Santa gave me an Aeropress go. Likely to be used in a bothy. Or maybe in a hotel room. Anyway. It came with paper filters. I see a metal filter us available. Better. Worse?
Any tips from users. Thinking the mug is fairly small. Brew strong and add hotcaater in bigger mug?
What? The mug is huge!
No advice on the metal filter sorry.
EDIT:
https://m.youtube.com/watch?v=kQ8wvUKa35E&feature=youtu.be
That was linked in a previous aeropress thread on here and is the method that I use.
I have the metal filter, it let's a bit more through than the paper but tbh that's no and thing imho, tbh though I tend to still use paper as I'm less likely to accidentally chuck it away and it's easier to clean, the mug size Is OK to me but I hate the shape
Like the look of the upside down method as per video.
Just use the paper, it's better than a metal filter for stopping bits of the ground coffee getting through. Not sure about the go but the regular aeropress you get 365 filters I think and they're only a few quid to replace with a new pack.
There are different grades of metal filter, you want the ultra fine, which looks like a mesh trapped within a metal frame, rather than just the fine, which is a metal disc with holes in. I find the ultra fine as effective as paper - and it’s reusable.
Inverted method definitely better imo.
I tried a metal filter, but it adds an extra layer of complication rather than just being able to pop the puck straight into the bin. You've got to remember to take the metal filter off. I didn't and it ended up at the bottom of the massive bin in the break room at work so that was the end of that.
I find the ultra fine as effective as paper – and it’s reusable.
The paper ones are so cheap that I can't see the relevance of needing a reusable one. They also have a smaller environmental footprint than metal will.
You don’t need to rinse a metal filter before you use it.
You can dry out and reuse the paper filters several times. Signed, Mr. Scrooge.
Is there any difference between the Aeropress models apart from the fact that one has a mug, another has a tote bag & the other ones just the press?
Fancying one for to take in the tin shed.
I use a couple of the paper filters each time,seems to brew a better, stronger cup.
For that purpose, you want the standard one not the go. Order from somewhere like rave coffee and you'll get a free bag of coffee with it
You’ve got to remember to take the metal filter off. I didn’t and it ended up at the bottom of the massive bin
Good point. I would almost certainly end up doing that. Just need to add a few paper filters to my camping odds and end bag and I'm sorted.
I use a go & made a cosy out of bubble wrap & gaffa tape, keeps it hot when brewing inverted outside.
Brew it strong & add water is the way to go.
I don't bother with a metal filter, extra faff and I broke it by being ham fisted😮
Paper filters here as well when camping, makes the cleanup pretty simple.
The metal filters also need regular cleaning with something like Puly Caff to remove the grot from it.
You will be surprised at how brown the cleaning solution can go even if the filters looks visually OK, it’s a strong alkali-detergent mix used for cleaning espresso machines so well suited.
I use paper filter, inverted method, whichever you choose remember to actually put a filter in before flipping it, it makes a mess!
Not just me, then!
The aficionado/snob will tell you that the paper filter absorbs more of the coffee's bitter oils, resulting in a smoother cup. As above though, the main advantage is quick and easy disposal of the puck without losing a crucial part of the apparatus.
LOL at reusing filters!
There's a reason why there's a schism between inverted and non-inverted in the aeropress world - neither technique is inherently better than the other.
I'd say it's worth experimenting with both to see which one you like doing (I switch between both based on mood).
Help ……
I’ve always used a small Moka pot, Lavazza coffee and modo mio milk frother, great coffee every time.
Just bought an Aeropress but there is no coffee taste. Tried normal and upside down methods, leaving for 2 minutes, etc….
Suggestions welcome 🤞
I've had best results from this method, was using inverted before but this is simpler.
He also has a (long) video explaining why he arrived at that method with some comparisons between different techniques.
Thanks for that @Kelron.
Tried it but still not doing it for me, think the Aeropress is probably heading back to Rave 🤷♂️
A finer grind worked wonders for the coffee quality for me. I used a delonghi burr grinder set on 2. Much finer than for cafetière.
Inverted must increase the concentration of constituents, since it eliminates the considerable initial drips. I found that made a difference too.
@nickingsley - when you talk about 'coffee taste' what do you mean? I'm just guessing here but if you've been enjoying Lavazza from a Moka pot I suspect you like your coffee on the bitter side. If that's the case then you can achieve some of that with the aeropress with a finer grind, bigger dose or longer extraction. It might just be that the Moka pot is the best brewer for your taste though!
Yeah I mean it's all personal isn't it? What is a good cup of coffee? What is the right taste?
I kind of have the opposite problem. I've used my Aeropress for well over 5 years now and as a result, I just cannot drink virtually any coffee served to me in any coffee shop I've tried, whether that be small independents, or large chain coffee shops.
It means that now 90% of the High street is off-limits to me.. 😂
It just tastes so dishwatery and bitter and tainted somehow.
Horrible.
Aeropress ruined my life...
Incidentally, I pretty much have always done it like that coffee video guy up there. I don't worry about grind size, temperature to the dot or anything. I just buy supermarket ground Italian style coffee and that seems to be really nice.
What I don't do that he does, is pointlessly brew it into an extra container, each one robbing your coffee of heat. By the time he's got it in that mug it must be tepid. That carafe can carefe-off.
I brew straight into a Thermos mug. Keeps it lovely and hot.
As above, aeropress has opened my eyes as to how bad a fair few coffee shops are. I do use as fresh a bean as I can which no doubt helps. I picked up an aeropress as a stepping stone to a potential espresso machine but after a lot of reading and YouTube watching, I won't be bothering and just staying with the aeropress. I will likely pick up a cafetiere for when I need to make coffee for a group
Just wanted to point out that the aeropress and the aeropress go is in the STW shop 🙂
Its also cheap on Pact Coffee at the moment but of course you would favour STW...
I generally like my hot drinks hot but it's surprising how many more complex flavours you can taste if you let coffee cool down a little
What I don’t do that he does, is pointlessly brew it into an extra container, each one robbing your coffee of heat. By the time he’s got it in that mug it must be tepid. That carafe can carefe-off.
For me if it's too hot I can't taste anything. Likely another thing that's a personal taste, but I would recommend as an experiment tasting the same coffee as it cools to see what different flavours you can pick up.
I can't imagine supermarket ground Italian style coffee has much flavour to give..... (Yes I'm being a coffee snob, this is STW)
When I first bought a metal filter, I thought I would still use paper filters for travelling for ease, but actually I find the metal filter easier. I don't have to remember to pack filters separately and keep them dry.
If you remove the filter cover with the aeropress upside down, without pushing the plunger out at all, you can slide the metal filter off leaving almost all of the coffee in the puck to be pushed out. Often I don't even need to use precious water to rinse it if out and about.
Be aware that if you get the Go, the metal filters Hannah mentioned (or at least the one I had for my original) are too thick for the Go. Personally I prefer the laser-cut discs anyway... horses for courses.
I can’t imagine supermarket ground Italian style coffee has much flavour to give
Well, it does to me. It's really lovely.
I use a heaped Aeropress scoop, and as I say, can't drink most coffee shop coffees in comparison.
I've made it the same for friends and they usually find it too strong.
Top tip small inverted coffee cold brewed, 1/3 coffee 2/3 tonic water and a squeeze of lemon, lovely:)
Timely thread, just run out of filters. Anyone got a cheap supply?
Standard Aeropress I think.
Thanks for the comments. I am sure there is something in finer grinding, hotter water, longer stewing and, perhaps most importantly, personal preference.
I was just underwhelmed by the lack of taste compared to my £4, 2 cup Moka from TKMaxx!
My son has decided he’ll sort the Aeropress as he’s on the ball when it comes to coffee gadgets back home with a separate grinder and a Gaggia Classic Pro …. Whatever one of those is?
Sorry I missed that before buying 😳
When is the go actually good? I have a standard aeropress that only ever really gets used in the van, the go would suggest I use it camping, but its way heavier than the wee GSI thingy I use now?.
I only bought a Go because after years of ferrying it to work and back, or forgetting to, I thought I could justify having a second. It's less annoying to pack, particularly in a frame bag, due to the lack of the pointy hex bits at the bottom. I never use the cup or the silicone cover. The folding stirrer which I thought was gimmicky is surprisingly useful. But really it's very similar to the original.
Wrote to Rave who advised a new method to use but find the inverted method left for 2 minutes is best. Think the Aeropress is pretty well limited to an espresso or with a little bit of milk on top before the taste is lost.
Also think the filter coffer supplied by Rave is pretty coarse compared to the standard Lavazza filter coffee, making it much more challenging to wring out any flavour.
Think it’s going to be heading back and sticking to the Moka pot.
Maybe the Aeropress is more portable but not delivering for my tastes 🙁
Bought a Jetboild Flash yesterday and now going to get an Aeropress - this is for in the work truck. Recommend me a small portable grinder - hand, battery, 12v (if such a thing exists). Ta
Porlex mini or if you are feeling flush one mate by knock
Well I got one from Rave, with some coffee included & I think I’m preferring it over the cafetière (as I’m learning & getting used to it). I haven’t tried the coffee that came with it as I’m finishing off the Aldi beans, which to me are perfectly nice. I’m using it invetertedly & find it easy to use.
However… If I was going camping (not likely whatsoever) or bothying (quite likely) I wouldn’t be taking anything as bulky as an Aeropress. Sorry but I’ll stick to my tried & tested Lyons coffee bags.
Cue some coffee nerd/geek to tell me I’ve got no sense of taste for using Aldi beans & Lyons bags! But hey, they float my boat. 🤣
Normal aeropress at home
Aeropress Go in the van. Lives there with the stove and other bits of kit
GSI ultralight java drip for overnight adventures on bike or foot
Sorry being a lazy bugger I have not read all of the thread.
After making 1000s of cups of coffee, I am replacing my aeropress.
Should I just replace it with the same again or go for the Go?
Going to order in the next 30 minutes.
Go makes three measures. And is more compact. If you regularly make four it won’t be for you. Otherwise they are the same. The pot and cover are little value to me. I like mine though and it’s a nice compact package. Will use on the narrowboat.
Many thanks, that is all I need to know. I will order the classic.
Ta
