizontally Bi amp a pair of stereo speakers.
Posted : 16/08/2013 10:13 am
@renton
I think we are talking cross purposes here (at least I hope we are)
You take a mono signal; input it to both channels of a stereo amp and then use the left to feed the woofer and the right channel to feed the tweeter. One mono signal source; one mono speaker. Two amps. Bi-Amping.
Sorry if I wasn't clear that's what I meant.
Posted : 16/08/2013 10:16 am
@stevehine...
Yep thats what I was trying to get across lol !!
Posted : 16/08/2013 10:19 am
Bi amping is sending the appropriate frequencies to the appropriate size driver (speaker)
You would need at the very least a passive crossover but much better an active crossover
for a bass bin in essence you need a device to filter all the high frquencies out so all the power the amp is sending to the 12"/15" driver (speaker) is the bass frequncies and is therefore that much more efficient
Posted : 16/08/2013 10:26 am
Yes, I'd forgotten that some speakers had that facility, but most speakers only have the one pair of terminals.
I think the bi-amping thing can get a bit blurred by the fact that you can have a system with a pre-amp, and a pair of monobloc amps, but each amp is driving bass and treble, so I guess bi-amped, but not how bi-amping is normally meant.
I have an old system like that; Logik DM101 t/table, Rotel RA820 pre-amp into a pair of Crimson power amps.
Posted : 16/08/2013 10:47 am
Yeah; I agree with CountZero and Plumber - if you are going to the hassle of bi-amping then ideally you'd do it with an active crossover before the power amps and then you could actually remove the crossover elements in the speakers entirely..
Posted : 16/08/2013 11:11 am
[url= http://singletrackmag.com/forum/topic/back-to-hi-fi-anyone-tried-bi-amping ]This has come-up before - there may be some useful info here for you rockthreegozy :)[/url]
Posted : 16/08/2013 11:16 am
They are not bi-wirable ones in that case. Both kinds exist.
I have only bi-amped because I noticed a Cambridge Audio power amp on clearance for £50 I think (it was faulty but I fixed it) and I thought I'd try it linked to my CA A5 integrated amp. Whichever range I used the power amp for ended up sounding FAR better than the other one, so I searched ebay and got a preamp and another power amp for £100 I think. Pretty good system for the money I reckon. I may have been lucky to end up with a system that suits the set-up, I dunno.
Posted : 16/08/2013 11:23 am
