This review is for a RockShox Reverb AXS seatpost, 31.6mm post diameter with 170mm travel. It has been transferred between bikes and had the saddle ch ...
By amandawishart
Get the full story here:
https://singletrackmag.com/wp-content/uploads/2023/06/rockshox-reverb-axs-seatpost-review/
Nice review Amanda.
Question: Do you think a small saddle pack would ever work with this post (Tube, levers, gas canister)? I'm imagining the battery would make fitment tricky.
Just debating whether to gat a Reverb AXS for my drop-bar mtb.
@stanley I use a small weecog bag on mine and it works just great 🙂
What’s the weight difference? I could look that up but I feel like it should be in a review.
I’m personally not interested until they get 200mm+. But even then it’s a lot of money for a tidier cockpit and slightly nicer lever feel + some real world downsides (need to remember to charge/carry spare batteries around).
Having said that, I’ve never used one. Perhaps they feel so amazing I’d be convinced!
They do feel amazing, also you can change which button actuates it when paired with AXS gears, which is ace, battery concerns for me are a non issue, needs charging maybe once a month if you don’t do it out of habit every ride. And again, if using AXS gears, you can use that battery to set the post wherever, then swap back. Or just carry a 25g spare if you are paranoid.
I stopped caring about weight a few years ago, but IIRC it’s about 750g, 100g more than a regular one
Unless you are off to ride for more than a week of 9+ hours of riding a day then that isn't really a downside. Spare battery is always handy, but it isn't needed for every ride. Charger isn't a major hassle to pack either, but you do need to make sure you have access to power when you do need to recharge.
I don't ride every day but I'm recharging the battery every 2 months, so it does seem to have plenty life in it.
Your concern seems to suggest you may be thinking it is like Apple products (and some other large screen smartphones) that need to be charged every single day...it isn't. It also only really uses power when it is being used, so unless you are using it constantly whilst riding (as in raising and lowering it constantly and not just for adjusting for the terrain) then the charge lasts a good while.
@spannermonkey - at a guess, you remove the saddle, turn the post round so the battery housing is at the front and then refit the saddle. The tilt adjustment is then at the rear of the bike and you will just wind the adjuster to get the required adjustment that you need. The battery part of the unit only goes as low as the seatpost collar, so unless you have a seriously angled top tube, the battery shouldn't come anywhere near the bike frame when the saddle is fully dropped.
@dickbarton unfortunately not as simple I believe, Berm Peak have a YouTube video where he tried, but the battery pushes up against the underside of the saddle
Will be interesting to have a wireless dropper comparison soon - trans-x and magura (updated viron) both releasing posts this year.
RE turning the post 180 degrees..
Jesse Melamed has jsut popped a vid on pinkbike showing around his EWS bike and he does this... apparently SRAM made new mounts or something, to allow it to fit.
MAY be something for aftermarket companies to make?
DrP
@spannermonkey - it isn't something I've tried myself, but that sounds a reasonable issue - I hadn't considered angle of saddle and battery pack, just the lower bit and the frame space...
@DrP ooo that's interesting "Rockshox made me custom seat clamps"
Reason I'm interested is that like in the Berm Peak vid, I'd end up with the post dropped right to the collar and can't see how to get past the issue of buzzing the battery on the rear tyre at full compression and then ripping out the battery
Had my 150mm since the launch 2 years ago, swap it between 3 bikes using a Crank Brothers seatpost shim, same saddle, though I swapped it over a fair few times before settling on the 'one saddle to rule them all'. No issues with battery life even with multi day camping trips, use AXS gears so I do have a spare battery. Absolutely no issues and I love what I call the 'bump' feature, a quick tap and the post drops 5 to 10mm to give a bit more maneuverability on techy climbs. Yesterday I rode a demo bike with a cable operated dropper and missed this 'feature' so much. As for cost when I purchased it was the same as 3 x service for my Fox Transfers so pretty much a no brainier, at current prices it is a luxury option if you are just replacing one post. The only negative is that by just undoing the traditional hex bolt on your clamp the whole thing can be carried away by a light fingered thief, sorted this by using a 'security' hex bolt on both clamp and trigger bolts. The mechanics at Bike Park Wales thought it was a neat idea and it does the job.
4 years ago…
Surely a con is the near £600 price tag. For a seat post.
Where you can get the same functionality for less than £100 from Brand-X.
It's not the same, of course, but it's absolutely a negative. Until there's mass adoption the price of wireless is still gonna be eyewatering.
The first listed ‘Con’ is that it’s expensive.
Provides more of a benefit over standard droppers than spendy cranks do over budget ones though.
Yes the price is a eye watering.... But I bought my first one new for £450, so in line with other top end posts of the time, and my other 2nd hand at £300. Both have been as reliable as brand-x but have a much much nicer feel and benefits of wireless. If I were building a bike on a budget id go with brand-x and a nice lever. No budget build, axs if by far the best at the moment....
We'll see how the trans-x / brand-x wireless post stacks up later this year but the £500rrp will still put it in the 'silly price' category for most people.
I’d also disagree on ‘same functionality’. Yes, the seat goes up and down, but the speed of actuation/lack of lever throw means that you barely even have to think to operate it, never mind push a lever through all its travel to activate it. Then when combined with AXS shifting, the ergonomics mean I barely have to move my thumb to make it work on the RHS shifter, using the knuckle of my thumb.
Err, try £791 RRP... 😲
They are bloody good, but not that good.
Look at what they actually sell for though - around £500, I’ve never paid more than that.
