Good evening,
I have a zee clutch mech with a damaged cage and an xt non clutch 10spd mech with a good cage but broken body, is it possible to just put the xt cage onto the zee body, or will i die?
Rab
Try it. What have you got to lose?
The answer is definitely maybe - I've had mixed success with swapping shimano cages, but the easiest way to find out is try!
Possibly, although I suspect the clutch one ight be different
One-Up's Rad Cage install video will be a decent guide to fitting/removing cages.
Or if you're 1x10ing it, a Rad Cage might be a good purchase anyhww.
Sure can. I actually did the exact opposite, and fitted a zee super short cage to an XT mech.
Straight swap no problem.
Thanks for the replies guys, off too the shed i go
