mine is the safety pin to hold up knee warmers. the "grippy" rubbery strip they have is next to useless but god ol' safety pin works a treat. What "well duh" solutions do you have ?
Got to be inner tube wrap on the chainstay. Simple, cheap and tough. What's not to like?
Sticking safety pins in your legs to hold up your knee warmers is a bit too low-tech for my liking.
this ^^
And looks alright too.
Why press in bearings when a mallet and the right sized socket is much easier?
Extra protection for lower races of external headsets? Cut a sort length of inner tube, slip it over the race, install the forks, roll it down and hey presto! longer life for your headset!.
Cover over my camelbak so I don't have to empty and wash it.
Camelback in the freezer so you don't got to wash it much... Apparently.
I have a couple of Smart 'Lunar' rear lights (R1 and R2 I think?)
To protect them from water/dirt ingress i've cut a 12mm band of inner tube and wrapped it around the light, to seal the joint between front and back.
single-speed rigid.
(any wheel size)
on the camelbak front...no need to even wash it
after a couple of rides just stick it in a basin with a sterilising tablet then bung it back in the freezer once its dried off
Wash it?
Staying in the pub when it's muddy.
No need to wash the bike or clothes.
Old lengths of inner tube pulled over the seat collar and headset to keep the wet out of the frame on the commuter.
These are all a bit high tech really given the man made nature of them all.
I give you the greatest Lo-tech solution = Fire
Smelly gloves in freezer. Once thawed no longer smelly....no soap, no seam damage
Old lengths of inner tube pulled over the seat collar....to keep the wet out of the frame on the commuter
I like that...
fafter a [s]couple of [/s] ride[s]s[/s] just [s]stick it in a basin with a sterilising tablet[/s] rinse it, then bung it back in the freezer [s]once its dried of[/s]
[i]your favourite "low tech" solution[/i]
Mine is my home made Neogaurd alternative,made from old truck inner tubes.
Dried mud as a protective coating which prevents my bikes paint from getting scratched.
I used a lego brick to hold my front mech in place when the cable snapped.
Or is that not what you're after? 😳
Surely any drivetrain that uses mechanical levers to force a chain up and down the block / rings is pretty low tech?
[Blasphemy] Rather than travel using a hi tech, engineered, two wheeled vehicle, simply walk [/Blasphemy]
Is this the sort of thing you are after?
Wad of cling film stuffed up inside the steerer tube from underneath stops it filling up with mud and shit off the front wheel
Lock-on grips and mudguards.
Hammer if things need breaking apart.
Gaffer tape if things need to be held together (again).
Zip ties 8)
Bicycles
Ale can shim is quite satisfying when it works.
Think this was mentioned in Zen and the art of motorcycle maintenance - when his friend wasn't happy with such a low tech solution for some problem on his motorbike.
Bit of wood/stone under the front mech to keep it in the middle ring after a broken cable. Tidy bodge.
Wellies. Dunlop. Job done for all outdoor footwear.
Bottle opener +beer = post ride heaven (salty snack optional)
+1 for a stone, when a pin came out of the chain split link.
Since then I always carry a spare split link and ....... never ever needed it since.
spit on it. works for me.
What's wrong with a suspender belt?
Toothpaste tube (used, empty, cleaned and cut flat) kept in case of tyre split which is too much for inner tube alone. Recycling is great, but my daughter keeps giving me her old tubes!
Some of the thicker bar tapes work well for this also. Mine has been on for 3 years and never comes loose
Positively complex compared to singlespeed....
A) Gaffer Tape
B) Hammer
If it moves when it shouldn't - Tool A
If it doesn't move when it should - Tool B
Bregante - MemberA) Gaffer Tape
B) HammerIf it moves when it shouldn't - Tool A
Generally works for me--also have one additional tool:
Tool C) Automobile
If A or B don't work, drive tool C to the LBS/hardware store for a new whatever you are trying to fix.
Bit of string between the saddle and the seat clamp so when I pull the saddle back up after a descent it comes straight to the right height every time (too stingy for a dropper post).
A length of inner tube slid over a dropper post to keep the shite off.
Oooh, interesting!
Is that a home build? Looks like a spring from a Brooks saddle?
That's got me thinking.......
Yetidan - they didn't catch on the first time, but now, who knows!
google "hite rite"
That's a weird routing for a rear mech cable.
eh, you mean the brake cable?
No it isn't, it's a canti guide....
Gotcha!
Sorry, I couldn't resist the temptation.
I've been edumacated. And I still want one; quite an upgrade from my bit of string!
Gotcha!
Was that the lamest troll ever?
CaptainFlashheart - MemberBit of wood/stone under the front mech to keep it in the middle ring after a broken cable. Tidy bodge.
Puts my lego brick into perspective!
