Am I being thick? H...
Am I being thick? Help me find a radiator
7 Users
6 Reactions
I'm trying to source a boggo, 600mm high, type 22 radiator for a small landing area, but it needs to be fairly narrow, 300mm. I can't find anything narrower than 400mm, am I being dumb or do they not exist?
Posted : 22/11/2023 2:15 pm
Will a 600mm x 300mm rad be worth bothering with!?
The only really narrow ones I've seen are the tall thin ones and even the BTU of those is pants.
Posted : 22/11/2023 2:23 pm
Can you go taller?
Posted : 22/11/2023 2:35 pm
 5lab
Towel rail?
Posted : 22/11/2023 2:47 pm
Thanks all, but panic over, I think a 400m will fit, and they're easy to find.
Posted : 22/11/2023 2:55 pm
 5lab
a 400m will fit,
I hate it when people humblebrag about the size of their house
Posted : 22/11/2023 3:58 pm
bigginge, daviek, funkmasterp and 3 people reacted
IIRC 600 rads only go down to 400W - you'll easily get a 700x300 though
Posted : 22/11/2023 4:59 pm
You are going to end up with an odd size rad probably at least 1.6m high. I’ve had same issue and found a brush steel one at 270mm wide and 2m high for a shower room to fit in a recess. Choice below 300mm was very limited and very expensive.
No one makes boggo in those sort of sizes. Try specialised rads shops.
Posted : 23/11/2023 5:21 am
