Zero Gap Stems
Zero Gap Stems
18 Users
5 Reactions
Stems where you tighten the top bolts all the way down... Enve, Hope Gravity, any others?
Posted : 27/09/2023 7:23 pm
Renthal
Posted : 27/09/2023 7:30 pm
zerocool reacted
Too many to list all of them I'd imagine.
Joystick
Posted : 27/09/2023 7:34 pm
Ragley, Nukeproof . . .
Posted : 27/09/2023 7:35 pm
Dmr
Posted : 27/09/2023 7:36 pm
Raceface Turbine R, Affect R
Bird Blank
Posted : 27/09/2023 8:11 pm
Intend, three rock, 5Dev, 77designs
*in that, they are 2 bolt stems, that bolt at the bottom.
Why’d ya ask?
Posted : 27/09/2023 8:29 pm
Pro Koryak stem does this.
Posted : 27/09/2023 8:34 pm
tomhoward
Why’d ya ask
May need a new 35x35 stem, find zero gap convenient for a bike that often has bars removed to go in a bag.
Two bolt jobs are ruled out for thw same reason.
Posted : 27/09/2023 9:22 pm
Unite
Posted : 27/09/2023 9:53 pm
For packing a bike down, I've always found it easier to remove the stem from the steerer. Then it's a matter of getting the stem straight rather than having to get the bar roll back where it was. Drop a few spacers on the steerer just to keep the forks in place.
Posted : 27/09/2023 11:49 pm
nickc, tomhoward, LAT and 1 people reacted
Nukeproof Horizon ticks all the boxes imho, well made, nice wide face plate, good set up markings makes in easy to put bars back in exactly the same place, looks very nice, decent weight & stiffness, plenty options and good value and actual no gap design, not overpriced boutique that don't even fit the criteria and don't allow higher rise bars and are also a pain to remove regularly so no point mentioning 🙄
Posted : 28/09/2023 9:20 am
I still don't know what zero gap means and why it helps the OP?
Posted : 28/09/2023 9:26 am
Instead of tightening the faceplate evenly at both top and bottom, some stems, e.g. Easton are tightened by tightening the top bolts fully to torque first, and then you tightening the bottom bolts, hence there is zero gap at the top. Why this makes it easier for him, I'm not sure
Posted : 28/09/2023 9:43 am
Onzadog
For packing a bike down, I’ve always found it easier to remove the stem from the steerer. Then it’s a matter of getting the stem straight r
I hate trying to align a stem far too much to get involved in that. Have a OnnUup tool also, so it adds fiddliness.
Posted : 28/09/2023 9:44 am
Problem Solver do a bolt up stem spacer. If you use that instead of one of your stem spacers you don't even need to worry about your fork falling out or getting the headset tension just right.
Easily fixed by marking with a sharpie before removal. Same goes for levers.
I use both of these methods on different bikes.
Posted : 28/09/2023 9:52 am
Bikeyoke do similar, little clampy spacer but the OneUp means I'd need to bring a cassette tool to refit the stem.
I'm a sharpie on the bars user, although I know my own bar roll so rarely need to refer to it.
Posted : 28/09/2023 10:14 am
OneUp means I’d need to bring a cassette tool to refit the stem.
My OneUp tool has a tool that fits the cap.
Posted : 28/09/2023 10:20 am
Yeah, but it's a pretty crap cassette tool
Posted : 28/09/2023 10:22 am
Well I'd not fit a cassette with it but it's enough for the tensioning the headset.
Posted : 28/09/2023 10:25 am
No gap stems are made for OCD sufferers who otherwise need to get the gap exactly even above and below the bars before they can ride 😂
Posted : 28/09/2023 3:23 pm
Instead of tightening the faceplate evenly at both top and bottom, some stems, e.g. Easton are tightened by tightening the top bolts fully to torque first, and then you tightening the bottom bolts, hence there is zero gap at the top. Why this makes it easier for him, I’m not sure
Fewer goes around each bolt when tightening I guess?
As a design it does seem more likely that less care (or no torque wrench) is needed by average joe to get even clamping force in all directions.
Posted : 28/09/2023 8:13 pm
yep, more carbon bar friendly
Posted : 28/09/2023 8:30 pm
Is the Nukeproof one meant to be done like that? I'm not sure I have been.
Posted : 28/09/2023 9:30 pm
FSA, one-up, syncros
Posted : 29/09/2023 4:09 am
I've used Renthal Apex stems, Raceface Aeffect R, and currently on a Raceface Turbine R. All have worked perfectly well. Easy setup, no slippage.
Posted : 29/09/2023 6:46 am
