Adaptive cruise con...
[Closed] Adaptive cruise control
43 Users
Is it any good?
I always use cruise control when I can,  but other people's inconsistent speed gets frustrating,  you catch someone up,  pull out to overtake and they speed up so you pull back in and they slow down again etc'.
In my head, ACC will be the bees knees. I think I should be able to "latch" onto the car in front and basically switch to autopilot!!
Posted : 09/05/2018 9:11 pm
Yes. It's not really necessary but another one of those things that reduce the stress of long drives.  Love it
Posted : 09/05/2018 9:17 pm
It’s bloody great.
Posted : 09/05/2018 9:18 pm
So does it work like i think it will,  speeding the car up and slowing it down (within a certain range?)
Posted : 09/05/2018 9:22 pm
 km79
Yes, it maintains the distance from the car in front.
Posted : 09/05/2018 9:24 pm
 rone
First time I've had it recently.  Like it a lot.
You specify a distance on my karoq.
I do wonder if my brake lights are coming on when it slows down?
Yes it keep the distance with VW you set that distance.
Posted : 09/05/2018 9:30 pm
I'm getting it on the next car
Posted : 09/05/2018 9:35 pm
Love it, but it's a bit slow witted when people change lanes into the one you're in.
Use it most on country A roads when in a bit of a queue. Pick distance, set to 60 or so, let it do its stuff.
On motorways I tend to use it in roadworks, or uber quiet stretches. I imagine with dsg or auto it'd be awesome.
Next gen stuff will be betterer.
My latest car is the first one with it, and I drove out of the dealership and straight home to read the manual..
And turned the thing off.
Then because I’m an inquisitive type I played around with it, mine you can set at 250mtrs max which is helluva distance really.. that’s quite some tech to see that far ahead.. as I found out.. so now it’s set at 80mtrs which is just enough for cars to pull in between me and the car if front. I can set it manually by driving at a distance and then tapping the lever forward and that’s it.. it’ll drive all day at that distance.
And now I use it a lot.. especially as I drive like a grandad in the slow lane, so I set it so I’m about 4-5 cars behind a truck and relax a bit.
My initial scepticism came because I just didn’t trust it, but I’ve done about 8k Miles with it now and it’s pretty darn good.
Worth upgrading to if you have the option.
Posted : 09/05/2018 9:37 pm
I had it on a MK7 Golf when they first came out as I was doing a lot of motorway miles and it made a huge difference for me in the slow road works etc where you can set a distance from the vehicle in front and not worry so much about watching the speedo.
Posted : 09/05/2018 9:48 pm
It’s better with DSG than manual
Posted : 09/05/2018 9:52 pm
We have it on some of the newer buses now, it’s really good.
the only (slight) criticism I could level at it, is that (this really only applies to buses) if you are doing 60 ish, you catch a truck up, which will only be doing 56mph, it slows you down, but not by much, and it does it so smoothly that you may not notice it happening.
I’m told that it will cut in and brake if necessary, but it’s never happened to me.
overall, I’m a big sceptic wrt ‘safety’ gizmos, but i have to say, it’s brilliant.
Posted : 09/05/2018 9:55 pm
Game changer. I had it in my GTD and I used it all the time.... even on twisty roads if I was behind someone. Mine was a manual so still had to change gear, but it switched itself off below 15 mph. If you have a dsg then it will stop you and the start you off also.
on my new car it was an option, so I specced it. Cant imagine driving without it now.
Posted : 09/05/2018 9:57 pm
A mate has it on his new 2.0 VW Caddy with DSG and it’s bloody brilliant, I’ve looked to see if it’s possible to retrofit it to my 2013 caddy highline with its basic cruise control but I really want a DSG equipped Caddy in viper green paint so I’d better sell a kidney
Posted : 09/05/2018 10:09 pm
Used it on a hire car for the first time today. Really liked it and will try and get it on my next car.
Posted : 09/05/2018 10:49 pm
Like it on our crv. But it can be a bit harsh on deceleration. Can’t just eas off. It has to SLOW. But I’m a fan. In a roadworks it’s great. Mine has three distance settings. Middle is best for most conditions.
Posted : 09/05/2018 11:59 pm
I have used it and find it brilliant, I set it at 70 on a dual carriageway and it kept me safe distance from car in front and brought me down to a standstill at the trafficlight controlled roundabout, then accelerated smoothly back to 70. The only thing that confused it was the signs on a smaller roundabout!!
Posted : 10/05/2018 7:02 am
VW one is good, (Passat dsg) quite intuitive once you get used to it and start to trust it. I like that it starts to speed up to your set speed when you indicate right to overtake a slower car.
Posted : 10/05/2018 7:36 am
DSG Passat with ACC here. Best feature of the car IMHO, and I’d not have another car without it. Some good points about it being slower to react than you are - car indicating into your lane for example, and you know you’ll have to slow, so I just knock the ACC off and let the car coast for a few hundred metres, before hitting resume again. With a DSG it will control speed fully, with the exception of pulling away from a standstill - get up to 5mph and the car takes over.
I’ve done three hour motorway journeys without touching the throttle or brakes before - quite unnerving to start with!
Posted : 10/05/2018 7:38 am
I've had it for a few years on my V70. You can specify how many seconds of gap to whatever's in front and it'll also auto queue to save rolling into the scenery when it gets slow.
On mine, rather than decelerate on throttle, it brakes though gently. I used it all the time until recently when I needed pads and discs all round at 60k miles.
It's really useful on longer journeys or in heavy traffic. I intervene a bit more now when I use it so it's not constantly on the brakes.
Posted : 10/05/2018 7:39 am
Another double thumbs up from me, it’s brilliant. As others have said with the DSG gearbox it’s almost like it drives itself on the motorway. Although the first time you let it take you from speed to a stop/crawl scares the living bejeezes out of you!
RM.
Posted : 10/05/2018 7:45 am
Have it on my Superb with a DSG box & lane assist. Also a fan, as a big commuter.
Posted : 10/05/2018 8:46 am
It's v good. The odd press on the throttle to over-ride occasionally makes it smoother on the motorway. eg you're in middle lane (not a hogger honest!) and slower car starts to pull in a safe distance in front but you know the CC will brake. Car passing you in outside lane so you need to pause for a couple of seconds before indicating and pulling out to overtake. So throttle press to maintain speed (and close gap slightly), pull out and off throttle for CC to resume at previous speed.
The get home from Yorkshire with as-few-a-touches-of-peddles game, makes 180 miles go quicker.
Have it on my Superb, it's OK on the motorway until people cut into the gap, then it becomes annoying. On A roads I just don't feel in control enough.
Posted : 10/05/2018 8:56 am
I use it in the Passat when my right foot is getting tired in motorway traffic jams; with DSG the car will just follow the car in front. If you stop, you've got to get it going again and if somebody cuts in you sometimes have to brake as the radar doesn't see more than straight ahead. It's not quite as good as a human because it doesn't see two or three cars ahead so tends to react a bit late but digitally connected cars will sort that out (same as the new digital trains they've announced today) and it won't be long before all vehicles are platooning on smart motorways. This slightly cheesy video explains how this already works for long-distance trucking in the USA: https://peloton-tech.com/
Posted : 10/05/2018 8:58 am
 rone
So does anyone know if it's actually braking? I.e my lights are coming on?
Posted : 10/05/2018 9:01 am
Work's Passat has it, I never bother with it, tried it a couple of times and just never felt it was solving any sort of problem, but then I never use standard cruise control either, my van doesn't have it.
Biggest gripe for me was it felt too much like 'autopilot', not just that I didn't feel fully in control but mainly that I could feel my concentration slipping when it was on.
Posted : 10/05/2018 9:05 am
So does anyone know if it’s actually braking? I.e my lights are coming on?
Yep - if it's braking then the brake lights come on.
RM.
Posted : 10/05/2018 9:11 am
Biggest gripe for me was it felt too much like ‘autopilot’, not just that I didn’t feel fully in control but mainly that I could feel my concentration slipping when it was on.
My new (to me) car has lane assist (but not ACC). That freaks me out in a similar way. You have to actively engage it i.e. when you start the engine it is off irrespective of when what state you left it in. I just struggle to imagine the internal conversation that would lead to you engaging it...."ok, I'm on the motorway doing 70 but I'm really tired so I better put it on unless I nod off and am unable to do this perfectly simple act of keeping the car between the lane lines". It's when I'm on a totally empty bit of road and have to change lanes for some reason (one of those bit of motorway where you have to be in a specific lane to stay on the motorway) and I don't indicate and it fights back and tries to stop you changing lane.
Posted : 10/05/2018 9:12 am
I love it. Most of my motorway miles are M25 (or the odd bit of M40 / M4 at busy times) so traffic is never going at 70. Just set the max speed and it maintains the distance you set. None of the "oh sh!t, way too close" moments. Traffic slows, you do to. Eases up, it gets back up to speed if there's space.
Just got a newer Golf and the ACC now seems aware of cars in the lanes either side - it won't undertake if a car in the lane to the right is going slower than you.
I don't find it reduces my concentration - it just frees up some brain cycles to get a better awareness of of what's going on around you. Can look further down the road and check mirrors more.
Posted : 10/05/2018 9:28 am
Friend loves it (new Golf) but has narrowly avoid a collision or two when he forgets his other car doesn't have it, just old school cruise.
That's more an indictment on him rather than the car.
Posted : 10/05/2018 9:32 am
Have it on my V60 (automatic gearbox).  Simply bloody brilliant.  It's got its problems (won't spot stationary traffic, limited braking force) but the benefits totally outweigh them.  You're still driving, but you can shift your attention much further down the road making for a smoother and safer journey.
On medium-busy motorways you can do a whole journey without touching the pedals, even with traffic jams, although on a quiet road at night you're better reverting to standard cruise control otherwise it'll jump on the brakes if you come up behind someone pootling along at 40mph.
Depending on the car / instrument layout you get a good overview.  My V60 shows you when it's tracking a car and displays their speed so you can judge your overtaking very easily.  If you do get stuck behind someone, flicking the indication on will cause the car to accelerate towards the one in front to make it easier to pull out.
Won't have another car without it (newer Volvos do the steering for you too).  But must emphasise that all this stuff is a driver aid and you need to be very aware of what it's doing, and intervening if necessary.
Posted : 10/05/2018 10:07 am
 dpfr
I like it but it does get confused by snow......
Posted : 10/05/2018 5:34 pm
I don’t find it reduces my concentration – it just frees up some brain cycles to get a better awareness of of what’s going on around you. Can look further down the road and check mirrors more.
This. I’ve used it on occasions, when I’ve picked up a car with it fitted, but never really got totally integrated with it, just down to driving so many cars, most without it, some with, and those slightly different versions, and when you drive three different cars a day, you don’t get a chance to really explore all the toys.
I don’t do enough personal miles to be that fussed about having a car with it fitted, and cost would dictate what my next car is, not whether it’s got ACC.
Posted : 10/05/2018 11:01 pm
 wool
On my GTI, Wouldn't buy a car without it now I use it all the time. It's is quite literally a life saver the brakes kick in quicker  than i can react if my foots not covering the pedal.
Posted : 10/05/2018 11:10 pm
It’s when I’m on a totally empty bit of road and have to change lanes for some reason (one of those bit of motorway where you have to be in a specific lane to stay on the motorway) and I don’t indicate and it fights back and tries to stop you changing lane.
I've got that - one of those things that made me go "cool!" when I discovered it but I don't find it that useful. I do turn it on when I hop onto a motorway or dual carriageway more as an extra safety net than anything else - most usefully, I find it encourages me to indicate every lane change, and I'd be quite happy if more people had it for that reason alone!
ACC, by the way, I'd be well up for - cruise control has made long journeys so much easier, ACC must be another step forward.
Posted : 10/05/2018 11:36 pm
 sbob
Thought I'd hate it.
Thought I'd hate normal CC.
Happily wrong on both counts. 🙂
Posted : 11/05/2018 12:40 am
You can't fault it's application, it is very good...the down side with any forward radar controlled gizmo such as adaptive cruise control and lane control is that the vehicle tracking for all four wheels must be spot-on.
Make sure you don't hit any big pot holes as you won't be able to get the radar and wheel alignment done at your local Quick-Fit, and you can't guarantee your main dealer will have the necessary kit to do the job either. There is every chance your car will be sent to a central service agent to get sorted.
Posted : 11/05/2018 6:45 am
And the cost to realign four wheels and a forward looking radar...in the region of £600 to £800 pounds.
Posted : 11/05/2018 6:46 am
 CHB
I have it on my Volvo V40. The adaptive cruise control (with Auto gearbox) is one of the best features introduced in recent years. I think the Volvo application is one of the best on the market as it uses radar AND cameras and also lasers for pedestrian detection, all in all very clever. Some other systems (eg BMW i3) are just camera based and therefore not as accurate at judging distance and relative speed.
The only problem I have with it is that if I move into the slow lane from behind a car in the middle lane because the slow lane is clear then I end up accelerating up to the set speed. This can mean you end up undertaking middle lane hoggers if you are not careful.
Posted : 11/05/2018 8:19 am
As everyone has said it's freaking awesome. Mates are always impressed.
With DSG box it does everything, in traffic jams it's excellent. I use it on pretty much every road it's that clever to read the road and obstacles etc that well.
It's also fun scaring passengers when something brakes relatively hard infront and you take no action knowing the system will do it's thing.
Won't ever have at least one of our cars without it now.
Posted : 11/05/2018 8:27 am
That's the only time they get the message to move back over.
Posted : 11/05/2018 8:28 am
This is what impresses me most with the Mrs's golf. Maintains time separation from car in front, then braking to a halt with no input. When traffic sets off again, it requests a quick dab of accelerator to confirm it should follow, then accelerates through the gears within the set time separation and max speed constraints. It's great.
Posted : 11/05/2018 9:28 am
As mentioned before, my car has the rubber band CVT gearbox (with paddles and override) and honestly when in Cruise it’s like floating on some magic carpet ride.
As these systems become cheaper, it’s well worth paying for them if they are upgrades IMO. Obviously work best with autos, but still very effective in manuals.
Posted : 11/05/2018 9:44 am
Which is legal I reckon. You’re not undertaking anyway, you’re staying in your lane, keeping up with the flow of traffic.
Posted : 11/05/2018 10:35 am
As someone said above, the new VWs won't let you undertake (unless you jab the accelerator) in the situation now.
It's a wonderful system, it frees up a surprising amount of brain power to focus on the rest of the road.
Posted : 11/05/2018 10:43 am
As someone said above, the new VWs won’t let you undertake (unless you jab the accelerator) in the situation now.
Can’t say I had that issue with mine.
Posted : 11/05/2018 10:46 am
Ours is a 17 plate one Drac - it'll give you a picture of a car to the right on the screen between the dials and hold you a safe distance behind it. I'd not call it an issue, it's a pretty sensible thing for it to do.
Posted : 11/05/2018 10:57 am
I’ve a 7.5 now but not been on a motorway with it yet, my Mk 7 allowed you to undertake. Certainly on dual carriageways when traffic on the right has been moving slower it’s not slowed down.
Posted : 11/05/2018 11:01 am
Pretty simple conversation for me - I'm on a motorway, I turn it on. I don't expect to fall asleep at the wheel or drift across for no reason - it's insurance against that ever happening. Like all insurance I hope to never have to use it.
Posted : 11/05/2018 11:07 am
Well. . .  There's some pretty glowing reviews here!!  Next car is likely to be an Octavia, I'll be upgrading to ACC if it's not standard.
Also, the anti pedestrian collision software is quite a thing to get used too to.
I tried mine out when up at the Farm and on the driveway into the Farm we have loads of chickens, and the car stopped dead from about 10mph when it detected them.. and a couple of bouncing balls from the nephews..
Posted : 11/05/2018 11:28 am
 kcr
Interesting discussion. I didn't realise this technology was currently  available. In light of the discussion about autonomous vehicles, people seem very positive about adaptive cruise control, which seems like the first step in automating driving.
How does this work in non motorway situations with non motorised traffic? Could someone be driving through town and relying on ACC to maintain distance to vehicles in front, and does that work reliably for cyclists and pedestrians?
I'm all in favour of fully autonomous vehicles, but this seems like a bit of a grey area if a driver is not paying attention.
Posted : 11/05/2018 11:51 am
Fiat 500's must have a version of this, if the young, blonde, female-shaped sack of shit that was 10m off of my bumper at 60mph a few days ago is anything to go by.
Posted : 11/05/2018 12:22 pm
The blind spot warning stuff is good as well.  Yes, of course you check all your mirrors etc before pulling out but at least once a year I have some soon up the outside (or inside as well in Belgium) at a point where you are not looking at the mirrors. It's just an additional backup and it's great
Posted : 11/05/2018 12:27 pm
It might be legal. But how confident are you that the sort of numpty who sails merrily down the middle lane won't suddenly decide to change lane without properly checking their mirrors? I don't normally risk it.
Although I will happily undertake if there is a clear empty lane between us (i.e. they're in the fast lane and i'm in the slow, with nothing in the middle). Because there's always one.
Posted : 11/05/2018 12:42 pm
I’ve used mine on motorways, A roads, dual carriageways, a few times on B roads never in country lanes or in town.
I wouldn’t dispute Town driving with it, but I’ve never tried it and probably won’t either.
Mine definitely works when spotting both cyclists and pedestrians, horses and runners.
I’m not in favour of autonomous vehicles, whilst the blob holding the steering wheel maybe ineffective on the current network, I feel we’ve just about accepted that new tech needs to be tried in a real world environment rather than computer simulations and manufactured claims by the largest manufacturers.. I’m not saying it won’t be an option, but I don’t believe the decision making software is upto the level of even the simplest of intellectual drivers out there. Yes there are arguments for/against and many a thesis written on benefits thereof, yet we still have lunatics driving vehicles with it (that lady in a Tesla for instance) and for that reason until people like her are taught properly to use it we will end up in a situation where no one will accept blame in any accident/incident.
Adaptive Cruise Control and Lane Departure systems benefit and assist, yet do not remove the need for a fat blob to control them.
Certainly an interesting time we are in in the development of the technology, I’m hoping that these systems become standard on every vehicle, as I do for automatic lights/wipers.
Posted : 11/05/2018 12:43 pm
I’m all in favour of fully autonomous vehicles, but this seems like a bit of a grey area if a driver is not paying attention.
The driver not paying attention is an issue even without these features probably more so.
Posted : 11/05/2018 12:48 pm
 kcr
Agreed. If all ACC is good enough to reliably spot cyclists and pedestrians it could improve urban road safety. I just was not aware that people could be driving about town with this now, and I haven't seen much discussion about how well the different systems work in that situation.
 I don’t believe the decision making software is up to the level of even the simplest of intellectual drivers out there
Google have already demonstrated their cars identifying and avoiding cyclists in live, public driving tests. Their car also allows cyclists to move away from junctions first, so I think they have probably already exceeded the abilities of some human drivers.
Posted : 11/05/2018 1:22 pm
