Zero stack headset ...
[Closed] Zero stack headset for 44mm headtube......
7 Users
Hi Chaps,
I've seen the CK one, but does anyone else know of a 44mm headset, for a tapered fork which is Zerostack?
Cheers for the help!
Ricks
Posted : 27/01/2013 7:15 pm
Cane creek 40 series or hope.
I replied to your mail BTW.
Posted : 27/01/2013 7:24 pm
Hope pick and mix will have something too. Think it's top cup 2 bottom cup B. for 1.1/8 steerer you might have to use an external if you are using tapered.
Posted : 27/01/2013 7:33 pm
Hope pick n mix 2, H cups
Nukeproof Warhead 44IETS Headset
Sorry missed the Tapered steerer bit...
The H cup from hope is traditional external cup, not zero stack though.
Posted : 27/01/2013 8:03 pm
I'm pretty sure you can't so zero stack on the bottom of a 44mm tube with a tapered steerer. You need a 56mm lower part for that.
Posted : 27/01/2013 8:11 pm
Think geetee has it.
Posted : 27/01/2013 8:12 pm
For a tapered steerer to work in a 44mm headtube you need to have an external lower cup, if you do the basic maths it can not work any other way.
Posted : 27/01/2013 8:20 pm
Indeed, zero stack top but need external lower.
Superstar Components do one for £28 that comes with two fork crown races for standard and tapered steerers
http://superstar.tibolts.co.uk/product_info.php?cPath=25&products_id=539
Posted : 27/01/2013 9:22 pm
False alarm! Some pooface bought the last large sultan frame just as I was getting my card out. FAIL.
Posted : 27/01/2013 10:41 pm
Hi, I had this very same problem and there is in fact a zero stack headset for running a tapered fork in a 1.5" headtube. You need an FSA Gravity 2 headset. It uses a sealed bearing up top and very small caged bearings in the lower to allow them to be incorporated within the headtube. It's not without downsides; it's pretty heavy and the bearings will wear faster than sealed (I had to replace after 6 months), but a bag of 50 was 3 quid! Hope this helps. http://www.shinybikes.com/gravity-by-fsa-gravity-2-headset-tapered-steerer-130-0020n.html
Posted : 15/02/2013 10:23 pm
