I’m trying to upgrade my forks on my calibre triple b to 160mm. What’s the best second hand, best value boost fork out there?
Cheers.
Sounds likes an RS Yari is your friend here. Chassis and spring are the same as a Lyrik, but the damper is downgraded. Gives a decent fork that is usually available cheaply (ebay and pinkbike are good starting points) and can have the damper upgraded if you want to at a later date
What fork is on there currently? Can you change the travel on it?
It’s rs sektor boost. Set at 140mm travel. Had an older triple b with a manitou mattoc pro (that got nicked) trying to replicate that bike.
Oops wrong thread...
