ZS44/28.6 | EX44/40...
ZS44/28.6 | EX44/40 pressing
5 Users
8 Reactions
 PJay
I've a ZS44/28.6 | EX44/40 headset to press. I've only previously pressed 1 1/8  external cup headsets and have press both cups simultaneously.
Is this a valid approach with a ZS44/28.6 | EX44/40?
I'll be using a press not blocks of wood.
Posted : 20/10/2023 6:07 pm
 cp
Regardless of headset cups I always do one at a time so that one end is always stable. Pushing them in at the same time increases the chance of cock up
Posted : 20/10/2023 6:21 pm
Yeah, same here, doing both at the same time just adds risk of one going wrong imo, I don't think there's any benefit to it.
That said, I fit all headsets with a rubber mallet. I have 2 headset presses, a couple of manual threaded presses, and a 12 ton hydraulic press, but rubber mallet is the best allround tool for it imo.
Posted : 20/10/2023 6:46 pm
I've done both ways without incident, if your press can centre well doing one cup at a time then do that, doing both at the same time makes it centre better with multi stepped presses.
Posted : 20/10/2023 7:12 pm
jamiemcf and jamiemcf reacted
 PJay
Okay, thanks guys.
I'm sure I picked up somewhere that pressing them together keeps them square to eachother, but that's probably nonsense. It's been ages since I pressed a headset so I'll watch a couple of videos to refresh my memory.
Assuming I used the press, for the first cup I assume that the opposing insert just rests on the headtube.
With the above headset, any benefit to pressing the upper (internal) or lower (external) cup first?
Posted : 20/10/2023 7:16 pm
 PJay
Went well doing one at a time 👍
Posted : 21/10/2023 4:34 pm
andy4d, lovewookie, andy4d and 1 people reacted
@PJay good work. Its def better one at a time as you can be stable and square in the headtube
Posted : 21/10/2023 7:30 pm
