YT Capra Headset lo...
[Closed] YT Capra Headset loose?
5 Users
I've just got YT Capra (Brand new) frame and when I was building it up I noticed how easily the top bearing of the headset goes into the frame. It also sticks up above the top of the headtube by about 1-2mm & the bearing can wobble around quite a lot in the frame.
I'm a bit concerned this isn't as it should be.
Can any YT owners confirm whether they have experienced anything similar?
Thanks!
Ed
Posted : 14/09/2015 10:00 pm
Is the bearing upside down?
Posted : 14/09/2015 10:02 pm
No its not, it's chamfered so only goes into the frame one way
Posted : 14/09/2015 10:37 pm
Does it say on the box that it was built on Friday afternoon?
Posted : 14/09/2015 10:44 pm
Id put it all together first with forks. Sitting proud isn't an issue often the top cover will fill the extra height with a seal. You may well find once it's nipped up its play free. Obviously depends on how much wobble there is on the bearing.
Posted : 14/09/2015 11:00 pm
The wife's looked a bit like that, but once built up it's been fine with no problems.
Obviously I didn't mention it to her
Posted : 15/09/2015 12:23 pm
