We are a relatively broad church here at Singletrack World and this week's Fresh Goods Friday is testament to such. Droppers 'N' strappers. Video 'N' ...
By ben_haworth
Get the full story here:
https://singletrackmag.com/2024/09/fresh-goods-friday-723-the-big-strapping-edition/
So £700+ is just what we pay for dropper posts these days?
Anyone know if I can still by a Gravity Dropper with the big knob you have to reach between your legs to grab hold of? That's all I need.
Hang on, that came out wrong...
A dropper post, or this moderately fun looking hardtail?
I get that one's at the top end of dropper post technology, and that the other's at the bottom end of what constitutes as a useable mountain bike, but £730 is a bit bonkers. IIRC the first Reverb droppers (back when if you wanted to drop your seat post you had to stop and loosen your seat collar) was only $300
Ooh, does that mean hot-tips are back in stock then?
You managed to talk about the fixplus straps without once mentioning 'Voile', 'copy', or 'bandwagon', nice going!
gravity droppers came out in 2003, I think I got one around 2008 and it was £200
This is where a Big P-Nut can really save the day, as they’re big and offer a decent amount of finger purchase.
And are worth about 99p. I'll continue to carry some small pliers ta!
Super glue is the answer to sorting cable ends. No frayed ends and no need to cut anything off the cable.
And the big P nuts are a good idea, I once had a locknut that wouldn't even come off with pliers so I had to chop the whole thing out. Having said that, if something is seized then the whole valve is likely to turn before the nut loosens.
P nut/P lugger combination tool? All in one tubeless repair solution
shouldn't be too much of a stretch.
If it isn't already available I'm happy to take a small commission
kimbers
for £730 Id want that dropper to gently caress my perineum at all times
Even when off the bike?
The P nuts have a chamfered recess on the underside that enables the tubeless valve to pull through and seat against the o ring. It’s quite a neat design which apart from enabling trailside repairs facilitates the quick checking of valve security before going for a ride. Also, rims don’t get scratched from the use of pliers!
No. Some cost that. Most don’t.
I needed bottle cage boss relocators to fit a frame bag + bottles on a gravel/tourer and have to say that the generic ebay ones look to be a better design than the passport ones here - basically using low profile bolt heads on the frame connection halves the depth of the aluminium bar, which helps if the reason for using is lack of front triangle space. The ones I got were excellent quality and of course a lot cheaper.
You can get cheap presta valve lockrings with similiar shapes, not quite as big as the p-nut I think but they're usefully easier to tighten and remvoe than a standard one.
Mine came with a teeny tiny anodised wrench to tighten them up, which I thought was adorable but of course I lost it 2 seconds later.
Those Sleeper grips look comfy but would I be right in guessing they wear out really quickly?
Especially when off the bike…
Those Gusset grips look very similar to ODI Longnecks,,,?
They do indeed. Different feeling rubber though IME.
