Advice on sharpenin...
[Closed] Advice on sharpening axes
11 Users
Bought a new axe,only for kindling, it has a blunt sharp edges,what's thebest way to sharpen it?
Posted : 17/03/2013 6:55 pm
I use a wet stone (whetstone)
check out you tube for lots of vids.
Posted : 17/03/2013 6:57 pm
Get a fairly fine file, and use that along both edges to get an edge, which will be fairly rough, then a finer file, to take burrs off, then use a stone to smooth the roughness left by the files. A coarse and fine diamond coated sharpener will work as well.
That's the problem with cheaper, 'high-street' hand-axes, they usually have pretty poor edges to start with, and need quite a lot of work to make them usable for actually cutting stuff. A quality axe by Gransfors or Roselli will be practically shaving sharp from the start.
Posted : 17/03/2013 7:10 pm
If its really blunt then start off with a file
Then use a wetstone to get it really sharp.
You can strop it on a piece of leather to get a shave sharp edge
HTH
Posted : 17/03/2013 7:11 pm
You don't want it too sharp for chopping kindling in my view. A file will be fine.
Posted : 17/03/2013 7:15 pm
If its for splitting wood/making kindling dont bother to much there is an argument for having a bluntish edge on a maul as it causes the wood to fold and split easier. You should be using the weight of the axe to spilt if you are cutting/chopping wood sharpen away. I havent sharpened my hand axe since I got it 2 winters ago and it splits like hot knife through butter.
Posted : 17/03/2013 7:31 pm
I find it's best to make the working file strokes towards the blade edge. This breaks rule 1 - both hands behind the blade. I wear gloves for this. You might want to also.
Posted : 17/03/2013 7:50 pm
I agree RE the blunt maul, mikey, but not the kindling axe.
A good maul has weight and a flared head to help cleave. It doesnt need to be sharp to work well, just technique.
Splitting for kindling though i prefer to have a v sharp blade to be able to lightly take off small pieces of willow for the starter wood basket. To be able to be a bit cavalier about what angle you cut the log at it helps to have a sharper axe IMO.
Posted : 17/03/2013 7:54 pm
Grinder, looks cool whilst doing it as well 😈
Posted : 17/03/2013 8:40 pm
 JoeG
This has lots of info: [url= http://www.fhwa.dot.gov/environment/recreational_trails/publications/fs_publications/pdf/pdf99232823.pdf ]An Axe to Grind[/url]
I came across this as well [url= http://www.grandforest.us/TheAxeBook.pdf ]the Axe Book[/url]
Posted : 17/03/2013 10:13 pm
My kindling axe was blunt when I bought it, never bothered to sharpen it as it splits wood fine. AIUI That's how it is designed, as a wedge rather than a blade, so it forces the log apart causing a deeper split.
Posted : 17/03/2013 10:29 pm
JoeG, thanks for finding those two axe books, I've got the Gransfors one somewhere, but it's handy having both of those two as PDF copies on my pad.
Posted : 18/03/2013 12:50 am
bit off topic but i bought one of these for a community project (axes/mauls deemed to dangerous)
[url= http://www.mowermagic.co.uk/acatalog/SMART-SPLIT_The_Safe_and_Easy_Way_To_Split_Logs.html#aSMARTSPLITTER ]smart splitter[/url]
its the best kindling tool ever, well maybe aside from the pro hydraulic one i used a few years ago anyway...
Posted : 18/03/2013 1:41 am
