Basically i have a raceface narrow wide single chain ring on the front and a 9 speed cassette on rear. Ive ordered a new zee 10 speed clutch derailleur and im going to do the mod with the spacer . My question is, im under the impression i need a new shifter as my original basic shimano one just wont work. What shifter would be best to get to suit this?
anything that is shimano 10sp dyna-sys will work.
why dont you get the zee shifter?
only £22.49 at Tweeks cycles
http://www.tweekscycles.com/components/mtb-gear-shifters/shimano-zee-m640r-10-speed-rapidfire-pod-right-hand-rear
If you're staying 9spd it's gotta be a SRAM x5/7/9/0 shifter and a 6.5ish mm spacer
As above you will need to be a SRAM 9 speed shifter.
Funnily enough I happen to have a SRAM 9spd I can sell
Was so close to buying a saint shifter there. So sram shifter it is then. Whats the details of the one you are selling mate?
Why stay 9 speed? You can get a chain and cassette for under £40 and a shifter second hand for under 20 probably.
Would a new chain be essential even if ive converted to single speed at front? Checked on crc there cassete £36 and chain £15 then shifter on top of that. The reason i was staying with 9 speed was really just a quick/cheap fix for loosing the chain along with cluth mech
New cassette and chain are only £30 at [url= http://www.merlincycles.com/shimano-slx-10-speed-cassette-hg75-chain-63436.html ]Merlin[/url] . If you went 10 speed you need a new chain as 9 and 10 are different widths.
May as well go the whole hog, ive got and x7 or x9 iirc 10/20£ respectively
I can confirm that drilling a zee shortcage works really well. I eyeballed from [url= http://bb.nsmb.com/showthread.php?t=153122 ]this guy's experiment[/url] and put a 2.5mm hole on the the "correct" side. I had a spare 8speed shimano shifter. Worked nicely despite using an oldish 8speed cassette and new chain.
Wysiwyg is the x9 shifter 9 speed? Good con ? If so i will take it.
