Review - Magicshine...
Review - Magicshine Monteer 8000 Galaxy you're never going to need more light!
33 Users
8 Reactions
Magicshine's latest 8000 lumen Monteer is less of a light and more like your very own personal solar flare for the trail! Winter might bring cold weat ...
By singletrackandi
Get the full story on our front page at:
https://singletrackmag.com/wp-content/uploads/2021/11/review-magicshine-monteer-8000-galaxy-youre-never-going-to-need-more-light/
Support us and help us keep the content flowing by becoming a full member.
Posted : 15/11/2021 11:24 am
gives me enough full power light to get a couple of runs in on the local at night, around 1 hour, but knocking it down to the Mid power setting can easily extend that to 2 hours, and honestly, I wouldn’t really need more.
This is really odd almost 400 quid for a light that runs for 2 hours?
Nope.
Posted : 15/11/2021 12:23 pm
Nope.
That's what put me off a Moon light I was considering. The "useful" settings didn't go beyond about 3 hours and the next mode down was a 90hr emergency setting, it's a shame as I usually criticise lights for having too many modes! 🤣
Posted : 15/11/2021 12:30 pm
It is weird isn't it that lights in general seem to be optimised for really short rides.
I've mitigated this somewhat by getting an adaptor which means my two Hope batteries work with my Moon light, and buying a 4 cell support for my Exposure.
#BuyBatteriesFromSmudgeRatherThanNewLights 🙂
Posted : 15/11/2021 12:45 pm
completely sealed to an IPX standard
IPX what? The second digit is missing, which is the relevant one for water ingress; the first digit being X just means it hasn't been tested for mechanical protection.
Posted : 15/11/2021 12:57 pm
It is weird isn’t it that lights in general seem to be optimised for really short rides.
Not really. Unless you are uplifting in the Alps then you won't spend that long hammering down hill. You don't need that much light when you are climbing and you can put it in a mid setting for cruising.
I watched an informative YouTube on this light comparing it to an exposure and an eBay special. It was pretty impressive and put them both in the shade (pun intended)
Posted : 15/11/2021 1:05 pm
mrchrist reacted
Unless you are uplifting in the Alps then you won’t spend that long hammering down hill. You don’t need that much light when you are climbing and you can put it in a mid setting for cruising.
This. Also, I use lights to go for an evening 2h ride. I don't need more burn time than that. If I was doing 24 hr events then obviously I'd want something else.
Posted : 15/11/2021 1:18 pm
That is the mid setting 😆
It only lasts an hour in high.
Posted : 15/11/2021 1:38 pm
Nope.
TBH, they don't work like that in real life.
The 8000s has the same battery as my 6500s. Frankly the 6500s is insanely powerful, I can't imagine needing more.
You don't use the high settings on anything but really technical bits, you just don't need too, you're given loads of flexibility, you can run the floods only, which is fine for winching up fire roads and such, or just the spots if want, and low/med/high of each. The lowest setting, just using the floods is equivalent to max power on my old Halfords 1600 light.
Having all the lights on max on my 6500 is incredible, past good enough for technical riding at night. When some other, even very bright expensive lights will cast big shadows on roots and stuff making them look a lot bigger than they are, it manages to fill a lot of that in, you just don't need it most of the time, in fact, if you're out with friends, it can be a bit blinding if you're not the one behind them.
If you want to find reasons to knock it, the external battery is large and bulky and unless it's a cool night (and you keep moving) its surprisingly easy to overheat them, causing them to dim.
I personally, have never used more than half the battery capacity on a night ride.
Posted : 15/11/2021 1:53 pm
WTF would I want to cycle up a fire road? 😉
Anyway, I'm clearly in the minority, so it appears the manufacturers are correct in thinking most people do short night rides.
Posted : 15/11/2021 1:59 pm
I think the point was that even if your night ride was to sneak into BPW after dark, then an hour of descending is probably a 6 hour ride? Or if you're riding more natural singletrack then even then you don't want 8000 lumens* all the time. 8000 lumens is about the same as 16x car main beams (or 8 car's depending on how you look at it). Which in itself will start to be problematic as trees nearby are going to be lit up much brighter than the trail ahead. So unless your riding is constant high altitude, above the treeline flat out descending for over an hour, you don't need more battery than that!
Efficiency has only improved 65% between the P7 and the XHP50 LEDs, and batteries have got denser by about the same amount, so if you want 10x the power we had 10 years ago with those P7 lights, you're going to also get about a third of the battery life.
*real world lumens, not chinese lumens.
Posted : 15/11/2021 2:11 pm
Anyway, I’m clearly in the minority, so it appears the manufacturers are correct in thinking most people do short night rides.
Ha ha, no honestly, it will do 3/4/5/6 hour night rides if you like, but it won't do it on full power, which is insanely powerful.
Think of it like a Tesla car, it could do 0-60 in 2.8 seconds and 150mph or whatever, that performance is there, if you want it, but it would mean a greatly reduced range. Most of the time you don't need all the power.
Posted : 15/11/2021 2:15 pm
J-R reacted
I have an RN3000 on the bars. I never run it on full all the time, there's no need. Only use it for tech and fast stuff. I can easily get 4+ hours out of it.
The 8000 must be mental, but i prefer self-contained lights.
Posted : 15/11/2021 2:17 pm
 DrP
Hmmm... not really (x2)
My exposure 6 pack stays in the 6 hour reflex setting...
plenty usable enough for a 3-4 hour night ride..
DrP
Posted : 15/11/2021 2:18 pm
J-R reacted
Yep. According to MS's website, there's 100, 50, 25 and 10% settings. 10% is still, presumably, 800lm (or maybe more if LED efficiency is non-linear). Which is what my main light produced 10 years ago, so more than enough for the uphill and/or none technical bits of a longer ride. I can't imagine ever wanting more than 50% TBH.
Posted : 15/11/2021 2:23 pm
J-R reacted
at the other end of the price scale I just ordered one of the from amazon for 25 quid.
https://www.amazon.co.uk/gp/product/B09H6ZDTGR/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
I dont expect its anywhere near the 5000 lumens they claim it to be, I wanted to give it a try on the handlebars and see whether its better than my halfords advanced 1600 light that I normally use on the bars in conjunction with another cheapo led light on the helmet
Posted : 15/11/2021 2:25 pm
I think the battery looks by far the best bit of that light. Would be thoroughly excellent paired with a 2kl light. Just the job.
Hmmm… not really (x2)
My exposure 6 pack stays in the 6 hour reflex setting…
The exceptional light that pretty much proves the rule.
Posted : 15/11/2021 2:41 pm
 cp
teethgrinder
I have an RN3000
Be interested in your thoughts on this - beam pattern/spread? I'm looking for a decent spread of light rather than the hot spot of twin LED cheap chinese lights.
Posted : 15/11/2021 2:45 pm
Night riding is awesome because familiar trails become a new challenge
Not with 8000 lumens they don't...
I'm pretty happy with the couple of sets of lights I picked up from PX.  The Strix and Strix Pro.  The Pro is on the Bars and the other one on the lid.
Nominally 700 and 800 lumens but compared to lights that claim 1000 lumens+ they compare favorably.
Posted : 15/11/2021 3:40 pm
@cp
https://singletrackmag.com/forum/topic/happy-new-light-day/
Has a nice spread compared to the X8 (which has LEDs on a "solarstorm" PCB).
Used it loads since I got it, and really like it. Not seeing the need for the Monteer 8000 or even 6500.
Posted : 15/11/2021 3:47 pm
If you’re referring to the same video I saw the chap didn’t test the exposure light correctly. Was it this one?:
Posted : 15/11/2021 4:03 pm
Lasted a full 60km night ride in this video - as others have said, you don't need to run it at full power all ride. I've got one and it's monstrously powerful in full beam so I only use that for descending.
Posted : 15/11/2021 4:15 pm
 cp
@teethgrinder
Has a nice spread compared to the X8 (which has LEDs on a “solarstorm” PCB).
Thanks! I currently have the X8 and am after brighter and better spread. looks like it might be just the ticket 🙂
Posted : 15/11/2021 4:28 pm
I still run an X8 on the helmet
Posted : 15/11/2021 4:41 pm
You are not along thegeneralist - that does not seem to be making the most of the battery to me either. I really like the Exposure programmable modes concept. Riding a long night (or multiple without ability to recharge) the ability to tune it down from a 100% (techie), 50 (JRA) and 25% (slow uphill) to say 80/40/20 and increasing your burn times is great.
Posted : 15/11/2021 4:48 pm
Thing is about night riding for me, I want it to be different.
Me, the bike, a good light and the dark is what I am looking for.
If I wanted high, high illumination, then I will just wait for the sun to come up and provide all the illumination that I need.
Is it just me?
Posted : 15/11/2021 4:56 pm
Yes
I night ride all year round, with only 6-8 weeks over summer not needing lights. Different times of the year, weather etc. need different lighting. Sometimes you need all the lumens, sometimes not as many
Posted : 15/11/2021 5:06 pm
Is it just me?
Nope. I want it to be different too, and now I'm slowly getting back into it, with 'old' lights that 'only' top out at 1000lm, I'm slightly worried I'm going to be outgunned lights-wise by anyone I happen to ride with; riding in your own shadow, cast by someone's bar-mounted portable sun behind you, is horrible.
Posted : 15/11/2021 5:19 pm
They aren't LED's are increasingly inefficient as they ramp up. I can't even imagine the "requirement" for the 8000 unless you're landing a large plane. In reality most riding will be below 50% light and hence 65% (or so battery)
I watched the same video as NickB and got the 10% off... bought a 6500 and 1/2 power is almost enough to ruin a night ride and make it feel like a day ride. 4 hrs at 100% so at least 8 hours if required on 50%... and still throws out A LOT more usable light than an exposure
The same video has the £25 Chinese light... these also work fine though batteries can suck but I use one on the HT rather than swapping lights over. Just follow someone with a bigger light if doing gaps and drops. (Good excuse IMHO)
Posted : 15/11/2021 7:17 pm
They aren’t LED’s are increasingly inefficient as they ramp up. I can’t even imagine the “requirement” for the 8000 unless you’re landing a large plane. In reality most riding will be below 50% light and hence 65% (or so battery)
Eh?
My point was: Why have they put together this combo of huge battery and far too many powerful LEDs to come up with a light that only last a short time on anything 50% brightness or above and hence will almost never be used on max power.
And you've said: Can't believe they have produced this light that puts out so many stupid lumens. Most of the riding will be fine at 50-60%.
We're saying pretty much exactly the same thing.
To take the point further:
Why don't they just pair this amazing battery with a 2-3kl light, reduce the cost by 100 quid, use up less of the earth's resources, save 70grammes on your handlebar and have one less intermediate power output that you have to skip through whilst looping between the output levels that you actually use.
Posted : 15/11/2021 7:41 pm
Two eBay specials with new batteries I made myself and a borrowed Magicshine MJ-880 will have to do me for now. I'll find out on Thursday how they fair. My riding buddy has a Monteer 6500 and a Diablo, so he can go in front...
Posted : 15/11/2021 7:45 pm
Why don’t they just pair this amazing battery with a 2-3kl light, reduce the cost by 100 quid,
They do. The RN3000
Posted : 15/11/2021 8:09 pm
They do. The RN3000
Gnomm. 🙂
Now all I need to get my head round is how the company that used to be known for bargain basement cheapness is now charging on a par with Exposure.
Posted : 15/11/2021 8:22 pm
Hero product. Lots of media attention. Raises brand profile. And they probably don't ride bikes themselves anyway.
Posted : 15/11/2021 8:25 pm
 cp
They do. The RN3000
Got to be careful on quoted battery capacity. The monteer 8000 comes with a 7.4v 10,000mah (74Whr) battery consisting of (I guess) 4x 21700 cells whereas the rn3000 comes with 3.7v 10,000mah (37Whr) consisting of 2x 21700 cells. I.e. the monteer has twice the capacity of the rn3000.
Posted : 15/11/2021 8:44 pm
That's fair on the batteries. Though the RN is less than half the lumens of both the 8000 & 6500.
There not perfect, but on for the money they're pretty decent and way less outlay than Exposure. I get that Exposure are good and hold their value, good backup etc., but we can't all afford £350+ for them. The RN fills that gap for me.
Posted : 15/11/2021 8:52 pm
Eh?
And you’ve said: Can’t believe they have produced this light that puts out so many stupid lumens. Most of the riding will be fine at 50-60%.
We’re saying pretty much exactly the same thing.
Why don’t they just pair this amazing battery with a 2-3kl light, reduce the cost by 100 quid, use up less of the earth’s resources, save 70grammes on your handlebar and have one less intermediate power output that you have to skip through whilst looping between the output levels that you actually use.
The 6500 has the same battery .. battery prices for W/h are the same as MTB batteries... (£99 for the 10kWh)
But its more efficient* to run the LED's at lower power. (*for light output not heat)
Most of my riding is fine at 50% on the 6500 but if you want to do big unmaintained gaps or hammer down rock chutes in dark woods more is better. (We were doing this last week and TBF "as much as possible was best" at least for whoever went first - if they hit a hidden tree then you knew to avoid it) So the 5% of the time you step it up to full is actually useful (when you need it).
I guess its like saying 160mm rotors and resin pads on 2 pots stop you... which is mostly true but the 5% when they don't is significant.
The LED's are in 2 banks ... one wide and one long. You can control the power to both banks independently (through annoying clicks) ...
On the 6500 Both on MID gives 3600 claimed lumens of the claimed 6500 for 1/2 the time (4hrs vs 8hrs) so its about 55% but you could do 3h50m on this and have lights at the 300 lumen get home mode until well past sunup. (40hrs on eco from full)
Not sure it will though ... running the LED's on 55% will not only extend their life but also the batteries.
Well they aren't quite there the 6500 is way more powerful than the exposure 5000 (and a better quality light) ... but as above batteries cost the same as MTB Batteries .. considerably less weight on the bars than exposure... not exactly cheap but if you see the same video the "mid range" £140 light tested was about the same as the £25 ebay light for light... and doesn't include batteries (eBike specific) so in a way you can also look at it as what do you get per £ above £25...
I've got the same £25 ebay chinese light.. I made a bar mount as the one came with it is pants when doing drops, it ends up pointing directly down when you land) and I still use this though... I'd be gutted however if I'd spent say £150 on a light that didn't give any extra light... so a bit of diminishing returns really.
I was going to make a new battery (if only because the chinese one goes through 3 batteries in 4 hours on mostly 1/2 power) but it was going to cost me the best part of £100 and I'd have to empty the garage to get to the spot welder... so I sorta went OTT perhaps but with the 10% discount (
it cost slightly more (taking £100 off for the battery) than the £140 mid range light in the test which was about the same as the £25 Chinese one???
Posted : 15/11/2021 9:42 pm
an IPX standard
That's not massively helpful without saying which one. Technically that statement would be true if it was IPX0.
Posted : 16/11/2021 7:14 am
J-R reacted
Same way as Honda improved product brand perception, or Skoda too. Not uncommon for a consumer brand to reposition themselves when market opportunities present themselves, and the test results across lots of MTB media would suggest uts been a good strategy.
Posted : 16/11/2021 10:43 am
J-R reacted
Nope. I want it to be different too, and now I’m slowly getting back into it, with ‘old’ lights that ‘only’ top out at 1000lm, I’m slightly worried I’m going to be outgunned lights-wise by anyone I happen to ride with; riding in your own shadow, cast by someone’s bar-mounted portable sun behind you, is horrible.
This is why I bought the 6500S, my riding mate uses an Exposure Six pack, having him follow me with my old Halfords 1600 meant I was riding in a shadow and as you say, horrible.
We're more closely matched now so it's no problem.
Posted : 16/11/2021 12:45 pm
I'm all for a bit more light for descending but that amount of light just seems ridiculous - does it melt the surrounding trees as you ride past?
I'm still convinced 1600 lumens is the most light needed for descending, but I guess it depends on where and how you ride - certainly there was an arms race to get brighter so your mates don't get you riding in a shadow, but it seems we have gone to the extreme end of the mental stakes with something that bright...each to their own but that isn't appealing for night riding for me, just far too bright.
Something that bright should only last about 1 hour unless battery technology can now be focussed on and get improved burn times without larger batteries - definitely not an easy thing to crack.
Just seems mental to me that people think they need something that bright for night riding - even in some thick wooded areas with a reasonably gradient and technical stuff, I'm genuinely unsure why that would be required.
Posted : 16/11/2021 3:12 pm
Wait till you get to my age Dick! I was perfectly happy with 1600 lm up until last year when I found myself struggling ever more to see where I waqs heading. I have just bought the Magishine 6500 and it is great. On low power it is about the same brightness as my old lamp on half power and will last for about 6 hours or more like that. No idea how long ludicrous mode lasts but the other night we did 2.5 hours, of which about 30 minutes were on full power and it didn't even use one of the 3 bars on the LED battery indicator.
Posted : 16/11/2021 3:19 pm
Something that bright should only last about 1 hour unless battery technology can now be focussed on and get improved burn times without larger batteries – definitely not an easy thing to crack.
The middle ground should actually increase quicker than the ludicrous mode's if all else was equal.
If you look through the samsung battery specs they'll offer different 18650's for different applications. Some will have higher storage capacities, others will have higher current capacities. So the super bright lights will suffer a bit with lower battery capacities as they draw more current.
The flipside to that is it's been a while since I bought loose batteries for lights, it's possibly the case that even high storage capacity batteries can deliver sufficient current for these light now. Or that companies only produce one battery pack to cover all bases.
Posted : 16/11/2021 3:31 pm
How old is that? My fear is it isn't as far away as either of us think! 😉
I'm still rocking the Light & Motion Seca 900 Race Ultra - that apparently will run for about 4 hours on full beam - admittedly 900 lumens, but the light spread is fantastically usable and works very well. I have started riding faster so also have a helmet light that is about the same brightness (actually might be 1200 lumens), but combined they are great.
I've got a Halfords 1600 light but find full brightness is just too bright and everything just flares so you don't see any detail.
I'm all for technological improvements, but I also appear to be set in my ways and find brightness is only usable if it doesn't flare and I seem to be finding 1600+ doing that far too much.
Anyway, enough of my grumblings...what is the age difference so I can see how old my grumping makes me sound! 😉
Posted : 16/11/2021 3:33 pm
I will be 55 shortly, but have suffered with pretty poor eyesight all my life.
Posted : 16/11/2021 7:28 pm
No mention of the fact that you have to cycle through all of the settings to go up to a higher beam? I.e you're just about to drop off a nice descent and have got to toggle through the low settings and flashing setting to get to high beam.
Posted : 19/11/2021 1:51 pm
thegeneralist
I think you're missing the point a little, it's not "short night rides", it's just "doesn't need to be on high power". Yes it's 2 hours on "mid", but it has a mid setting that is still stronger than a lot of lights' high setting. When in mid it's probably brighter than both of my lights on full power, combined, for perspective and they're perfectly good lights that I've raced downhill with. And even Low is a useful trail light unlike older lights where it was more or less fire road/get me home.
IMO the switching on these isn't clever though, it'd be great to have MAX POWAH mode as a seperate button press. Cycling switches kind of suck at the best of time but when the top mode is so atomic I just wouldn't want to cycle past it to mid or low, I'd just want to switch it on for dh sections.
Posted : 19/11/2021 10:08 pm
The V2 has a remote with 2 buttons, one to toggle through settings, one to jump straight to full power (and then back to previous setting).
Posted : 19/11/2021 11:54 pm
Ah that's exactly what I was hoping for, cheers!
Posted : 20/11/2021 12:25 am
Yup, that's good to know.
Posted : 20/11/2021 8:05 am
https://magicshine.com/products/monteer-8000s-v2-0
Posted : 20/11/2021 11:53 am
I think some are missing the point and focusing too much on the headline output. I bought the 6500 and the ability to run at around 2000lumens for a claimed 7hrs was what sealed the deal. Most 2000 lumen lights have a run time of 1.5-2hrs.
Posted : 20/11/2021 12:57 pm
 cp
I think in some ways the 6500 is the better option for respectable run time vs light output. I'm very tempted by one.
Posted : 20/11/2021 1:04 pm
I had the 3500 for a few months and the light itself was very good (toggle issue aside, which now seems to be fixed with that remote up there.).
Just couldn't like the separate battery though. It's a great battery, but it just gets in the way, as do the cables.
Went back to Exposure.
Posted : 20/11/2021 1:19 pm
Good evening
My Names Nick im the UK distributor for Magicshine UK. I apprecaite all your feedback, Im a Through and Through Mtber myself, I took over last year with NO experince, I just have a massive passion for riding bikes.. its been a steep learning curve but were getting there. Im happy to take on any of you suggestions and pass to the manufacture.
Posted : 20/11/2021 7:54 pm
Magic Shine - in my opinion are not worth the money. I am sorry to say that I disagree with this review. I purchased a Magic Shine light 2021 after the previous top marks review. they last for a just over a year, when they failed due to a common issue, the cable from the battery to the light. I sent it back, they said yes its a common problem. Then after a month it failed again, they have then since never responded to my emails. I recently ordered another cable which arrived with an exposed part of the cable I sent them pictures and no response. The light is no longer used.They were an amazing light at first, so if you are testing them on straight out of the box, they would be impressive, but spending over £300 now £400 I would expect the more last more than a 12 months+ These lights due to the expense need to be on a long term test to show their property quality and reliability, also after sales is important, I am not a professional rider or access to abundance of cash, but i feel strongly about being mis led. And think they are not in the same league as other brands.
Posted : 28/11/2023 1:41 pm
Hi,
If you would like to send the light to me I can see if I can fix/modify it to see if I can get it working again for you. I have managed to fix quite a few MS lights/batteries and would be a shame if it can no longer be used by you.
I cannot promise anything, but for the initial cost of sending it to me. If so, please ping me an email. Thank you.
Posted : 28/11/2023 1:54 pm
jairaj and jairaj reacted
Assume this is the brittle inner cable insulation cracking and causing short circuit and the battery going into protection mode until plugged back into the charger to reset.
On my 3rd removable battery cable and second head unit here. Managed to warranty the cable which went first, then the head unit which went something like 6 months later - luckily manufacturer had increased the warranty period which I had to ask the distributor about as they initially said it was out of warranty. Latest cable is purchased but have also cut out the offending section of the failed cable and soldered so have a spare.
I've seen a thread somewhere else showing the head unit opened up so at least that section of cable should be able to be replaced at some point, but the bullet connection may be a pain to replicate.
I've asked last time if the manufacturers are aware and if they have plans to change the specification of the cable but had no response.
Posted : 28/11/2023 6:46 pm
Disappointed to say that I have this same cable issue with mine. Emailed the manufacturer and was told to jog on because I was a few months out of warranty. I guess I’m buying a new cable.
Posted : 28/11/2023 6:50 pm
