if anyone needs above help, locks, new doors, best security etc just, many years experience
Slammed mine on a bit of wood today- fekked up the wires on one side. Fixed that but gubbed the other side. Both now tangled.. May have detached the big spring letting it unwind itself in the process- is it going to be a major pita to fix?
Door closed and locked- still kinda useable thankfully!
any ideas on make of door mate mail me at jimbean1912@gmail.com
most springs can be reconnected , by undoing the grub screws on left hand side of spring bar that will allow u enough to refit the spring to bracket
Aye.. Guessing it needs wound up again to re-tension it before puttingbit back on.
Don't have a clue bout the make but it's all good- sure I'll figure it out after some tea and swearing..
Ta anyways.
Been there. Had a badly attached door fall out of the frame while trying to straighten it out, resulting in having to dismantle the cables and loosen the spring. If you straighten out the cables and re-attach them, it is actually fairly straightforward to re-tension if you know the technique.
I found this video very useful:
Cheers KCR!
What would you recommend security wise jimbean?
