I know the leaderboard thing appears a bit before they start, but I still often miss them until I see the tunnel.
How d you see the start- the green line across the course is pretty obscure?
On the map in the top right corner
you need to remember where they start/finish really
Just remember them if you care that much about them. Or remember those few you actually think are worth going for. I know where they are in Watopia, couldn't care less about anywhere else.
This. Look for the green marker.
the leaderboard is 500m before sprint i think.
there's normally some king of marker next to the road that accompanies the green line too, that's how I spot them usually.
I’ve just ended up learning the ones I’m interested in. And don’t forget you need to be wound up to full speed as you cross the green line as well for the best result on most.
Once you've done the sprint once a little ghosty PB version of you will appear the next time to race against. It appears on the map as a little grey dot and waits patiently at the start line until you pass. Unsure if it's there in events, though.
Other than that, check the route out on Zwift Insider and make a mental note of roughly where the start is.
