Alarm wiring help n...
[Closed] Alarm wiring help needed
4 Users
Need to replace some PIRs. The out going unit uses 4 of the 6 wire. Red and black and positive and negative supply as expected. The next bit is what has me a bit flummoxed though.
The first of the n/c alarm contacts has a single wire to it. The second tamper contact has a different wire to it. At the sides of the contacts are pins with resistor ratings along side them. The 4k7 pins are shorted with a plug in box next the the alarm side and the 2k2 pins are shorted on the tamper side.
Two unused wires are just cut back in the housing.
So far, I think I'm okay with this until I tried to replace them. The new sensors have 6 terminals, as you'd expect but if I want to set up a supervised system, I'll need to add some conventional resistors to the contacts. I'm just not 100% certain where to put them.
Can anyone help?
Posted : 05/06/2018 8:23 pm
Are the markings on the PIRs the same? If so, just wire exactly as before.
You are not clear about the resistors - are they soldered on the PIR?
If not, just reuse them.
What are the markings on the old PIR and new??
Black and red are usually wired as the 12v + & -, a resistor between + and Ta, and a resistor between + and T. Only 4 wires needed.
Posted : 05/06/2018 8:36 pm
You have end of line resistors which help tamper protect the circuit. Sounds like they are normally open .... Long time since I did this though.  Check out this article
Posted : 05/06/2018 8:37 pm
Yep, happy with the idea of end of line resistors, that makes sense. My problem is, with the current until and its pins instead of physical resistors, I can't see the actually connects of the 4k7 and the 2k2 resistors so that I could replicate them on the standard pir connector block on the new unit.
I'm thinking it should be alarm wire to alarm contact 1, 4k7 between alarm contact 1 and alarm contact 2 and then a 2k2 from alarm contact 2 to tamper contact 1.
Posted : 05/06/2018 9:25 pm
yep, you want one core coming to pin 1 of the alarm contacts, 4k7 resistor from pin 1 to pin 2 of alarm contacts, 2k2 from pin2 alarm to pin 1 tamper, remaining core into pin 2 of tamper.
Breaking tamper circuit will read an open circuit, everything closed will read 2k2, tamper closed but alarm open/active will read 6k9 in total.
Posted : 05/06/2018 9:51 pm
that's assuming the jumper pins on your old one are 4k7 alarm and 2k2 tamper, usually the jumper pins are on the same sides as the relevant terminals but always worth a check
Posted : 05/06/2018 9:53 pm
Cheers, thanks for that. 4k7 pins on the left, nearest alarm contacts and 2k2 pins in the right nearest the tamper.
Looks like I need to go resistor shopping.
Posted : 05/06/2018 9:57 pm
