4G LTE network type...
[Closed] 4G LTE network type help!!
4 Users
Is this specification TP Link M7350 router
4G: FDD-LTE B1/B3/B7/B8/B20 (2100/1800/2600/900/800MHz)
3G: DC-HSPA+/HSPA/UMTS B1/B8 (2100/900MHz)
2G: EDGE/GPRS/GSM Quad Band (850/900/1800/1900MHz)
Similar to or better than this iPhone 6s
Model A1688*
Model A1687*
LTE (Bands 1, 2, 3, 4, 5, 7, 8, 12, 13, 17, 18, 19, 20, 25, 26, 27, 28, 29)
TD-LTE (Bands 38, 39, 40, 41)
TD-SCDMA 1900 (F), 2000 (A)
CDMA EV-DO Rev. A (800, 1700/2100, 1900, 2100 MHz)
UMTS/HSPA+/DC-HSDPA (850, 900, 1700/2100, 1900, 2100 MHz)
GSM/EDGE (850, 900, 1800, 1900 MHz)
As my girlfriends Samsung Galaxy alpha
GSM 850 / 900 / 1800 / 1900
3G bands HSDPA 850 / 900 / 1900 / 2100
4G bands LTE band 1(2100), 2(1900), 3(1800), 5(850), 7(2600), 8(900), 20(800) - G850F
LTE band 1(2100), 2(1900), 3(1800), 4(1700/2100), 5(850), 7(2600), 17(700) - SM-G850M
Speed HSPA 42.2/5.76 Mbps, LTE-A Cat6 300/50 Mbps
Does not get 4G in our basement flat and she's throwing a tantrum.
I can't see why it won't work as both the Three network bands are covered, maybe it's just a should have bought an iPhone thing that Apple nerds love to say.
Apologies for the worlds most boring question.
Posted : 05/07/2016 10:34 am
Your phones connect to it via Wifi and it connects to the mobile network via 2G/3G/4G. So any phone with wifi will connect fine.
Posted : 05/07/2016 10:45 am
Yes, but I'm interested in if the 4G spec of the router will receive 4g signal in our basement flat. Think I'll only know by trying it
Posted : 05/07/2016 10:49 am
 IA
Not sure I get your question?
Does the iphone get 4g? It's more likely an antenna/reception issue than having the right bands.
If your phones don't, then I don't suppose it will be any better.....
Posted : 05/07/2016 10:51 am
 cp
4G
and
basement flat
is probably an incompatible combination..
Posted : 05/07/2016 10:57 am
The iPhone 6s gets 4G perfectly well, including using it as a hotspot. The Samsung gets nothing really.
Posted : 05/07/2016 11:02 am
Are you both on the same network?
Posted : 05/07/2016 11:20 am
Yes both on three, perhaps I'll try EE
Posted : 05/07/2016 11:21 am
Will all come down to how good the antenna / LNA is in the Wifi module.
Which you won't know till you try....
Posted : 05/07/2016 11:27 am
Thanks footflaps
Posted : 05/07/2016 11:31 am
