Aluminium house rad...
[Closed] Aluminium house radiators are they worth it?
13 Users
I'll be replacing all of the radiators in the house very shortly I'm tempted by aluminium for responsiveness, efficiency?, lighter weight and maybe? a bit smaller for the same output
anybody got any real world experiences with them? Are they work the bit extra that they initially cost? or should I just stick to bog standard steel ones?
cheers
Posted : 05/03/2012 4:03 pm
They look cool, that would swing it for me.
I've never thought "OMG my steel radiators are responding slowly".
Posted : 05/03/2012 4:08 pm
 hora
It depends. I like the zing they have when heating and cooling and they have a great feel.
Posted : 05/03/2012 4:13 pm
Hmmm two extra good qualities, no negative but still not 100% sure they're worth the extra wonga on what is a tight budget.
undecided 😕
Posted : 05/03/2012 4:45 pm
Hmm, I've often found that steel is a terrible conductor of heat and often stays cold on one side when the other is in contact with hot water; so I'd say go for it.
Posted : 05/03/2012 4:54 pm
I installed ally one sin the barn.
Mainly because they were the cheapest way of getting ones that didnt look like they came from screwfix.
I got these
http://www.theradiatorcompany.co.uk/product_details/?catid=Mix
They work well, quickly, low volume, and convect well.
dont really have many pics of them
but we have 3 of them fitted with towel rails, esp the 1.8m tall one in the bathroom. Works as a radiator and a towel rail - which radiators and towel rails cant manage on their own!
Might take some pics some time.
p.s. diamond is the best heat conductor, so you'd be better off with diamond radiators really.
Posted : 05/03/2012 4:55 pm
Now that's sounds more convincing cheers
I did sized up everything we needed last night and did a price comparison last night between steel and ally
result was £1035 for steel and £1350 for ally
steel ones seem way way cheaper than ally for the conventional shape ones (Long and low) but a bit more expensive for upright ones.
We decided to go for about 50/50 between uprights and more conventional shaped ones so the price difference isn't as big. If you went for all conventional shaped ones throughout the price difference would be much much bigger
The final decision was ally! 8) This has been approved by Mrs 29er 😆
Posted : 06/03/2012 9:01 am
lighter weight
How does this matter?
Are you planning on carrying it around the house with you to heat whichever room you're in at the time?
Posted : 06/03/2012 9:06 am
it'll be a hell of a lot easier for me to fit them on my own
Posted : 06/03/2012 9:18 am
Yeah but the fatigue resistance is lower so remember to check for cracks. And although ali is stiffer, the extra give of steel makes for a more lively supple ride. Steel is real!
Posted : 06/03/2012 9:42 am
glenh - Member
So carbon wins yet again 😀
Posted : 06/03/2012 9:46 am
Keith, 'ere you go. A pic of the tall one with towel holders on.
Posted : 06/03/2012 10:14 am
I did not know this. Is it really true?
Im assuming it isnt true of carbon as man from Shimano says here:
As for material, a carbon frame isn’t going to dissipate heat from the caliper any.
http://www.bikerumor.com/2012/02/14/road-bike-disc-brakes-are-coming-but-will-they-work/
Posted : 06/03/2012 10:17 am
Isn't it where they're positioned that gets the convection current going? E.g. under a window works better than on an internal wall.
Posted : 06/03/2012 10:21 am
Carbon fibres != diamond
doh, you know what I mean smartarse 😉
Posted : 06/03/2012 10:23 am
cheers for all of the helpful answers
😆 and 🙄 at the rest
Posted : 06/03/2012 10:27 am
the chilling of air at a window causes it to fall (convect downwards) whcih then creates a moving pool of colder air at low level. If you put the radiator on the opposing wall, it's rising convection will pull the colder air along the floor as a chilling draught. A radiator under the window is intended to counteract that falling cool air flow.
Air flow and heat transfer through the radiator is a function of it's design, fins and vents etc.
Old steel single panel rads are not very good. Modern double rads with fins in the centre convect well. Ive found my aluminium ones do too and I wouldnt be surprised if the funny design to the top of them is to help move the convecting warm air up and out into the room.
Posted : 06/03/2012 10:28 am
Stoner yeah we'll be ordering 4 very similar to those
I think I'll put the order in tomorrow from these guys
http://www.traderadiators.com/
Posted : 06/03/2012 10:29 am
yeah there are loads of funky shaped ally ones which look very much like that's what they're trying to achieve e.g.
Posted : 06/03/2012 10:32 am
Surely a radiator's ability to heat is defined purely by its BTU - an alu rad may be lighter, smaller etc, but what is the performance advantage?
Having said that I do like your stoner, but I couldn't see one like that on your website - do you have a link?
Posted : 06/03/2012 10:38 am
they didnt do a tall one in the Mix range so I had to get the Oscar
http://www.theradiatorcompany.co.uk/product_details/?catid=Oscar
IIRC aluminium radiators have a higher btu/Wattage /size than steel ones. You also dont get rust issues with Al. You need a different kind of inhibitor though.
Posted : 06/03/2012 10:41 am
Ah...so you can't mix and match?
Posted : 06/03/2012 10:44 am
dont see why not. you might just need to make a cocktail of fernox products 🙂 Fernox and the radiator companies would be the guys to ask.
Posted : 06/03/2012 10:45 am
Any issues with having alu and steel on the same circuit?
Do you need different corrosion inhibitor for alu rads?
I'll ask my services manager when he returns from the pastry van.
Edit - beaten to it!
Posted : 06/03/2012 10:47 am
Hmmm...
Where did you get the towel-rail-y things?
 Bear
Sentinel X100 suitable for all metals.
Posted : 06/03/2012 10:50 am
I'd guess that alu should be more responsive. heat up a room quicker, conversely it probably cools down quicker too after the boiler is off.
Posted : 06/03/2012 10:51 am
useful to know bear.
BTW, what do you do with large thermal store systems where you might have over a 1000 litres. It cant be cost effective to use inhibitor at the recommended concentration?
At the moment I have no inhibitor in my system because it would cost so much and I know I really ought to add some sometime.
Posted : 06/03/2012 10:53 am
OK my services manager says its OK to mix and match steel & alu, just get the right inhibitor.
Posted : 06/03/2012 10:54 am
There's a bay window in one of our rooms with a fairly low window sill, we can get a 5000BTU ally rad that fits perfectly but could only get 3200BTU from a double steel jobbie so would have needed an extra rad in the room else where or an expensive custom bay one
oh good point though I did have a small steel towel rad for the downstairs toilet, I'd best change that for an ally one too so we're 100% ally then
ahh cool cheers Al' looks might I might be ok with the little towel one that the Mrs wanted
Posted : 06/03/2012 10:55 am
