Evening.
Does the Zee M640 shifter allow you to change more than one gear at a time? Also, does it come with cable and outer? I have been Googling away, but have only met with contradictory answers!
Many thanks,
Dom
Mine's the M640, multiple shifts and it came with a cable. The outer was 2 short pieces rather than a full outer. It was a roper retail one not OEM.
That's good to know, and thanks for getting back to me. May I ask where you got it from?
LBS. I got very good mates rates. Almost as good as Rose / Bikediscount.de. But then I have supported them through thick and thin.
CRC have got the Zee shifter for £22.99 about the cheapest I've seen it.
Thanks, nodrog2. I've seen that, but it doesn't say multirelease in the blurb, so I'm hesitating.
I think shimano only make one Zee shifter. Can only find one on the website. That is cheap too. My LBS can't buy them for that.
I got mine from rose and it came with the inner cable only
as bigblackshed has said, only one type and it is multishift
Great. I'll get one ordered.
I have one that isn't multi release.
I've ordered one now, so we'll see. Maybe that's why they're so cheap on CRC.
