9/11 documentary
[Closed] 9/11 documentary
118 Users
According to a new report by Middle East Eye, Prince Bandar bin Sultan – Saudi Arabia’s most famous arms dealer, longtime former ambassador to the US, and recent head of Saudi intelligence – was among those detained as part of Crown Prince Mohammed bin Salman’s (MBS) so-called “corruption purge” that started with the initial arrests of up to a dozen princes and other top officials last weekend.
If confirmed, the arrest and detention of Bandar would constitute the most significant and high profile figure caught up in the purge – even above that of high profile billionaire investor Prince Alwaleed Bin Talal – given Bandar’s closeness to multiple US administrations and involvement in events ranging from Reagan’s Nicaraguan Contra program (including direct involvement in the Iran-Contra scandal), to making the case for the Iraq War as a trusted friend of Bush and Cheney, to directing US-Saudi covert operations overseeing the arming of jihadists in Syria.
So you now agree that the twin towers collapsed due to aircraft impact and subsequent uncontrolled fire and you wish to talk about the people involved in that? or are you going to disprove science with politics?
Posted : 14/11/2017 3:56 pm
There were huge lateral forces when the plane hit the building; shook the whole tower. Took the resultant fire to take it down though.
yes, i meant in the collapse
Posted : 14/11/2017 3:59 pm
so the towers in fact collapsed in quite an unpredictable way?
No, but see below
So... it was predictable?
Yes, but see below
One would expect that given all possible collapse scenarios, the one that occurred was quite likely?
It couldn't really have collapsed any other way, that does NOT mean that the collapse was predictable or likely. Just the manner of collapse.
You seem to be mixing up probability of collapse Vs probability of a different manner of collapse. (or maybe I'm mixing up what you're getting at?)
I doubt anyone would have predicted it [i]would [/i]collapse. But if you'd told people to predict the [i]manner [/i]of collapse if subjected to excessive structural damage of the type that we now know occurred then "down, roughly into it's own footprint" is the answer you'd likely have got.
Posted : 14/11/2017 4:00 pm
The issue is that there appeared to be minimal lateral forces.
should there have been, why?
as above then, are you aware of some significant lateral force that we've all missed?
Posted : 14/11/2017 4:02 pm
CharlieMungus - Member
referenced above, but copied again
Nearly every large building has a redundant design that allows for loss of one primary structural member, such as a column. However, when multiple members fail, the shifting loads eventually overstress the adjacent members and the collapse occurs like a row of dominoes falling down.
The perimeter tube design of the WTC was highly redundant. It survived the loss of several exterior columns due to aircraft impact, but the ensuing fire led to other steel failures. Many structural engineers believe that the weak points—the limiting factors on design allowables—were the angle clips that held the floor joists between the columns on the perimeter wall and the core structure (see Figure 5). With a 700 Pa floor design allowable, each floor should have been able to support approximately 1,300 t beyond its own weight. The total weight of each tower was about 500,000 t.
As the joists on one or two of the most heavily burned floors gave way and the outer box columns began to bow outward, the floors above them also fell. The floor below (with its 1,300 t design capacity) could not support the roughly 45,000 t of ten floors (or more) above crashing down on these angle clips. This started the domino effect that caused the buildings to collapse within ten seconds, hitting bottom with an estimated speed of 200 km per hour. If it had been free fall, with no restraint, the collapse would have only taken eight seconds and would have impacted at 300 km/h.1 It has been suggested that it was fortunate that the WTC did not tip over onto other buildings surrounding the area. There are several points that should be made. First, the building is not solid; it is 95 percent air and, hence, can implode onto itself. Second, there is no lateral load, even the impact of a speeding aircraft, which is sufficient to move the center of gravity one hundred feet to the side such that it is not within the base footprint of the structure. Third, given the near free-fall collapse, there was insufficient time for portions to attain significant lateral velocity. To summarize all of these points, a 500,000 t structure has too much inertia to fall in any direction other than nearly straight down.
[quote=sbob ]There were huge lateral forces when the plane hit the building; shook the whole tower. Took the resultant fire to take it down though.
Still not huge enough to shift the CoG outside the footprint. In fact I suspect even if you had a succession of airliners crashing into the tower during the 10s it took to collapse that still wouldn't have been enough to prevent it collapsing straight down.
Before anybody asks, no I haven't done the maths and I CBA.
Posted : 14/11/2017 4:03 pm
Yes, i did mean the manner of collapse. That if someone said a plane would explode in there and the subsequent fire would cause a collapse, you would reasonably say, Yeah, it will pretty much fall on itself
Unless you're aware of some significant lateraa force that we've all missed?
Only ones i can imagine would be the unpredictable nature of one thing falling on another. tends not to be just vertical forces at play
Posted : 14/11/2017 4:07 pm
No, it really is just the vertical bit you need to worry about in this situation.
The force is gravity, and the mass is mahooosive, any lateral reaction forces from bumping into stuff on the way down are many orders of magnitude smaller, consequently you cna pretty much disregard them, hence...
"Yeah, it will pretty much fall on itself"
Posted : 14/11/2017 4:10 pm
Yeah but the mass under the influence of gravity swept everything in one direction, there was considerable deflection mass - lots of stuff being ejected in the videos, but the general trend is going to be in the direction of the insanely dominant accelerating force of gravity.
ahhh cross post with amedias
Posted : 14/11/2017 4:11 pm
jivehoneyjive - at times with your various forum posts [i][b]very[/b] occasionally[/i] you touch on some almost credible (albeit tenuous) points. But with all the nonsense spouted on topics like this you're discrediting anything you say I'm afraid. I wish you well, the world needs cynics but you need to pick an appropriate target, this is on a par with faked moon landings and lizard Royal families.
Posted : 14/11/2017 4:14 pm
This is one of those situations where the numbers are BIG, and humans are generally speaking, terrible at envisioning BIG. We think we can, but we can't, hence why we need maths to prove stuff to us once it gets outside of the realms of what our brains can deal with.
Logic and experience tells us that if you bump into stuff you get deflection*, but in everyday situations we're not encountering stuff BIG enough, or realising the BIGness of the difference between things.
Plug the numbers in and it becomes a lot clearer!
*yes some of the rubble gets spat out sideways, but the bulk of the mass goes in the same direction.
I can accept the difference in magnitude, but the chaotic nature of bumping into stuff, especially the building itself, lots and lots of times makes the straight down seem very unusual
Posted : 14/11/2017 4:17 pm
It's not though.
This really is a case of your perception vs reality. There may be lots of stuff in the way for it to bump into in a chaotic fashion, but the horizontal forces are still orders of magnitude smaller than the one going down, so down it goes, and remember its not a rigid structure, even if some part of it gets a punt sideways, it's not transferred to the mass as a whole.
You really need to get your head around the fact that there are no [i]external[/i] lateral* forces during the collapse. Once you get your head round the fact that there is no force acting laterally on the mass then you can see why there's no reason to expect lateral movement of the mass as a whole.
*The only lateral forces are horizontal components of reaction forces due to the down wards motion, and these are tiny by comparison.
Posted : 14/11/2017 4:22 pm
The chaotic nature at the small scale (say the size of a brick or book) is going to largely cancel out. Within the core of the building there'd be so much material and so little time between a floor collapsing and the material of that floor impacting the next that lateral forces would be minimal. At the edges there'd be less constraint so you'd get material ejected but it would be relatively constant on all four sides so the resulting lateral forces would still be too small to have any significant effect.
As noted earlier, the largest lateral force the buildings had to cope with were the plane strikes: 280 tonnes at 400-500 knots vs 450,000 static tonnes.
Posted : 14/11/2017 4:25 pm
Assuming every level was blown to get it to drop - would this look any different? All the concrete is gonna break up and be sent in all directions but will get normalised into the downward direction.
Posted : 14/11/2017 4:26 pm
Except they are not. They are of the same magnitude, they may be smaller. Unless you reckon the angle of the 'bump' is very small. It would just be a factor of Cosine of the bump angle, wouldn't it?
Posted : 14/11/2017 4:29 pm
there is always a gravitational force on the mass, the deflection forces get cancelled/minimised/deflected again or the part gets destroyed/broken again, when they hit something else, the gravity force is still there.
It's lie leaves blowing int he wind, there is turbulence, collisions and stuff getting ejected sideways, but the majority of the mass is going in the direction of the prevailing wind.
Posted : 14/11/2017 4:30 pm
Not sure how it works, but by blowing it, isn't bumping reduced because the thing it might bump into has gone?
Posted : 14/11/2017 4:32 pm
In isolation, many of the theories regarding the towers collapse as a result of plane impact and fire do seem perfectly reasonable, all we're ever likely to have on that front is informed conjecture from either camp
That said, when looking at cases which bear some similarities, it's not unreasonable to question not only the mode of collapse, but the factors which led to it.
(disclaimer: no responsibility taken for 3rd party material and external websites)
the deflection forces get cancelled/minimised when they hit something else,
except at the edges, where they will tend to be in the same direction.
and only if collapse is uniform
Posted : 14/11/2017 4:34 pm
So you have concrete and steel layers, an external skin, and inner cores columns. The layers (the floors) are tagged onto the inner core columns. If you cut all the columns or de-tag them from the columns its gonna go down right. But there is still most of the existing mass.
Do they not collapse from the ground up?
Posted : 14/11/2017 4:37 pm
 sbob
jivehoneyjive - Member
Not really.
I saw the plane impact the building, I saw the fire, I saw the collapse.
They didn't collapse before the plane impact and fire, did they?
Posted : 14/11/2017 4:38 pm
except at the edges
lots of stuff got ejected sideways, have you seen the videos.
The Windsor building in Madrid is a different construction to that of the WTC. The Windsor building is/was a traditional stanchion and beam construction so each floor has multiple columns supporting it. The WTC were an inner core and outer skin joined by very lightweight lattice beams.
If you don't understand the difference then you won't understand why one collapsed and the other didn't. Of course I don't remember a passenger jet aircraft striking the Windsor building, do you?
Yes but it wasn't all from one side so any force resulting from material being ejected from the north side would be largely counteracted by that being ejected from the south. Similarly for east and west.
Posted : 14/11/2017 4:40 pm
Well yeah but the demolition proponents say they were blown in order just in advance of each floor dropping. I am giving them latitude.
Posted : 14/11/2017 4:42 pm
Had we not established that mechanically at least, the aircraft impact was not relevant?
There's videos of the collapse????
Posted : 14/11/2017 4:43 pm
The horizontal motion from 'bumping into stuff' is a small horizontal reaction component of the downwards momentum after collision, there is still the resulting downwards component of momentum + the force from gravity downwards, and that is [i]still [/i]acting, the horizontal force [i]stops [/i]after collision.
Take a single piece of rubble as an example, even if 100% of the downwards momentum were converted to 100% lateral, there is nothing pushing that bit of rubble sideways after it hit whatever it hit, but gravity is still pulling it downwards, overall path is down...
I'll say this bit again:
There are no [i]external [/i]lateral forces. There is an external vertical force, gravity.
Posted : 14/11/2017 4:44 pm
If you blow it into dust, sure. But that's not what controlled demolitions do. In either situation the bulk of the building and the bulk of the strength and resistance to the falling material is still going to be there.
Perhaps you could do a massive demolition which did have a bigger impact on the strength and the rate of collapse- but people would have noticed when the building blew up like a melon with a grenade in it, rather than collapsing like a collapsing building. Or, you could strip out the contents and leave just a skeleton- like in a real demolition- but again that'd be kind of noticable.
Posted : 14/11/2017 4:45 pm
There are no external lateral forces. There is an external vertical force, gravity.
No need to say that again I haven't proposed any external lateral forces
nothing pulling it back either. I can assure you it's not the lack of understanding of the basic mechanics of this which makes it problematic. It is the complexity of the interactions which make it difficult to unpick
Posted : 14/11/2017 4:49 pm
I think it is likely it did cut a column here and there.
Posted : 14/11/2017 4:50 pm
Indeed which is why the cloud of whatever is significantly larger than the perimeter of the tower.
Posted : 14/11/2017 4:55 pm
Yet you think there should be (bulk) lateral movement. How can there be lateral movement with no lateral force?
There's nothing pulling it no.... but there is something pushing back against it....air resistance, which is why it decelerates horizontally, probably not *that* much there is no force acting on it any more pushing it further out where as vertically gravity is still acting on it vertically.
Posted : 14/11/2017 4:56 pm
Let's try some probabilities
1)Probability that it would collapse 'neatly' given that it was a controlled explosion:
2)Probability that it was a controlled explosion, given that it collapsed neatly:
some estimates will do just to get started
Off centre mass would be a possibility. Think Jenga, no external lateral force, still results in bulk lateral movement
There's nothing pulling it no.... but there is something pushing back against it....air resistance, which is why it decelerates horizontally, there is no force acting on it any more. Where as vertically gravity is still acting on it vertically.
This isn't towers dropping in a vacuum!
air resistance acting in any significant way on a brick ejected laterally from the building?
Posted : 14/11/2017 5:00 pm
You've just gone down the rabbit hole CM...
Nooooo! the Towers are NOT like Jenga.
re-read the earlier posts re: pivoting and rigid/load transferred structures. Jenga blocks are solid, the Towers were mostly hollow. The upper stack of a Jenga tower can pivot due to being a semi-rigid structure with good load transference. The Towers could not do that.
air resistance acting in any significant way on a brick ejected from the building?
you'd be surprised, but you're missing the point. In the absense of an acting force the brick (or whatever) will continue horizontally at the same speed, it won't get any faster, it would infact slow down due to air resistance, but the amount is not the point, the point is that gravity is STILL acting on it vertically so it will accelerate vertically.
Posted : 14/11/2017 5:03 pm
This deserves response because I know you are not trolling, you are robustly questioning.
In jenga, the energy during the fall, in the down direction, is much less than the energy required to smash/crush/destroy the jenga blocks.So the falling blocks deflect off relatively very strong block below, cos they have nowhere else to go.
In wtc, the energy required to crush any level below, is utterly insignificant to the energy during the fall.
Posted : 14/11/2017 5:06 pm
I'm fairly sure that only one camp is using informed conjecture.
Out of the buildings shown above what fundamental design similarities do they have, and importantly what differences?
what do the fires have in common? E.G. were any of them caused by the flash ignition of 90,000 litres of fuel or did they start in one small location and spread from there over time? I'm fairly sure you know the answer already
Posted : 14/11/2017 5:08 pm
Smash a brick on an anvil and it will go sideways, by a couple of meters,or maybe 5, if that happens 100 floors up the wtc, at 70m wide, it does not look as if its gone far sideways, but its still got 400m odd to go down.
Posted : 14/11/2017 5:09 pm
…with magic explosives that don’t make any sound. Aye. Right.…with magic explosives that don’t make any sound. Aye. Right.
...oh you were there?
Posted : 14/11/2017 5:11 pm
indeed, imagine jenga where the blocks are 95% air and they are physically joined together. Now structurally weaken them rather than trying to topple it.
As mentioned early as a very good analogy, if you want to simulate the aircraft impact on your jenga then flick a sugar lump at it.
Nope but there were one or two other people there and I'm led to believe that there might have been some news coverage too. Spookily enough no one has ever reported hearing explosives which, had they been used, would certainly have been heard.
Posted : 14/11/2017 5:15 pm
I have now lost track of who are the truthers and who are the sane ones!
What's all this sugar cube business?
Posted : 14/11/2017 5:17 pm
[quote=CharlieMungus ]Except they are not. They are of the same magnitude, they may be smaller. Unless you reckon the angle of the 'bump' is very small. It would just be a factor of Cosine of the bump angle, wouldn't it?
If the whole of one side of a structure between floors stays intact whilst the other side collapses, then given the numbers here the sin of the angle is 4/70 - still an order of magnitude less horizontal forces even resulting from a collapse in such a fashion. The reality is that nowhere near that much offset happened during the collapse. I'm not sure where you think you're getting a bigger bump angle than that affecting the whole structure, unless you're completely discounting the floor by floor collapse model.
Posted : 14/11/2017 5:18 pm
1)Probability that it would collapse 'neatly' [s]given that[/s] if it was a controlled explosion:
high, being that that is the aim of a controlled demolition and a building of that construction type cant really collapse any other way, it can't topple so what other way for it to collapse is there?
Impossible to answer as this is a non-sequitur, since the only manner in which a building of that construction type could collapse is 'neatly' (in this context) whether controlled or not you cannot infer a probability of the former from the latter.
Posted : 14/11/2017 5:19 pm
oh, and set fire to them too, just because it'd be fun 😉
Posted : 14/11/2017 5:23 pm
its to do with ponys. feeding of.
Posted : 14/11/2017 5:29 pm
I'll just quote myself from two days ago, because I don't think I was too far off the mark.
jimjam
Multiple questionable or seemingly incongruous issues which open these rabbit holes in the conspiracy theorists mind and without expertise in multiple fields it's impossible to fully rebuke or rebuff them.
Taking 9/11 as an example - someone who wants to disprove the conspiracy theorists needs to have expertise in aerodynamics, aviation, architectural/structural engineering, metallurgy, demolition....etc etc etc
Even if you happen to actually be a world renowned expert in one of those fields the conspiracy theorist will simply switch to another "fact" or more "evidence" of something else. Something which renders your expertise in the previous field irrelevant, and you are suddenly back on a level playing field of guesswork and supposition.
Also, I think it's worth keeping track of the full spectrum of this conspiracy. Let me see if I can get this straight.
1. The jets which hit the Twin Towers were actually empty, and they were radio controlled.
2. The radio controlled jets were actually missiles disguised as planes, this is how they caused so much damage.
3. The twin towers were both destroyed by controlled demolition because it looked a bit like a controlled demolition.
4. WTC7 was destroyed by controlled demolition, not fires caused by burning debris from the twin towers.
5. WTC7 had 91,000 litres of diesel in it, but this didn't contribute to the fire because they found all that diesel in the wreckage...so they managed to blow the building up with explosives, but avoided rupturing the diesel tanks.
Posted : 14/11/2017 5:55 pm
Don’t forget the unicorns.
Posted : 14/11/2017 6:13 pm
am bo - Member
Ah yes. The unicorns were controlling the [s]jets[/s] missiles from the edge of the flat earth.
Posted : 14/11/2017 6:19 pm
This is a democracy (sort of!) and we've now heard evidence from both sides, so lets vote on it (ive added my vote)
A) The WTC was hit and brought down by aircraft hijacked by terrorists: VOTES: 1
B) The WTC was brought down deliberately by some secret agency to cover some secret evidence or event, or to influence public opinion: VOTES: 0
Please copy /paste, adding your vote. At some point when we have the results we can close this thread with the relevant majority finding
Posted : 14/11/2017 6:31 pm
maxtorque - Member
Pffft. Clearly someone isn't woke enough to know that the (flat) earth is run by a secret cabal of illuminati shape shifting lizard pedophiles who maintain the illusion of democracy and freedom to suit their own nefarious purposes.
Begone with your talk of votes and "evidence". Come back when you're able to lift the veil of lies from your eyes and see the world for what it really is. You are living in a dream world, and delusion and all of your "evidence" is exactly what "they" want you to believe.
And /sarcasm /smiley /somekindoffunnyanimated.gif
Posted : 14/11/2017 6:34 pm
C) There are many anomalies surrounding 9/11 VOTES: 1
Posted : 14/11/2017 6:35 pm
I'm guessing the people who are trying to explain away science with politics still think it was a conspiracy, the people that don't understand science still think it's a conspiracy, and the people that understand science still think they can convince the conspiracy theorists, is that about right?
Posted : 14/11/2017 6:38 pm
The point was not to compare the Towers to Jenga, but to give you and example of a system which has no external lateral force, yet lateral displacement occurs.
Posted : 14/11/2017 6:44 pm
[quote=jivebunny]C) Due to my lack of knowledge There are many [s]anomalies surrounding[/s] things I don’t understand about 9/11 VOTES: 1
FTFY
Just give me the top 5, I haven't got all night.
Posted : 14/11/2017 7:31 pm
I'm not saying it's the mind control dolphins.
Posted : 14/11/2017 7:37 pm
fire too intense...
mostly due to structural failure...
ground zero...
from one minute in should do you.
Posted : 14/11/2017 7:39 pm
...oh and just some people who were actually there ....
Posted : 14/11/2017 7:56 pm
Just look at these two liars 😉
Posted : 14/11/2017 8:14 pm
A) The WTC was hit and brought down by aircraft hijacked by terrorists: VOTES: 2
Posted : 14/11/2017 8:25 pm
Jive do you think two big passenger plains with passengers on flew into the sides of the WTC towers ?
Posted : 14/11/2017 8:55 pm
B) The WTC was brought down deliberately by some secret agency to cover some secret evidence or event, or to influence public opinion: VOTES: 1
Posted : 14/11/2017 9:13 pm
I'd have to be pretty mental to regularly mention Bandar Bin Sultan's links to the hijackers and Mohammed Atta at Huffman Aviation if I didn't think planes flew into the WTC towers.
But as I've said, there are many anomalies...
Cheekyboy's video is a good example:
Of course, it doesn't prove anything outright... but it's reasonable to imagine experienced firefighters have a grasp on the difference between an explosion and structural collapse or any other phenomenon which would've bought the lobby down.
I'd highly recommend watching this film:
In addition to covering a lot of ground, it goes a bit more into the background of the security arrangements of the buildings.
On top of that, it's really well made, entertaining and in some parts funny. Brilliant work considering it's all just the one guy and jam packed with plenty of solid research.
Posted : 14/11/2017 9:20 pm
On this: planes were swapped in flight (youtube is your friend), with military planes, adapted/loaded with lord only knows,.. passenger planes were diverted landed (lord only knows what became of the passengers, don't even want to think about that)... planes hit buildings. no plane hit WT7, that was demolished, so...that means 1 and 2 were too.
...there were supposed mobile phone calls made from loved ones....this has been proved impossible in 2001 from the height the planes were at at the time.
Posted : 14/11/2017 9:25 pm
Wow, just wow!!
Posted : 14/11/2017 9:28 pm
I see what you were getting at, but it's still misplaced. I've tried to explain to that it behaves differently because it's a different kind of structure. You might expect some toppling with a rigid structure but not a structure like the Towers, and especially once you take the scale difference into account.
There is still no external lateral force by the way (other than an initial push maybe), your Jenga tower topples due to the vertical force of gravity, the toppling is because it is able to transfer load between it's rigid components and essentially pivot, at least until the pivot point moves, it doesn't move sideways because of a continuing lateral input force, it topples due to gravity and the rigid nature of the structure. Once the bricks separate it all falls downwards of course, it doesn't continue moving sideways other than any existing horizontal momentum.
TLDR, Jenga is different so not relevant.
Posted : 14/11/2017 9:41 pm
" planes were swapped in flight (youtube is your friend), with military planes, adapted/loaded with lord only knows,.. passenger planes were diverted landed (lord only knows what became of the passengers, don't even want to think about that"
Why? Why swop the planes if you were going to"disaster " the passengers , why not just hijack the planes and crash the actual planes into the towers ?
". planes hit buildings. no plane hit WT7, that was demolished, so...that means 1 and 2 were too." If you plan to demolish the buildings without the planes why bring planes into the equation just blow the buildings up.
Posted : 14/11/2017 9:52 pm
Hang on, earlier in the thread, firefighters couldn't possibly have predicted the collapse of WTC7 because they just spray water on fires, they're not structural engineers or anything clever like that.
You really need to conspire with your fellow theorists to come up with a consistent story.
Edit:
Exactly. At lizard/illuminati HQ they got together and said "right then lads, we're going to blow up the world trade centre" and someone said "oh, how, with a bomb?". And they said "no, with what looks like planes. We've got our best men on it, and they've realised that actually a plane won't make the building fall down so we're going to make it look like planes but actually use *something else?!?!?* to get the job done".
And nobody said "well, if planes wouldn't do the job, wouldn't someone figure it out?"
It's like putting together a false-flag terrorist 'atrocity', only the bad guys are armed with supersoakers instead of AKs, and just hoping that nobody notices that supersoakers aren't usually fatal.
Posted : 14/11/2017 9:53 pm
...don't even want to think about that...
Thinking doesn’t appear to be one of your strong points anyway. So I wouldn’t worry too much.
Posted : 14/11/2017 9:56 pm
From memory there were only two cell phone calls placed on 9/11. Both were from UAL93. Both were when the aircraft was below 7,000ft. Both did not last longer than a minute or so. Both took several attempts before the calls were connected due to poor reception.The bulk of the calls were from airphones the built in phones in the seatbacks. I guess the hostages were not worried about their credit card bills.
Posted : 14/11/2017 9:58 pm
Wow, there are some seriously diverse viewpoints one here.
Who said the UK wasn’t both diverse and divided 😆
Indeed. Given if it was a conspiracy the amount of planning that must of gone into it, letting cell phone calls slip out, or make up a story that's impossible would be a pretty big gaff.
Posted : 14/11/2017 10:08 pm
Oooh get you. 8)
Posted : 14/11/2017 10:34 pm
5:40 ...more people who knew WT7 was about to collapse...
Did you hear that? Keep your eye on that building it will be coming down soon...
wow, everyone is an expert, or everyone got to have a nice chat with an expert with a crystal ball
Posted : 14/11/2017 10:50 pm
Page 6 / 19
