2010/11 Reba solo air 26". Lockout on, fine. Lockout off, 20mm travel.
Before I take them apart, suggestions? Doesn't matter what the psi is, I get the same clunk at 20mm regardless of set rebound rate or +/- gate adjustment.
I believe the right stanchion to be the problem.
Worked fine on Monday.
Wrong forum edit. Sorry again.
Posted : 19/08/2015 5:56 pm
Weird that it's better with lockout on than off, but my bet would be that the damping oil has leaked into the lowers.
Might be ok with a strip and rebuild or might need new seals.
Easy to diagnose as there'll be a lot more than the 15/20ml of oil in the lower leg.
Posted : 19/08/2015 7:41 pm
