I bought one of [url= http://www.sainsburys.co.uk/webapp/wcs/stores/servlet/SearchDisplayView?msg=&catalogId=10241&langId=44&storeId=10151&krypto=gZeiTTO4IlIiYiv%2FtJClZdY0hz3yvUlQ1XVJxq%2FN2lXBRogilcD%2B69xmwS58bDpuy5VhTQCPxcgA4w3R%2BSGc1OcjnrZ1j2w9gObAqCk4C8%2Bydi8JTn9CfC8LkRtRsV5w6tb%2BDK5Hs7%2BrphUyxpHVytg4Wt34%2FTsPK46PJfCv%2BCF1%2B4KRntq4oAxNtQfikEaP#langId=44&storeId=10151&catalogId=10241&categoryId=&parent_category_rn=&top_category=&pageSize=30&orderBy=RELEVANCE&searchTerm=blaupunkt%20bpr%202&beginIndex=0&hideFilters=true&categoryFacetId1= ]these DAB radios[/url] today, but want to run it from a 12v supply in the camper. (Stupid long urls!)
[img]
[/img]
[url= http://www.powerstream.com/dc6.htm ]This[/url] is what I need, I think, but where can I get one from in the UK?
[img]
[/img]
From what I remember of my GCSE Electronics would suggest you need a Potential Divider.
https://en.wikipedia.org/wiki/Voltage_divider
Two resistors, total cost about three pence.
That only works if you also know how much current the radio takes, which will change 🙁
Looks like this sort of thing but you need to check the power raying
^^ or a voltage regulator if the output voltage is a bit more sensitive (12V from a car can be 14.4 on a good day, and quite messy)
That's the ticket Leffeboy, cheers.
I have no idea what everyone else is talking about which is why that although thruppence is cheap enough I'm happy to pay a tenner for someone else to put it together. 😀
> https://en.wikipedia.org/wiki/Voltage_dividerTwo resistors, total cost about three pence.
As above they only really work when you need to divide the voltage for something that takes no current and are fed from a fixed voltage supply.
I have used these buck converter boards for doing similar. Again you would need to check the required output current.
http://www.ebay.co.uk/itm/262367320918
I can't even buy the parts to make them in the uk for that price which is rather annoying...
I've a vague handle on electronics but I do so wish it was better. I'm not silly, but I follow a retro computing group on Facebook and the skill of the guys doing repairs on there just breaks my head.
Maplin sell the car adapters if you want to go in a shop.
